ac doesn't blow cold air - Club RSX Message Board
Go Back   Club RSX Message Board > GENERAL RSX > Problems & Solutions RSX
Notices
Reply
Thread Tools
Old 05-09-2009, 09:26 PM   #1
ivtech2
Senior Member
ivtech2's Avatar
ivtech2 is an unknown quantity on c-rsx
i am gonna die if i have to go another summer without ac. my ac blows only hot air and the heater works fine. I tried filling the refrigerant but it's not holding pressure and still the same problem, no cold air. what do you guys think is wrong? or what should i do? PLEASE HELP
ps. i'm bringing it to the shop next week.
ivtech2 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 05-09-2009, 09:52 PM   #2
Oside_integra
Experience>KnowledgeAlone
Oside_integra's Avatar
Oside_integra is an unknown quantity on c-rsx
sounds like a leak? because the pressure isn't being held, there are dyes that you put in the ac system to find the leak but they are bad for the compressor better off taking it to a shop.
mine:
04 Rsx Type S, 91 Integra ls, 85 ae86gt, MB ml430
hers:
93 civic eg turbo
Oside_integra is offline   Reply With Quote
Old 05-09-2009, 10:01 PM   #3
ivtech2
Senior Member
ivtech2's Avatar
sorry, forgot to mention that the pressure is high but no refrigerant in it if i'm correct. i did it last year. i'll check the pressure again soon but i think its pretty high. must be a problem
Old 05-09-2009, 10:53 PM   #4
yuzuki
Member
yuzuki is a jewel in the rough of c-rsx yuzuki is a jewel in the rough of c-rsx yuzuki is a jewel in the rough of c-rsx yuzuki is a jewel in the rough of c-rsx yuzuki is a jewel in the rough of c-rsx yuzuki is a jewel in the rough of c-rsx yuzuki is a jewel in the rough of c-rsx yuzuki is a jewel in the rough of c-rsx
Hmmm that same thing happened to me but the problem was that there was a leak on the condenser. All the freon leaked out and cost me a grip of money to fix.
yuzuki is offline   Reply With Quote
Old 05-09-2009, 11:04 PM   #5
fa22raptorf22
Senior Member
fa22raptorf22's Avatar
fa22raptorf22 is an unknown quantity on c-rsx
Well if you are 100% that its leaking you will have to get that repaired.
Otherwise, if it does have the pressure, you may have an electrical panel problem...like the controls on the inside for the ac, which is a diy fix.
fa22raptorf22 is offline   Reply With Quote
Old 05-10-2009, 10:38 AM   #6
ivtech2
Senior Member
ivtech2's Avatar
what do you mean? i don't think there is aleak because i tried filling it up last night and the pressure guage is reading a really high pressure. like 8lbs. normal being 3-4. the my problem is i don't think theres much refrigerant in the system.
Old 05-10-2009, 10:43 AM   #7
l e o h j
got swirls?
l e o h j's Avatar
l e o h j is an unknown quantity on c-rsx
don't keep forcing refrigerant inside the system if the pressure gauge is reading a really high pressure it will just damage the whole system
go to a shop that specializes on air conditioning let them drain and refill your refrigerant thats what i did when i got tired of having no a/c inside my car after replacing the compressor and refilling the system myself with those damn cans
one more thing to check for is if your compressor is clicking when the a/c is on
need a detail?[L.A / O.C / I.E /SFV COUNTY] pm me for a price
DIY: BUDDYCLUB SHORT-SHIFTER INSTALL
l e o h j is offline   Reply With Quote
Old 05-10-2009, 10:56 AM   #8
ivtech2
Senior Member
ivtech2's Avatar
how can i tell if i need a new compressor? where can i buy one? easy to install?
Old 05-10-2009, 11:15 AM   #9
Angelo118
Blank Member
Angelo118 has a clean start Angelo118 has a clean start Angelo118 has a clean start Angelo118 has a clean start
At first it sounds like you may be low on refrigerant. If issues persist when recharging and you have correct amount of refrigerant clean evaporator coil. If it's clean and in good condition all I can say is it may be compressor failure.
This is not possible. I can understand have pressure and not getting cold air refrigerent in cars tend to get worn out and crappy after a while.
I think you should get a local shop or EPA certified person to discharge your system then pull it into vacuum as I would do with most central A/C house units and refill it. If no cooling persists I say look at the compressor.
2003 ABP rsx-s 11/2007-12/16/2010 rip
Resurrected: 6-11-2011 TBP RSX
Angelo118 is offline   Reply With Quote
Old 05-10-2009, 11:17 AM   #10
Angelo118
Blank Member
You will have refrigerant in the system, fans will all run but no cooling effect. You can buy a new compressor from: a part out thread, Acura dealer and around forums. Installing it is all on you.
Old 05-10-2009, 11:22 AM   #11
ivtech2
Senior Member
ivtech2's Avatar
where are the parting out threads on this site? will i have to replace dryer, o ring ect.?
Old 05-10-2009, 11:43 AM   #12
Angelo118
Blank Member
http://forums.clubrsx.com/forumdisplay.php?f=217
part out thread.
I'm not exactly sure what you would need I don't work on cars too much but understand the way all systems work. Before you buy anything or do anything very drastic check all electrical connections and so on to make sure you don't just have a loose wire or something. BTW too much refrigerant in a system can cause the compressor to slug or stop working I'd get that at proper levels first.
Old 05-10-2009, 09:55 PM   #13
l e o h j
got swirls?
l e o h j's Avatar
you can tell if u the compressor is working or not. if u have the a/c on and it should click. if not have it checked. its not really easy to replace the compressor unless you really know what your doing. you need to get the system discharged first before taking off the compressor unless you dont mind refrigerant blowing on your face when you disconnect the hoses
Old 05-11-2009, 07:20 AM   #14
Oside_integra
you could also check the resistance on the clutch coil on the compressor with an ohm meter i think its like 4 ohms of resistance.
mine:
hers:
93 civic eg turbo
Old 05-11-2009, 10:21 PM   #15
Splinter88
Desert Silver RSX-S
Splinter88's Avatar
Splinter88 is an unknown quantity on c-rsx
I have the same problem...i'll be taking my car in to a shop sometime this week. I'll let you know what the problem is when they tell me..But you might figure it out before i do. Hopefully it doesn't cost me a shit load of money lol
Injen CAi, Strup RH, ESMM, Hawk HPs front/rear, 15% tint, BC SS, Progress rear sway/tie bar, Kumho Ecsta's.
Splinter88 is offline   Reply With Quote
Old 05-11-2009, 10:24 PM   #16
BIZZYBONAPINOY
i-vtec do you?
BIZZYBONAPINOY's Avatar
BIZZYBONAPINOY is an unknown quantity on c-rsx
let us know how things goes. im looking for a answer too! mine hasnt been working also
Showoff thread/re-do thread: http://forums.clubrsx.com/showthread...1#post44070481
BIZZYBONAPINOY is offline   Reply With Quote
Old 05-12-2009, 01:36 AM   #17
ivtech2
Senior Member
ivtech2's Avatar
bump
Old 05-19-2009, 11:37 AM   #18
Splinter88
Desert Silver RSX-S
Splinter88's Avatar
Wow...you guys are going to love this lol.
Hopefully your RSX's don't have the same problems...very unlikely.
Mine needs a new evaporator core = $198, labor for that is 130$, Evacuate & Recharge A/C system - $32.95, Repair connector at A/C compressor - $36.28. Shop fees ..$21.75.
all in all its going to take 397$ to fix my A/C lol.. Sometimes i wish i was a mechanic.
Old 05-20-2009, 07:40 AM   #19
My06_types
06 TypeS
My06_types's Avatar
My06_types is a jewel in the rough of c-rsx My06_types is a jewel in the rough of c-rsx My06_types is a jewel in the rough of c-rsx My06_types is a jewel in the rough of c-rsx My06_types is a jewel in the rough of c-rsx My06_types is a jewel in the rough of c-rsx My06_types is a jewel in the rough of c-rsx My06_types is a jewel in the rough of c-rsx
I also had the problem that my car wouldnt blow cold air when the ac was on. Its an 06 so i took it to the dealer and they had toreplace an o ring on the condensor that went bad and now it works fine so it could be something as small as an o ring
ASM W/White stockies Showoff::
http://forums.clubrsx.com/showthread...9947:thumbsup:
Build thread::
http://forums.clubrsx.com/showthread.php?t=706345
My06_types is offline   Reply With Quote
Old 05-20-2009, 08:03 AM   #20
con5tant
lettuce be cereal
con5tant's Avatar
con5tant is a jewel in the rough of c-rsx con5tant is a jewel in the rough of c-rsx con5tant is a jewel in the rough of c-rsx con5tant is a jewel in the rough of c-rsx con5tant is a jewel in the rough of c-rsx con5tant is a jewel in the rough of c-rsx con5tant is a jewel in the rough of c-rsx con5tant is a jewel in the rough of c-rsx con5tant is a jewel in the rough of c-rsx
check the fuse?
con5tant is offline   Reply With Quote
Old 05-20-2009, 12:59 PM   #21
M_nus
M_nus's Avatar
M_nus is an unknown quantity on c-rsx
I had the same problem and needed a new condensor fan. But my problem seems different. I knew it was the fan because when it tried to turn on, the engine would just stutter and my RPMs would drop as if the car had trouble idling. $400 repair. But now it's colder than ever.
M_nus is offline   Reply With Quote
Old 05-22-2009, 02:43 AM   #22
dc5itr888
Senior Member
dc5itr888 is an unknown quantity on c-rsx
im having the same EXACT problem...
Ive been told that the condenser needs to be replaced...
dc5itr888 is offline   Reply With Quote
Old 05-22-2009, 05:53 AM   #23
Saig3n
Member
Saig3n is an unknown quantity on c-rsx
I also have the same issue with the A/C. System pressure is high and no cold air. I'l check to see if i need to replace anything.
Saig3n is offline   Reply With Quote
Old 05-22-2009, 07:15 AM   #24
Mr.Gameovr
New Member
Mr.Gameovr is a jewel in the rough of c-rsx Mr.Gameovr is a jewel in the rough of c-rsx Mr.Gameovr is a jewel in the rough of c-rsx Mr.Gameovr is a jewel in the rough of c-rsx Mr.Gameovr is a jewel in the rough of c-rsx Mr.Gameovr is a jewel in the rough of c-rsx Mr.Gameovr is a jewel in the rough of c-rsx Mr.Gameovr is a jewel in the rough of c-rsx
My problem is a little different......My A/C only blows cold when my foot is on the gas, once i come to a stop it goes back hot! it's really pissing me off can ayone help?
Mr.Gameovr is offline   Reply With Quote
Old 07-03-2009, 06:37 PM   #25
Conan O'Brien
Conan O'Brien's Avatar
Conan O'Brien is an unknown quantity on c-rsx
same problem and apparently i need an entire new fucking AC. the compressor locked up because of something to do with the oil not moving through the system properly. what the fuck. dude said it's going to cost $1300. lol.
2008 Acura TL Type-S
2005 Honda S2000-RIP
2004 Acura TL - Sold
2003 Acura RSX- RIP
Conan O'Brien is offline   Reply With Quote
Reply
Bookmarks
air , blow , cold
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
