Help! 6 Cels: p0301, p0302, p0303, p0304, p0300, p0341 - Club RSX Message Board
Go Back   Club RSX Message Board > GENERAL > Problems & Solutions
Reply
Thread Tools
Old 05-31-2009, 10:55 PM   #1
b18cek
Senior Member
b18cek's Avatar
P0300 Random Misfire
P0301 No. 1 Cylinder Misfire
P0302 No. 2 Cylinder Misfire
P0303 No. 3 Cylinder Misfire
P0304 No. 4 Cylinder Misfire
P0341 Camshaft Position (CMP) Sensor
My car ran perfect yesterday, and now I have all these codes and it runs like shit!
The car stalls and studders at low RPM and eventually shuts off. I can turn it on but I have to apply the gas.
Is it likely to just be the Camshaft position sensor? If so, how do I know which one to replace since I believe there are (2)?
Any insight is appreciated..
Thanks!
b18cek is offline   Reply With Quote
Sponsored Links
Advertisement
Old 05-31-2009, 10:57 PM   #2
SHOGUNN
Master Member
SHOGUNN's Avatar
pwnd
Mag Tuned
SHOGUNN is offline   Reply With Quote
Old 06-01-2009, 05:28 AM   #3
rensoyka
Breast inspector by appt.
rensoyka's Avatar
most likely cause is the timing chain has jumped. don't run the car until it gets checked over.
'06 black type-s.
rensoyka is offline   Reply With Quote
Old 06-01-2009, 08:33 AM   #4
b18cek
Senior Member
b18cek's Avatar
How would the timing chain randomly jump? I called Acura and they said that the engine will misfire if the camshaft sensor is faulty. So I just ordered a new one of those, which wont be in until tmr
Old 06-01-2009, 09:52 PM   #5
b18cek
Senior Member
b18cek's Avatar
any more suggestions???
Old 06-01-2009, 10:49 PM   #6
soltarius2000
Member
Do a compression test
soltarius2000 is offline   Reply With Quote
Old 03-28-2011, 12:53 AM   #7
Rhd_rick
New Member
I know this posting is kinda old but Friday I had these check engines lights go off then I reset them then today I went for a Lil cruise and they went off again but car runs fine trying to wonder if u ever got ur problem fixed
Rhd_rick is offline   Reply With Quote
Old 04-04-2011, 09:35 AM   #8
b18cek
Senior Member
b18cek's Avatar
timing chain was stretched!
Old 04-04-2011, 12:19 PM   #9
Rhd_rick
New Member
Wat would cause tat .........also I pump 91 all the time this problem occurred Saturday night again when I pumped 87 by accident
Old 04-04-2011, 12:27 PM   #10
rensoyka
rensoyka's Avatar
well if you have a type-s it doesn't like 87 gas so you may get some mis-fire codes. fill it up with premium when it gets down a bit
'06 black type-s.
Old 04-04-2011, 01:17 PM   #11
Rhd_rick
New Member
Yea tought so it's a base model rsx with z3 I always pump 91 but i was coming outta speed zone around 12am and was tired so I pressed 87 instead same problem last time my buddy drove it home 4 me and he pumped gas and came with flashing cel and I asked him and he said he pumped 91 ........bs........any ways thaxx for the help I'm new to k series I get the basics but all this other stuff is confusing not ur avrage b20 b18 b16 haha or even d16 d15 swap where the problem is always the dizzy
Old 04-04-2011, 01:27 PM   #12
rensoyka
rensoyka's Avatar
could have been shitty old gas or maybe had some water or other crap in it, especially from some of the lesser brand gas stations.
'06 black type-s.
Old 04-04-2011, 01:40 PM   #13
Rhd_rick
New Member
It was 76 gas I usually use chevron
Old 04-04-2011, 02:43 PM   #14
Cb7-R
Sacked!!
Cb7-R's Avatar
Originally Posted by SHOGUNN View Post
pwnd
This was funny.
Gee thanks for the update, it only took 2 years....
Originally Posted by F-BOM View Post
beat the shit out of your brother then sue him
Cb7-R is offline   Reply With Quote
Old 04-04-2011, 02:56 PM   #15
Rhd_rick
New Member
Originally Posted by Cb7-R View Post
This was funny.
At least know u know wats up
Old 04-05-2011, 01:57 AM   #16
Mr. Type RR
Member
Mr. Type RR's Avatar
holy shit run 93 ur ruining ur motor, injectors the hole 9 its tune on 93. don;t be cheap wit gas ull fuck it up it ain;t worth the pennies ur saving
Mr. Type RR is offline   Reply With Quote
Old 04-05-2011, 10:59 AM   #17
Rhd_rick
New Member
I. Wasn't being cheap normally the buttons are aligned 87 89 91 for some reason at this pump they were 91 89 87 so I always just hit the last button also keep in mind tat I never pump at this gas station I was just in tat area ..........but believe me the last thing I wanna do is pump apple juice (87) into my z3 motor
Old 04-26-2011, 12:44 PM   #18
koryo hawnkie
New Member
Quick question if someone can help. I'm getting my head gasket replace along with the water pump. I'm also gonna go ahead and replace the timing chain and tensioner with a toda heavy duty chain and tensioner. The chain has not broken or has not stretched or jumped any but my question is should I replace the sprocket/gears that turn the timing chain since I'm replacing the timing chain? I have. 2002 rsx s with around 180,000.... thanks
koryo hawnkie is offline   Reply With Quote
Old 04-26-2011, 12:51 PM   #19
akaveli
I Alwayz Haz Ava Hottiez
akaveli's Avatar
@ apple juice
Injen \ CRSX \ Megan \ Avid \ Skunk2 \ RBC \ Hondata \ Progress \ Mag-Tuned \
Boost coming soon
akaveli is offline   Reply With Quote
Old 04-26-2011, 12:54 PM   #20
2010 admin
Administrator
2010 admin has disabled reputation
Sprockets are way harder than the chain. Doubtful you would need to replace it unless there was some obvious damage or something.
2010 admin is offline   Reply With Quote
Old 04-26-2011, 02:20 PM   #21
koryo hawnkie
New Member
Ok awesome! Thanks Erik for the info
Reply
Bookmarks
cels, p0300, p0301, p0302, p0303, p0304, p0341
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © 2001-2012, Club RSX, Inc. All rights reserved worldwide.
