#1 |
Senior Member
DIY: SRS Codes and reading them.
Ok so I had an issue with SRS the light being on and couldn't find exact info anywhere. After finding it all from multiple places, I thought i'd compile it into a single post to help others out.
1st :: Try to reset your light, it may take 3-4 tries or more if your timing is off. KSMatic - DIY : Reset SRS Light IF Your light blinks 2x and comes right back on, here's how to pull the codes. Step 1: Make sure the key is not in the ignition and then get a paperclip and fold it into a U shape Step 2: Plug it into ODBII Service Port 4 and Port 9 ![]() ![]() (above images courtesy of k-series.com) Step 3: Insert key and turn ignition to Position II Step 4: Watch the SRS and write down the codes. It will stay on for 6 seconds, then go off and the codes will then follow. HOW TO READ CODES SRS Codes consist of a main-code, and a sub-code. EXAMPLE : 21-1 :: 21 is the main code, 1 is the subcode Here are all the possible codes Heres a video of codes i was getting so that you can get an idea on how to read them bettter. I had three codes in this video. VIDEO http://video.google.com/videoplay?do...90455763232641 CODES 15-1 :: Faulty OPDS unit or OPDS unit not initialized 22-1 :: Open or increased resistance in passenger's seat belt buckle tensioner 12-1 :: Open or increased resistance in front passenger's side airbag inflator |
| Sponsored Links | |||
Advertisement | |||
#2 |
Get of My Nuts
Man this is awesome! I figured mine is a faulty driver seat buckle switch 9-3.
Now i just have to figure out how to fix the problem!! Also anybody that knows how to fix my problem please help me!!!! Last edited by upshotunity; 03-18-2009 at 08:23 PM. |
#4 |
Senior Member
these might help
#5 |
SupA FlY......
http://www.youtube.com/watch?v=Ots23KU2bIU
code videos also notice the check engine lights and the abs. decode please, i have my idea of the codes i just wanna make sure.
03_RSX - S ![]() 99_TL (daily)
#7 |
SupA FlY......
yea thats what i got... i dunno how the hell i got those... what could cause that.... anyone else got codes like this?
also i know in the past i leak water down the b pillar, to the right rear of the pass seat... could this cause anything... i dont know if it still leaks... (guessing from roof drainage tube)
#8 |
I like Golf
http://www.youtube.com/watch?v=mAPlfHw2TGI
here is my code, I have no idea how to read it I got 10-6 I think I'm probably wrong |
#11 |
Mr. Lott Stern
i wonder if this process work's with a 2002 civic ex sedan? lmk anyone? thanks!
Super "Chargers" Crew#41 My Whiphttp://a1.ec-images.myspacecdn.com/i...a6a221e0/l.jpg The Beasthttp://a4.ec-images.myspacecdn.com/i...83066b85/l.jpg My Dyno Results Before Being Aftercooledhttp://a4.ec-images.myspacecdn.com/i...5a56f57a/l.jpg |
#12 | |
Senior Member
looks liek 15-3 to me : Faulty OPDS sensor |
#14 |
New Member
can someone tell me what code this is I got no clue how to read them.
http://www.youtube.com/watch?v=NNezjUjIiyE |
#15 |
K-Series
code600= after watching your video i counted the flashes, 10 long flashes and 1 quick one. According to the chart that was posted 10-1 means Seatbelt and seatbel buckle tensioners (and airbag(s)) deployed...
if i understand correctly that means that one or all of those airbags have been deployed before. have you been in an accident? or did you buy it this way.. btw, i'm just taking a guess i'm no expert
#16 |
K-Series
btw, for some reason, i always get passanger airbag off, mostly when i'm driving alone, i took it to the dealership but they tell me it's common usually means seat might have gotten wet but i know its not.
has this also happened to anyone before? i get it all the time |
#17 |
i haz gold plated diapers
i have 4-1, and 3-1 which is open or increased resistance on seat belt tensioner for passenger and driver side. BTW this happened after doing black int swap of seats and seatbelts
'03 RRP base w/ full black interior FTW '*N.orth.E.ast.C.rew*' Team Tape Crew Member #5 DIY Dashboard Removal http://forums.clubrsx.com/showthread.php?t=641971 |
#18 |
Member
I orginally did the srs light reset. And it worked. For like 2 weeks. My srs light just came back on today, i had no luck reseting it. I pulled the codes.
My light flashed once, and than 9 times and than My light flashed 3 times fast, and 9 slow times. Thats all it did. What codes are these 9-1 and 9-3?? I mean my car has never been in an accident, and ive never changed the seats of taken them out or anything. Someone helo me out please! |
#19 |
Member
Could someone take a look at this:
http://www.youtube.com/watch?v=brCVdZ3ZD0c I have no idea what is the code for this. Thanks |
#21 |
USP
Excellent post, just fantastic....
Now how do we FIX our codes? Haha, I mean this REALLY is one of the better DIY threads; however, it leaves most of us with a "now what?" attitude. I pulled 22-1 which is open/resistance to passenger seat belt. Car has been in an accident, but thank God that's the only code I saw pull through so kind of a relief no airbags appear to have been deployed, ha. Anyway, yeah now what...
i thank GOD a lot |
#23 | |
New Member
Did you ever figure it out? Thanks! |
#24 | |
EDIT: i just tried reseting again, this time with the seatbelts buckled in, still got srs light
'03 RRP base w/ full black interior FTW '*N.orth.E.ast.C.rew*' Team Tape Crew Member #5 DIY Dashboard Removal http://forums.clubrsx.com/showthread.php?t=641971 Last edited by dc5prime; 08-05-2009 at 10:03 PM. |
#25 |
Master Member
ok...im quite noob on this issue but i recently remove my seats to install the jdm carpet on my 06 rsx and now the airbag light is on, what's the deal? do i need to reset it or is it possibly i miss a connection somewhere underneath the seats?
| Bookmarks |
| Tags |
| codes, diy, reading, srs |
| Thread Tools | |
