Burning oil? - Club RSX Message Board
Go Back   Club RSX Message Board > GENERAL RSX > Problems & Solutions RSX
Notices
Reply
Thread Tools
Old 04-29-2009, 07:25 AM   #1
SManos22
K Proed!
SManos22's Avatar
SManos22 is an unknown quantity on c-rsx
Burning oil?
i realised that when i would hit it in first vtec wouldnt hit till late and sometimes sputter and sometimes in second as well. so then i went to go check my oil and there was no oil on the dipstick! So i went to the store and bought 5 quarts of Amsoil extended life 5W-30 synthetic. when draining the oil it looked as if only 3 quarts or so came out. my cars oil was last changed about 3000k ago before i put it up for the winter last november. my cars not leaking oil anywhere and also does not smoke, so am i just burning oil that bad?
232.3whp/163.3tq
N/A All Day!
ABP Crew Member #63
SManos22 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 04-29-2009, 07:33 AM   #2
04DC5TypeS
J to the ames
04DC5TypeS's Avatar
04DC5TypeS is an unknown quantity on c-rsx
rsx's are known to burn oil, especially synthetics and when hitting vtec alot.
04 NBP Type S SOLD
07 BMW SGM 328xi
04DC5TypeS is offline   Reply With Quote
Old 04-29-2009, 07:43 AM   #3
SManos22
K Proed!
SManos22's Avatar
so burning this much oil seems to be normal? Now i was also wondering for my next oil change if i should go back to regular oil. i didnt think once u went synthetic that u could go back to regular oil.
232.3whp/163.3tq
N/A All Day!
ABP Crew Member #63
Old 04-29-2009, 08:03 AM   #4
04DC5TypeS
J to the ames
04DC5TypeS's Avatar
I don't think you should switch back to dino but from what I have read you can switch to a heavier viscosity like 0w-30 to reduce burning, especially since we are approaching summer here in NY. I'm sure there are some oil experts here that can clarify this further. There have been some threads on this before.
04 NBP Type S SOLD
07 BMW SGM 328xi
Old 04-29-2009, 10:50 AM   #5
fredboy
Member
fredboy's Avatar
fredboy is an unknown quantity on c-rsx
stick with synthetic
fredboy is offline   Reply With Quote
Old 04-29-2009, 12:52 PM   #6
gucciking
double stack?
gucciking's Avatar
gucciking is a jewel in the rough of c-rsx gucciking is a jewel in the rough of c-rsx gucciking is a jewel in the rough of c-rsx gucciking is a jewel in the rough of c-rsx gucciking is a jewel in the rough of c-rsx gucciking is a jewel in the rough of c-rsx gucciking is a jewel in the rough of c-rsx gucciking is a jewel in the rough of c-rsx
Acura Rsx Type S-laughter Your Wallet With Oil Costs.
Mine burned oil everytime I hit vtec..So the easy fix..don't hit vtec.
vtec = alot of burnt oil, and holes in your pocket.
gucciking is offline   Reply With Quote
Old 07-16-2009, 02:44 AM   #7
Girn
Master Member
Girn's Avatar
Girn is an unknown quantity on c-rsx
dont u mean 10w-30.. 0w-30 would be lower viscosity
02 type-s
Girn is offline   Reply With Quote
Old 07-16-2009, 03:14 AM   #8
svaillan
GT30R > Traction
svaillan's Avatar
svaillan is a rep WHORE
svaillan is a rep WHORE svaillan is a rep WHORE svaillan is a rep WHORE svaillan is a rep WHORE svaillan is a rep WHORE svaillan is a rep WHORE svaillan is a rep WHORE svaillan is a rep WHORE svaillan is a rep WHORE svaillan is a rep WHORE svaillan is a rep WHORE svaillan is a rep WHORE svaillan is a rep WHORE
check to make sure you're A/F is set correctly.
Workout Crew, Wind surfing crew #1 Boost Slut krew#12...My Name is Steve
[SIGPIC][/SIGPIC]
I'm so stock my valves tickFull-Race stage 2gt RSX 449WHP 313TQ @ 14 psi on 91
semper fidelis tyranosaurus Rex
svaillan is offline   Reply With Quote
Old 07-16-2009, 03:15 AM   #9
SkylineTT7
OMG DC5
SkylineTT7 is an unknown quantity on c-rsx
i also have that problem too but its normal...like every1 said k20 is a motor oil drinker soo its normal man. dont worry
Hold
On
Not
Done
Accelerating
- My Show-Off Thread: http://forums.clubrsx.com/showthread.php?t=689498
SkylineTT7 is offline   Reply With Quote
Old 07-16-2009, 08:12 AM   #10
Drewpreme
( ‾ʖ̫‾)
Drewpreme's Avatar
Drewpreme is not even half way to the top Drewpreme is not even half way to the top
Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top
Drewpreme is offline   Reply With Quote
Old 07-16-2009, 10:28 AM   #11
rensoyka
Breast inspector by appt.
rensoyka's Avatar
rensoyka is an unknown quantity on c-rsx
I think that you should check your oil at every gas fill-up and keep a record before determining that you are burning oil. using 1 quart every 3 or 4 thousand miles is acceptable. 1 quart every thousand miles is bad.
'06 black type-s.
rensoyka is offline   Reply With Quote
Old 08-07-2009, 01:45 PM   #12
n19htmare
Member
n19htmare is an unknown quantity on c-rsx
My car chugs oil... I have to add a qt ever 1000 miles or so. What could be wrong with it?
Last time i let it run 4K miles, and did oil change and only recovered not even 2 qts.
n19htmare is offline   Reply With Quote
Old 08-07-2009, 03:04 PM   #13
walk
cone head
walk's Avatar
walk is an unknown quantity on c-rsx
Mine will burn .5 to 1 qt over 6000-7000 miles if I beat on it.
Last change I babied it almost all the time (due to nearly $5/gal gas prices) and it didn't lose a drop.
I use only 10-30w full syn.
1 qt every 1000 miles? I don't know, unless you are drag racing it literally every day I don't think that's normal, I'd have it checked.
02 RSX Type S - SFR SCCA SoloII #67 ST
94 Miata - ES build in progress!
walk is offline   Reply With Quote
Old 08-07-2009, 05:35 PM   #14
rensoyka
rensoyka's Avatar
you are either leaking it somewhere or your engine needs an overhaul, bad rings, pistons or valve guides.
'06 black type-s.
Old 08-07-2009, 06:32 PM   #15
n19htmare
Member
wonderful. Anyway to tell without taking the whole thing apart?
Reply
Bookmarks
burning , oil
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
