#551 |
Boost Slut Krew Member #1
Nice. Hit me up when you get there. You gonna be in the show or are you gonna race?
11.79 @ 120MPH - Bandimere Speedway, CO SuperFlow Dyno Tuned - 91 - 440whp 330wtq @ 18lbs - Thanks Brian! ![]() DynaPack Dyno Tuned - 91 - 525whp 340wtq ![]() My In-Depth Build Threads:http://forums.clubrsx.com/showthread.php?t=674689 |
#552 |
Sir Luscious Left Foot
No/No but I'll hit you up.
Full-Race GT3076R DynaPack 510whp 399tq 13lbs 91 550whp 410tq 18lbs 116 SOLD 96 Subaru Outback Sale pending 99 Range Rover 4.6 V8 HSE Loaded |
#553 | |
CLUBRSX Supporter
2006 ASM RSX Type S q/_ \p/Oo.\\_. A ._//.oO\ \_o__|R S X|__o_/ |
#555 |
#556 |
Internet Crack Dealer
let me know, I will come up and pick it up.
Chris Dye Club RSX, Inc. chris@clubrsx.com http://www.clubrsx.com | http://www.clubep3.com | http://www.k-series.com All Motor Crew Sensei (aka member #13) |
#557 |
Senior Member
#558 |
Just got back from the track. I'll post vids and pics up in a little while.
#559 |
Story of my trip to the track tonight:
http://forums.clubrsx.com/showpost.p...4&postcount=38 There were actually two other rsxs there tonight I hadn't seen before. One was another ABP that I ran against on my 2nd pass. The other was a black one, the dude tried to do a burnout on street tires. Video of my third pass, right after this pass my battery shit on me and I wasn't able to run the remainder of the night unfortunately. Very pleased with it for only 3 passes. Definitely feel like I can shave another couple tenths off the time too. I had the boost turned down about 3 psi on these passes and my 60' times could be improved. http://videos.streetfire.net/video/T...New_707891.htm
11.79 @ 120MPH - Bandimere Speedway, CO SuperFlow Dyno Tuned - 91 - 440whp 330wtq @ 18lbs - Thanks Brian! ![]() DynaPack Dyno Tuned - 91 - 525whp 340wtq ![]() My In-Depth Build Threads:http://forums.clubrsx.com/showthread.php?t=674689 Last edited by WooTIHaveATypeS; 09-17-2009 at 05:04 AM. |
#561 | |
T67 oh my
remember at 11.49 you need a roll bar and new seat belts Last edited by fearRSXenigma; 09-17-2009 at 10:48 AM. |
#562 | |
CLUBRSX Supporter
What are you going to do about the battery? Maybe you could do what Kevin did with his car and put the battery in the front right with Brian's battery tray.
#563 | ||
I think for the battery I'm gonna get a new one in the next couple days, mount it in the back so I can go to Bandimere on Sunday and stuff. And then in a couple weeks I'll probably tear out the interior, undo the wiring and wire it over to the passenger side wheel area and hit up Chris for a tray.
#564 | |
CLUBRSX Supporter
Good luck on Sunday when you go back to the track. Hopefully you can get some better times with the boost upped to 19 psi.
#565 |
CLUBRSX Supporter
Hey Chris, can you guys possibly bend exhaust piping at the shop? My B-Pipe on my exhaust will sometimes bang against the frame of the car and I wanted to get it bent out of the way so it stops that problem. I was thinking about hammering the frame in a little bit but didn't want to go the cheap route. If it's possible how much do you think it will cost me? Thanks.
#566 |
I do, can you email me a pic?
#567 | |
#568 | |
#569 |
Having a working trans and working launch control makes a huge difference. I was also slipping the clutch a bit when I launched which also helped with consistancy.
#570 |
I bet the gears ratio's helped a lot too, having the longer first gear will help you use more boost
#572 | |
OoooOOoo a red ball
#573 | |
![]() Just slightly, so the slicks won't slip and the car doesn't bog out. You even told me to try slipping it slightly when we were at the track last year, cause I was being rtard and just dropping the clutch.
#574 | |
OoooOOoo a red ball
#575 |
Lol. I suppose that's true. But even with the launch control working, dropping the clutch it wants to break loose. I think I need to find a happy medium.
| Bookmarks |
| Tags |
| colorado, make, wanted |
| Thread Tools | |
