DIY - Valve Clearance Adjust (K20A2/A3) - Club RSX Message Board
Notices
Reply
Thread Tools
Old 06-08-2009, 04:18 AM   #1
Chrisb27
Registered User
Chrisb27 is a jewel in the rough of c-rsx Chrisb27 is a jewel in the rough of c-rsx Chrisb27 is a jewel in the rough of c-rsx Chrisb27 is a jewel in the rough of c-rsx Chrisb27 is a jewel in the rough of c-rsx Chrisb27 is a jewel in the rough of c-rsx Chrisb27 is a jewel in the rough of c-rsx Chrisb27 is a jewel in the rough of c-rsx
Didn't find that anyone else had done a DIY for this yet so I figured I'd join up and add this. I did the adjust a while ago and I thought i had more pics but I'll work with what I have - I borrowed some screen shots from the FSM for clarity (My first DIY so be kind).
Maintenance Time!
Parts / Tools
  1. Valve Cover Gasket
  2. Gasket Material
  3. 10MM Socket
  4. 12MM Socket
  5. 3/4" Socket
  6. Long 1/2" Extension + Ratchet (Rotating Engine)
  7. Spark Plug Socket + 3/8" Extension
  8. Feeler Guage
Valve Adjust - Mine is a K20A3 but the specs are just a bit different for the A2 and there's a few more of em to check. This should be checked with the engine cold as well.
  • Step 1 - Jack up the car and put it on jack stands. Remove the front driver side wheel so you can access the port to the crank bolt to roll the engine over manually to hit TDC for each cylinder.
  • Step 2 - Remove the intake cover and the spark plug cover.
  • Step 3 - Next disconnect the plugs for the coils and pull the spark plugs - I'm not sure if it's required but I labeled each one as I took it out to make sure it went back in the same place.
    You should end up with something looking about like this.
  • Step 4 - Now comes the fun! Remove the valve cover and set it aside.
    All opened up.
  • Step 5 - Now it's time to rotate the engine to get to TDC on the #1 Cylinder. Below is the location of the cylinders facing the front of the engine as well as the adjuster screw locations.
    TDC on the #1 Cylinder is setup by lining up the marks on the VTC actuator and the exhaust cam gear (C) and verify that both B and A are as they are shown.
  • Step 6 - With Cylinder #1 where it is you can now break out the feeler gauge - (I found the Craftsman angled one made life a whole lot easier).
    You should insert the feeler gauge between the top of the valve and the adjusting screw on the intake and exhaust valves.
    To get the correct size, start with one that is in the middle of spec and move up or down accordingly. You should feel slight drag on the gauge when moving it around, not too much and not to loose. If it is out of the listed spec than break the nut loose and tight or loosen as necessary and re-check your clearance.
  • Step 7 - Move on to Cylinder #3 by rotating the crank 180 degrees clockwise and verify the marks are as follows.
  • Step 8 - Move on to Cylinder #4 by rotating the crank 180 degrees clockwise and verify the marks are as follows.
  • Step 8 - Move on to Cylinder #2 by rotating the crank 180 degrees clockwise and verify the marks are as follows.
  • Step 9 - Now that your done you can slap everything back together - BE SURE to put the gasket material in the locations show below or otherwise it will leak - ask me how I know. Then tighten in the order show below as well.
All done!
Criticism / Suggestions wanted. I have gotten alot of info from this forum over the past 2 years, figured it was time to give a wee bit back
Chrisb27 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 06-08-2009, 04:00 PM   #2
d4nvu
k20a3 > *
d4nvu is an unknown quantity on c-rsx
another way to turn the crank is to jack the car up on the passenger side and put the car in fourth gear and just rotate the rim clockwise. that way you dont have to bother with taking off the rim. and it is good remove the spark plug so there's less compression and its easier to spin, just make sure nothing goes down there. good guide though
d4nvu is offline   Reply With Quote
Old 06-08-2009, 09:02 PM   #3
a2_dc5
Brevit : the soul of wit
a2_dc5's Avatar
a2_dc5 is a rep WHORE
a2_dc5 is a rep WHORE a2_dc5 is a rep WHORE a2_dc5 is a rep WHORE a2_dc5 is a rep WHORE a2_dc5 is a rep WHORE a2_dc5 is a rep WHORE a2_dc5 is a rep WHORE a2_dc5 is a rep WHORE a2_dc5 is a rep WHORE a2_dc5 is a rep WHORE a2_dc5 is a rep WHORE a2_dc5 is a rep WHORE a2_dc5 is a rep WHORE a2_dc5 is a rep WHORE
very nice man
damn 100k hu? how she run?
Armenian crsx crew member #2
a2_dc5 is offline   Reply With Quote
Old 06-08-2009, 09:10 PM   #4
inmydream316
Kevin★05 DC5-S
inmydream316's Avatar
inmydream316 is an unknown quantity on c-rsx
subscribed!!
13 Subaru BRZ 1/17/13
97 Mazda Miata M Edition - SOLD 7/23/12
05 NBP RSX-S - SOLD 10/9/10
Visit my blog for DC5
inmydream316 is offline   Reply With Quote
Old 06-08-2009, 10:44 PM   #5
Chrisb27
Registered User
Originally Posted by a2_dc5 View Post
very nice man
I did this a few months back - I'm sitting at 118k right now - she still runs like a top.
Old 06-18-2009, 04:43 PM   #6
suiteddc5
Registered User
suiteddc5's Avatar
suiteddc5 is an unknown quantity on c-rsx
Originally Posted by inmydream316 View Post
subscribed!!
dido!
suiteddc5 is offline   Reply With Quote
Old 06-18-2009, 06:21 PM   #7
D Fabulous
Master Member
D Fabulous's Avatar
D Fabulous is an unknown quantity on c-rsx
i'm doing this, this weekend thanks!
First Car - 02 NBP RSX 5 spd SOLD - INGS +1 Bodykit, AEM CAI, CTRH, DCTCS, ESMM, Revo S.S., Tein S-Techs, 17"5ZR Hyper Black Corpse
Summer Car - 03 PWP RSX-S - EVERYTHING FORSALE http://forums.clubrsx.com/showthread.php?t=714704: KPRO Street Tuned, 60A Billet MM, Injen CAI, RBC IM, Hondata IMG, CTRH, Greddy Ti-C Turbo, Revo S.S., Tein S-Techs, DIY Ground Wires, Black Projectors, Red Taillights, Mugen Rad Cap, Spoon Drainbolts, Potenza Re-11 225/50/16,..http://www.youtube.com/watch?v=aDOHA0ijsmQ Best:13.9 w/out RBC.
D Fabulous is offline   Reply With Quote
Old 04-11-2010, 11:16 PM   #8
wariospeed
Who's dat Mex?
wariospeed's Avatar
wariospeed is a jewel in the rough of c-rsx wariospeed is a jewel in the rough of c-rsx wariospeed is a jewel in the rough of c-rsx wariospeed is a jewel in the rough of c-rsx wariospeed is a jewel in the rough of c-rsx wariospeed is a jewel in the rough of c-rsx wariospeed is a jewel in the rough of c-rsx wariospeed is a jewel in the rough of c-rsx
is it true that you have to do this when the car isn't warm or hot????? i wanna do it but i would have to drive to the hobby shop and do it there......thanks alot ...
2002 DSM type-s."maybe not today,maybe not tomorrow, but someday!
wariospeed is offline   Reply With Quote
Old 04-12-2010, 08:24 AM   #9
Drewpreme
( ‾ʖ̫‾)
Drewpreme's Avatar
Drewpreme is not even half way to the top Drewpreme is not even half way to the top
Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top
yes, car needs to be completely cooled down so that the measurements are not skewed by the hot expanded metal.
Drewpreme is offline   Reply With Quote
Old 04-12-2010, 08:45 AM   #10
rsxman09
Member
rsxman09's Avatar
rsxman09 is a jewel in the rough of c-rsx rsxman09 is a jewel in the rough of c-rsx rsxman09 is a jewel in the rough of c-rsx rsxman09 is a jewel in the rough of c-rsx rsxman09 is a jewel in the rough of c-rsx rsxman09 is a jewel in the rough of c-rsx rsxman09 is a jewel in the rough of c-rsx rsxman09 is a jewel in the rough of c-rsx
good job man!
rsxman09 is offline   Reply With Quote
Old 04-14-2010, 09:34 PM   #11
BigpapasRSX
SSM crew
BigpapasRSX's Avatar
BigpapasRSX is an unknown quantity on c-rsx
What size are the valve nuts on the K20A3?Are the intake and exhaust nuts the same size ?
BigpapasRSX is offline   Reply With Quote
Old 04-14-2010, 09:37 PM   #12
TheTempest
Olivia Munn :love:
TheTempest's Avatar
TheTempest is a jewel in the rough of c-rsx TheTempest is a jewel in the rough of c-rsx TheTempest is a jewel in the rough of c-rsx TheTempest is a jewel in the rough of c-rsx TheTempest is a jewel in the rough of c-rsx TheTempest is a jewel in the rough of c-rsx TheTempest is a jewel in the rough of c-rsx TheTempest is a jewel in the rough of c-rsx
don't know the size, maybe 10?
and the intake and exhaust are the same
professional DIYer
02 WRX
TheTempest is offline   Reply With Quote
Old 04-14-2010, 09:39 PM   #13
imbest123
Bańned
imbest123's Avatar
imbest123 is an unknown quantity on c-rsx
theres also this one: http://www.vtec.net/articles/view-ar...icle_id=143824
Wheel gap can be compared to a vagina. The more fingers you can stick in the worse off you are
Don't PM me. I don't give a fuck about who you are and no, I don't have nudes
imbest123 is offline   Reply With Quote
Old 04-14-2010, 10:00 PM   #14
BigpapasRSX
SSM crew
I know its 10mm for the K20A2.But is it the same size for the K20A3?I have been searching on here and it does not say in the Helms.I am buying the valve tool for the job,but not shore what size to buy
Old 04-16-2010, 04:16 AM   #15
BigpapasRSX
SSM crew
No SAY?
Old 04-16-2010, 10:45 AM   #16
Drewpreme
( ‾ʖ̫‾)
Drewpreme's Avatar
the adjusting nut on the a3 and a2 are the same size.
Old 05-09-2010, 02:36 PM   #17
fkn_fast
Member
fkn_fast's Avatar
fkn_fast has been a little shit in the past
I need to do this. Just hit 100k. I have put on my coilovers,intake,exhaust,ect. I change my oil and all that too. Just wondering would this be something I could do myself. Just dont wanna get in over my head. Seems like its not to hard, just worried since its my only car.ha
fkn_fast is offline   Reply With Quote
Old 05-23-2010, 12:36 AM   #18
UNC_xL
Senior Member
UNC_xL's Avatar
UNC_xL is a jewel in the rough of c-rsx UNC_xL is a jewel in the rough of c-rsx UNC_xL is a jewel in the rough of c-rsx UNC_xL is a jewel in the rough of c-rsx UNC_xL is a jewel in the rough of c-rsx UNC_xL is a jewel in the rough of c-rsx UNC_xL is a jewel in the rough of c-rsx UNC_xL is a jewel in the rough of c-rsx
my car is making a ticking noise from the engine. does it need a valve adjustment? i plan on doing this to see if it'll quite down. just changed the oil and tranny fluid today. how quick should i address this? is it a 'fix-it-now' fix or can i go for another week? i've been hearing this for a little while now but thought it was normal. after reading this and listening to some clips on youtube, i'm not so sure anymore.
UNC_xL is offline   Reply With Quote
Old 05-23-2010, 07:08 AM   #19
josolanes
Master Member
josolanes's Avatar
josolanes might be well recognized one day on c-rsx josolanes might be well recognized one day on c-rsx josolanes might be well recognized one day on c-rsx josolanes might be well recognized one day on c-rsx josolanes might be well recognized one day on c-rsx josolanes might be well recognized one day on c-rsx josolanes might be well recognized one day on c-rsx josolanes might be well recognized one day on c-rsx
hmm i may try this soon on my car. 135k miles on it and i *think* i'm getting comfortable enough to do this
FS: K24A2/PPG 2002 ABP RSX-S with 136k Miles
Current - 2002 ABP RSX-S | RIP - 2003 DSM Base RSX
josolanes is online now   Reply With Quote
Old 05-31-2010, 11:31 PM   #20
texm3x
Master Member
texm3x's Avatar
texm3x might be well recognized one day on c-rsx texm3x might be well recognized one day on c-rsx texm3x might be well recognized one day on c-rsx texm3x might be well recognized one day on c-rsx texm3x might be well recognized one day on c-rsx texm3x might be well recognized one day on c-rsx texm3x might be well recognized one day on c-rsx texm3x might be well recognized one day on c-rsx
nice
Originally Posted by txfg2si View Post
So I had a tripped out dream that I was cruising with texmex in a old white car and for some reason we were falling from the sky lol so I grabbed the car phone to call 911 head off towards the sand dunes and of course Texmex was like you hungry?.....and I woke up lol
you still dreaming about my chorizo ??
texm3x is offline   Reply With Quote
Old 06-04-2010, 10:33 PM   #21
matrix22
CHEAP TRACKDAYS WANTED
matrix22's Avatar
matrix22 has been a little shit in the past
nice job!
matrix22 is offline   Reply With Quote
Old 06-15-2010, 11:45 AM   #22
nyc rsx outlaw
gotta go!!!!
nyc rsx outlaw's Avatar
nyc rsx outlaw is an unknown quantity on c-rsx
nice!!! im gonna do this
2004 nhbp type s- sold... i do miss it
2006 magnetic black.... oh yeah im driftin now
nyc rsx outlaw is offline   Reply With Quote
Old 06-19-2010, 05:47 PM   #23
kwasley
Senior Member
kwasley's Avatar
kwasley is an unknown quantity on c-rsx
how do you turn the crank?
i didnt see it in the instructions.
thx in advance
kwasley is offline   Reply With Quote
Old 06-23-2010, 08:04 AM   #24
DJGypsy
Ewok Taxidermist
DJGypsy's Avatar
DJGypsy is an unknown quantity on c-rsx
thx in advance
see below
Originally Posted by Chrisb27 View Post
[*] Step 1 - Jack up the car and put it on jack stands. Remove the front driver side wheel so you can access the port to the crank bolt to roll the engine over manually to hit TDC for each cylinder.
as you can see OP listed it in his post. only thing is, the crank pulley is on the PASSENGER side of the car...i would remove the passenger wheel to access the crank bolt port.
Originally Posted by jhon martan View Post
unless you have a Boss 302 or a 289 HP with solid lifters, you have hydraulics that never need adjusting.
^^^ why are you posting? you add nothing to the thread.
-Dan
Showoff Thread updated 9/12/2010
motorcycle crew #27
DJGypsy is offline   Reply With Quote
Old 07-25-2010, 08:02 PM   #25
hitokirikenshin
TROOF!
hitokirikenshin's Avatar
hitokirikenshin is a jewel in the rough of c-rsx hitokirikenshin is a jewel in the rough of c-rsx hitokirikenshin is a jewel in the rough of c-rsx hitokirikenshin is a jewel in the rough of c-rsx hitokirikenshin is a jewel in the rough of c-rsx hitokirikenshin is a jewel in the rough of c-rsx hitokirikenshin is a jewel in the rough of c-rsx hitokirikenshin is a jewel in the rough of c-rsx hitokirikenshin is a jewel in the rough of c-rsx
What exactly am I looking at for the diagram where the liquid gasket spots are supposed to go?
hitokirikenshin is offline   Reply With Quote
Reply
Bookmarks
adjust , clearance , diy , k20a2 or a3 , valve
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
