Old 06-17-2009, 07:41 PM   #1
rictrd
DC5 R
rictrd's Avatar
Fluid with LSD
For the guys who do autox/track and are using clutch type or plate type LSD what transmission fuild are you using?
rictrd is offline   Reply With Quote
Old 06-17-2009, 07:47 PM   #2
KazeSpec
KneeDragger in Training
KazeSpec's Avatar
i'm only using a gear type but Jeff (Kiwi) uses Kaaz mixed with Castrol.
Special Projects Motorsports, Pro-Car Innovations, Innovative Mounts, Amsoil, Blueprint Racing, AIT Racing, BuddyClub, LF.com
click: INfamoUS, All Motor Crew#14, Motorcycle Crew #37
need Spy sunglasses? PM me. Hardrace/PCI bushings PM me
KazeSpec is offline   Reply With Quote
Old 06-17-2009, 08:00 PM   #3
Bluewind
Bluewind's Avatar
75W-90 or 80W-90 are fine. Typically use Neo Syn. or Redline. Different fluids yield different results based on their formulas with friction modifiers.
Videos
Bluewind is offline   Reply With Quote
Old 06-29-2009, 05:46 AM   #4
SkylineTT7
OMG DC5
SkylineTT7's Avatar
wut kind of lsd do u guys have?
Hold
On
Not
Done
Accelerating
- My Show-Off Thread: http://forums.clubrsx.com/showthread.php?t=689498
SkylineTT7 is offline   Reply With Quote
Old 06-29-2009, 11:35 AM   #5
Temptazn_Mark
www.MarkLinRacing.com
Temptazn_Mark's Avatar
I have a Quaife.. it's ok but not great.
I would like to move to an OS Giken. Oil, I'm just using Redline MTL. Does different thickness or friction modifiers affect how/when the clutch type LSD lock or something?
Temptazn_Mark is online now   Reply With Quote
Old 06-29-2009, 11:55 AM   #6
Bluewind
Bluewind's Avatar
vv
Videos
Old 06-29-2009, 12:31 PM   #7
Temptazn_Mark
vv
lol yes, I saw that post but I was looking for a more detailed answer.
AKA like synchromesh some how is too slippery for clutch type and has delayed locking and LSD locks harder and doesn't work as smooth or something.
(dunno if what I said above is true, just made shit up as an example)
Old 06-29-2009, 12:56 PM   #8
coredump
Double D Garage
coredump's Avatar
i have factory itr lsd and i just run honda oem mtf. i was taught that transmissions require certain oem additivies that may not be found in aftermarket mtf so i just stuck with oem honda mtf.
coredump is offline   Reply With Quote
Old 06-29-2009, 01:39 PM   #9
Todd
Master Member
Todd's Avatar
Todd is an unknown quantity on c-rsx
I now believe that OEM or GM Synchromesh are the only two you should use.
Redline flat out did not work for me on the track. It worked fine for street use.
see http://forums.clubrsx.com/showthread.php?t=648342
That which you manifest is before you.
Todd is offline   Reply With Quote
Old 06-29-2009, 03:47 PM   #10
jmercado567
Master Member
jmercado567's Avatar
I was about to open the same thriead...
I have the ATS D20 LSD. It has 20 discs. This thing is freaking smooth. I finally know what LSD shatter sounds like...
The feeling is very different and the lsd is very quick. I like how it is softer on the drivetrain when accelerating and decelerating.
For now Im using Royal Purple 90 which claims to contain LSD lubricant. I only have like 3 miles on this thing... will review later.
Still looking for info on experienced LSD clutch type.
Tankless Crew #1 | TS Crew #1
TwinScrew Supercharged K20z1 374whp 265wtq 16psi http://forums.clubrsx.com/showthread.php?t=626669
Need Aftercooler? http://forums.clubrsx.com/showthread...9#post27958319
jmercado567 is offline   Reply With Quote
Old 06-29-2009, 04:58 PM   #11
izerosll
www.r8cergirlclothing.com
I run Kaaz Fluid with my Kaaz LSD. It seems to do the trick.
I track the car monthly in Time Trials and change the fluid after ever 2nd oil change or every 2 events. Which ever comes first.
Mando
"02" championship white RSX type S
Armando ~n~ Audra
izerosll is offline   Reply With Quote
Old 06-29-2009, 07:13 PM   #12
Bluewind
Bluewind's Avatar
Todd and Coredump, we're talking about Clutch type slips not helical.
jmercado567, I've the same lsd. I recommend Redline or Neo. I've tested Redline, Neo Synthetic, and ATS's own fluid. They all felt about the same, though I prefer Neo Syn based on availability, cost, and performance. They have two types, go with the cheaper. At our level we don't need the super heavy duty stuff. Haha, "smooth"? Clacking around a parking lot isn't my idea of smooth, haha.
Videos
Old 06-29-2009, 08:08 PM   #13
majinbatusaix
sneaker sl00t
majinbatusaix's Avatar
majinbatusaix is cool, not as cool as some thoughmajinbatusaix is cool, not as cool as some thoughmajinbatusaix is cool, not as cool as some thoughmajinbatusaix is cool, not as cool as some thoughmajinbatusaix is cool, not as cool as some thoughmajinbatusaix is cool, not as cool as some thoughmajinbatusaix is cool, not as cool as some thoughmajinbatusaix is cool, not as cool as some thoughmajinbatusaix is cool, not as cool as some thoughmajinbatusaix is cool, not as cool as some thoughmajinbatusaix is cool, not as cool as some though
i plan to run Kaaz fluid after i install my J's racing LSD, but definitely Castrol for the break in period.
Ray at Kaaz is very helpful, he adjusted the clutch plates so i dont get too much chatter as I daily my car free of charge and also answered all the questions that i had
damn 20 discs thats crazy, i forgot how many my J's racing has, but its at most half of that
titanium exhaust crew #1
majinbatusaix is offline   Reply With Quote
Old 06-29-2009, 11:23 PM   #14
jmercado567
Master Member
Hey bluewind, cool. your right the clacking scares people and I dont have to let them know Im comming.. ha ha.
The smoothness I speak of is that when compared to gear lsd there is that slight initial glide to grip. I love that feel.
also if you roll to a turn while decelerating the claking can somewhat be avoided.
This thing is just pure excitement. turn accelerate, lock and go! not stupid wheel spin... especially with the power I am running.
What is the difference you find with the other fluids?
Old 06-30-2009, 03:38 AM   #15
Temptazn_Mark
I might be getting a Super Lock OS Giken.. let you guys know how that is compared to my Quaife..
Old 06-30-2009, 07:17 AM   #16
rsxtypes0818
DC5 Krew
rsxtypes0818's Avatar
gm syncormesh what i run but i am runing a quaife
Dc5ing it in vero beach. representing the K20 Krew. 225Whp 167tq tuned by B.R.I.A.N
rsxtypes0818 is offline   Reply With Quote
Old 06-30-2009, 12:20 PM   #17
majinbatusaix
sneaker sl00t
are both you guys running your lsd's on 100% lock??
Old 06-30-2009, 12:27 PM   #18
Bluewind
Bluewind's Avatar
Either it's at that quality level of oil, or the limited level at which I was driving, but I couldn't feel a noticable difference between the 3. I go with Neo Syn or Redline based on the mentioned above reasons of affordability, availability, and performance. ATS is just far too expensive and hard to source. In the end it's one's user preferences. Experiment and find if you can feel a difference and use whichever works best for you. It's all good fun!
Videos
Old 06-30-2009, 12:44 PM   #19
KazeSpec
KazeSpec's Avatar
if you do get the OS Giken, give me the Quaife...
Old 06-30-2009, 01:05 PM   #20
Temptazn_Mark
Sure, I'll sell it to you for good price, I'll let you know.
Old 07-01-2009, 03:19 PM   #21
coredump
Double D Garage
coredump's Avatar
for those who are running clutch based lsd, are you guys dailying your cars?
Old 07-02-2009, 01:37 AM   #22
Bluewind
Bluewind's Avatar
Yea.
It sounds horrible and isn't comfortable, but it's not detrimental.
Videos
Old 07-02-2009, 02:55 PM   #23
majinbatusaix
sneaker sl00t
for those who plan to daily a 1.5 way clutch i would recommend adjusting the plates to lock at 60% rather than 100% it should make daily driving much more bearable/comfortable and reduce the chatter sound/noises significantly, and maybe also prolong the intervals of rebuilds.
Old 07-02-2009, 03:02 PM   #24
coredump
Double D Garage
coredump's Avatar
Yea.
Describe? Why would it be uncomfortable?
Old 07-02-2009, 03:15 PM   #25
majinbatusaix
sneaker sl00t
from what ive heard especially on turns at low speeds (eg. navigating through a parking lot at a grocery store) you get loud chatter sounds coming from the tranny, similar to the symptoms of a torn cv boot
Reply
Bookmarks
fluid, lsd
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
