Replacing the "Rear Main seal" when replacing the clutch - Club RSX Message Board
Go Back   Club RSX Message Board > PERFORMANCE BASICS > Transmission & Drive Train
Notices
Reply
Thread Tools
Old 04-22-2009, 10:31 PM   #1
Flip One
Knows he can't spell
Flip One's Avatar
Flip One is an unknown quantity on c-rsx
Is this nessesary? I have a JDM type-R transmission with 20K miles on it. I am upgrading the cluthc to an exedy stage 2 and was wondering if I should replace the seal attaced to the crank?
and also what is the part number of the seal.
Power Mods:Injen CAI, BCRH, Buddy Club Pro-spec exhaust, RBC IM, Brian Crower Stg 2 Cams, Brian Crower Valve springs w/ titanium retainers, Hondata IMG.
Other Mods:JDM Type-R Transmission, Eibach Pro kit springs, ESMM's, Type-R wing, DIY redouts, DIY Blackouts, 8000K Hid's.
Best Times:13.8 @102mph 60ft 2.3
ECU:K-Pro.
Flip One is offline   Reply With Quote
Sponsored Links
Advertisement
Old 04-22-2009, 10:50 PM   #2
IKON671
11.1 @ 136mph
IKON671's Avatar
IKON671 is an unknown quantity on c-rsx
if it ain't leaking don't mess with it.. (if it ain't broke don't try to fix it)
THX 2/FULL-RACE/EVANSTUNING/X-ACT DYNO"SHOWOFF THREAD"MODIFIED MAG DEC 2007
IKON671 is offline   Reply With Quote
Old 04-23-2009, 12:14 AM   #3
Flip One
Flip One's Avatar
thats what I was thinking but someone suggested replacing it. thanks for the input.
ECU:K-Pro.
Old 04-28-2009, 02:08 PM   #4
corey872
Senior Member
corey872's Avatar
corey872 is an unknown quantity on c-rsx
Miles on the transmission really have no bearing on the main seal which is on the engine crankshaft...unless you're implying the engine / tranny combo only has 20K mi. Also, I wouldn't really consider the mileage now, but what you think the engine will have when you expect to pull the trans again. Even then it is probably better to look at age. I've seen plenty of 'collector' cars with low miles, but they leak due to aged / hardened seals. So if the engine is 2,3 or 4 years old now and you don't expect to pull the trans for 3-4 more years, is the seal going to be OK in 8 years?
IMHO, it's cheap insurance against a leak which will most likely trash your clutch in the process. It's less than $20 for a new seal and just about zero effort to install while the trans / flywheel is off. If you risk it, you could end up having to pull the trans just for a cheap seal. Of course the converse is also true...if you plan to sell the car in 2-3 years, you could just leave it and let it be someone else's headache!
Corey
E85 Fueled 02 NBP Type S Mahle 12.5:1 Pistons Precision 5857E Turbo OBX Sidewinder Kpro Injector Dynamics 1000cc
TiAl 38mm Gate ACT XTSS Clutch Eagle Rods ARP studs OBX LSD TSX 6th Gear 3 Custom Magnaflow SS Exhaust
E85 - "The biggest performance fuel bargain on the planet." - Gale Banks
corey872 is offline   Reply With Quote
Old 05-14-2009, 04:29 AM   #5
Cb7-R
Sacked!!
Cb7-R's Avatar
Cb7-R is an unknown quantity on c-rsx
That totally doesnt apply here. Replace the seal. Its about 15 bucks and will cost you no additional labor to replace now.
ASE Master/L1 Technician
Cb7-R is offline   Reply With Quote
Old 05-14-2009, 08:40 AM   #6
paulkramer
Member
paulkramer's Avatar
paulkramer is an unknown quantity on c-rsx
My car is 7 years old now - should I be scared?
paulkramer is offline   Reply With Quote
Old 05-16-2009, 01:51 PM   #7
imbest123
Bańned
imbest123's Avatar
imbest123 is an unknown quantity on c-rsx
so does anyone know the part number?
Wheel gap can be compared to a vagina. The more fingers you can stick in the worse off you are
Don't PM me. I don't give a fuck about who you are and no, I don't have nudes
imbest123 is offline   Reply With Quote
Old 05-16-2009, 09:19 PM   #8
imbest123
Bańned
imbest123's Avatar
Ok so I looked it up and Im guessing its part number 91214-PNA-014 which is number 26 in this picture. Can anyone verify this for me?
Old 05-16-2009, 09:52 PM   #9
corey872
Senior Member
corey872's Avatar
That looks like the one.
Corey
Old 05-17-2009, 02:19 AM   #10
Cb7-R
Sacked!!
Cb7-R's Avatar
yes thats it.
Old 05-21-2009, 12:41 AM   #11
imbest123
Bańned
imbest123's Avatar
Alright so i have another question. when the rear main seal is removed, will another fluid leak out of there? if so what fluid? oil? i take it that whatever fluid, if any, leaks out will need a flush/change
Old 05-21-2009, 03:08 AM   #12
Axix23
Axix23's Avatar
Axix23 is an unknown quantity on c-rsx
change that SEAL!!
FORSALE: FS: ONE MINT 17x8" Gunmetal SSR Type-C-RS wheel, Black T1 Racing turbo blanket, NEW Tial 44m WG Spring(2.9psi), NEW Tial 50mm BOV 11 psi spring, NEW o2 extension, OEM RSX-S injectors with clips, pair of Digital h1 3k Hid bulbs, and NEW Gatorback 4070775 belt, PM me for prices....
Axix23 is offline   Reply With Quote
Old 05-21-2009, 09:08 PM   #13
Cb7-R
Sacked!!
Cb7-R's Avatar
Yea some oil will leak. Thats the rear mains job to prevent oil from leaking.
Reply
Bookmarks
clutch , rear main seal , replacing
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
