Go Back   Club RSX Message Board > PERFORMANCE BASICS > Supercharging
Closed Thread
Thread Tools
Old 07-02-2009, 09:03 AM   #1526
stwatson
Meth Blow Speed = my life
stwatson's Avatar
stwatson gets around and is known
stwatson gets around and is knownstwatson gets around and is knownstwatson gets around and is knownstwatson gets around and is knownstwatson gets around and is knownstwatson gets around and is knownstwatson gets around and is knownstwatson gets around and is known
Im also thinking about removing the POS bulb that is in my boost gauge and replacing it with some LED's. That would brighten it up a little.
AWAITING THE 12 SECOND TIME SLIP
Supercharged and Alcohol Injected!
318whp/215wtq Tuned by the Twat Himself
13.2 @ 111mph
stwatson is offline
Old 07-02-2009, 09:05 AM   #1527
rcracin
Senior Member
rcracin's Avatar
U guys really use the boost gauge on blowers that much?
Originally Posted by ProjectR View Post
whats the difference between jersey girls and garbage? garbage gets taken out, ZING
rcracin is offline
Old 07-02-2009, 09:05 AM   #1528
stwatson
stwatson's Avatar
TK-421...
what size piping are you getting or are you mating these parts to an existing pipe setup?
13.2 @ 111mph
stwatson is offline
Old 07-02-2009, 09:06 AM   #1529
stwatson
stwatson's Avatar
I do to monitor belt slip and to see if Im ACTUALLY boosting...helps to save gas. Partial throttle is notorious for jumping into boost faster than I realize, so its good to be able to see when you're trying to save gas.
13.2 @ 111mph
stwatson is offline
Old 07-02-2009, 09:07 AM   #1530
JustinC
Master Member
JustinC's Avatar
Originally Posted by stwatson View Post
Didnt even realize that was out there. Seems like it would block the hell out of the RPM tach. I kinda need to see that when Im all around town...
Gotcha...well I got some electrical tape so I guess I could just wrap those up to clean up the look a little.
don't use just electrical tape. it will end up putting sticky residue all over the wire, you put the loom over the wires and then put electrical tape around it.
Also, I think from your perspective it won't block the rpms too much and besides your tunerview will flash at the shift point
2005 Silverstone Metallic AP2 Honda S2000
Sold: 2003 NHBP RSX Type S
S/C Crew #45
RED WING CREW #2
Originally Posted by rensoyka View Post
that's why most guys who suck get their hands on a repair manual, 95% less suckage
JustinC is offline
Old 07-02-2009, 09:09 AM   #1531
stwatson
stwatson's Avatar
Well its SUPPOSED to flash at the shift point...Im still working on that Something is not quite right with it yet so I still gotta get some kinks out. For some reason my adapter box that allows hondata to communicate with the tunerview is overheating or something and stopping the connection. Im talking to them right now to resolve the issue so...
I guess I'd just have to buy it to see how much its blocking the RPM's but those pics on the item page dont really show a good "driver perspective"
I guess I can take the $35 plunge and see how it works then post back.
13.2 @ 111mph
stwatson is offline
Old 07-02-2009, 09:11 AM   #1532
rcracin
Senior Member
rcracin's Avatar
You could also rig up the led on your boost gauge to flash as your shift point. So many possibilities.
rcracin is offline
Old 07-02-2009, 09:12 AM   #1533
stwatson
stwatson's Avatar
that sounds complicated...lol
13.2 @ 111mph
stwatson is offline
Old 07-02-2009, 09:13 AM   #1534
JustinC
Master Member
JustinC's Avatar
yeah, Im looking at it and thinking about how much it would block your view. It look as though they tried to get it as low as possible. I just thought you may want a cleaner intall look.
S/C Crew #45
RED WING CREW #2
JustinC is offline
Old 07-02-2009, 09:13 AM   #1535
robry
BSK#17 Whale Penis Power!
robry's Avatar
yeah I would use that gauge pod mount (I'm gonna use it for my wideband gauge when I get one in a few weeks). But get some small wire loom and put it over those wires them wrap tape on it, it'll just give it more of a finished look. Also, what I was getting at with your radar detector was that the cable could be swapped out for some black 4-wire phone cable. It's flat, black and easy to hide in between the headliner and roof. You could soder on the power wire connect to it then run it across the headliner, down the a pillar and into the fuse box, then use an add-a-circuit. Works awesome Plus, radar mounted high above the rearview mirror will give you the most 'detection' range when driving highway speeds, help you pick up radar over top of hills and curves. I find my 8500 x50 works best up there and I think you'll notice that the v1 does as well too. Laser is fucking worthless to detect, because it just means you're getting pulled over lol, so that's why I don't bother mounting it low.
Precision SC6162S powered 06' Type-S | 417whp/289wtq @ 13.5psi | Synapse WHORE Krew #1
"It isn't about passing everything on the road, its about knowing you can"
robry is offline
Old 07-02-2009, 09:14 AM   #1536
tmartin
Afterfooler bliss
tmartin's Avatar
tmartin might be well recognized one day on c-rsxtmartin might be well recognized one day on c-rsxtmartin might be well recognized one day on c-rsxtmartin might be well recognized one day on c-rsxtmartin might be well recognized one day on c-rsxtmartin might be well recognized one day on c-rsxtmartin might be well recognized one day on c-rsxtmartin might be well recognized one day on c-rsx
Originally Posted by JPSlick View Post
If you guys know anyone that needs HID's I got the hook up.
Whats the hookup? I do not know anything about them but kind of like the way they look. In for some education on them and a good hookup.
tmartin
http://willbelayforfood.com/RSX/RSXMainSite/index.htm
Originally Posted by sharper View Post
Every once in awhile my son asks how much I have spent on my car, I always answer "asking how much money someone has spent on a car is like asking a woman her weight, the person is always insulted and the answer that is given is never the truth."
tmartin is offline
Old 07-02-2009, 09:14 AM   #1537
JustinC
Master Member
JustinC's Avatar
yes, if you don't have a step by step don't go there..we don't need to jump another 10 pages
S/C Crew #45
RED WING CREW #2
JustinC is offline
Old 07-02-2009, 09:14 AM   #1538
robry
robry's Avatar
http://videos.streetfire.net/video/U...vie_633662.htm
robry is offline
Old 07-02-2009, 09:16 AM   #1539
stwatson
stwatson's Avatar
I mean it DOES look cleaner. Im just going for function over form here. I COULD get some kind of bracket and paint it black and screw it into the plastic there to hold the gauge in place??
I'd have to look around at the pieces open to me at Lowes or whatever.
Here is what I'd REALLY like to do. I'd like to get a different CD player headunit and have the entire bottom half of the main display area open for mods. I can dash mount the tunerview there AND the boost gauge. That would be the best...however it requires me buying a new headunit.
13.2 @ 111mph
stwatson is offline
Old 07-02-2009, 09:16 AM   #1540
stlrollin6
everyone shut it
stlrollin6's Avatar
morning, so i havent slept in over 24 hours and i am still tipsy and feel like dying, and am now in class til 11. worst day of my life, should have waited til tonight with no school the next day. seriously, omg
starting to become a money pit
Dippers/Smokeless Tobacco crew of CRSX Co-Founder member #2
stlrollin6 is offline
Old 07-02-2009, 09:18 AM   #1541
rcracin
Senior Member
rcracin's Avatar
4300k for hids or you're a ricer. I hate blue light.
It ist hard to hook up a shift light. Doesnt kpro have a function for that? Your new device sounds like it does.
rcracin is offline
Old 07-02-2009, 09:22 AM   #1542
stlrollin6
everyone shut it
stlrollin6's Avatar
i got 6k and they are straight white....idk why
Old 07-02-2009, 09:24 AM   #1543
stwatson
stwatson's Avatar
I'll look into the power stuff once I get the V1. Right now I'll just deal with the annoying coiled wire. Do you recommend I get that concealed display for the V1 or is it not really worth it?
Hey now...
Wow...nice stuff on that one. No need for the A/F gauge on me though I got a direct K-pro read out.
13.2 @ 111mph
stwatson is offline
Old 07-02-2009, 09:24 AM   #1544
rcracin
Senior Member
rcracin's Avatar
You're nuts. I always sleep like shit after doing something like that.
rcracin is offline
Old 07-02-2009, 09:25 AM   #1545
stwatson
stwatson's Avatar
I think the tunerview II has the option...not K-pro. Its a switch set by the item turning on the shift light based on RPM signal given by K-pro.
13.2 @ 111mph
stwatson is offline
Old 07-02-2009, 09:25 AM   #1546
JustinC
Master Member
JustinC's Avatar
Hey now...
lol..he was showing you the pod
S/C Crew #45
RED WING CREW #2
JustinC is offline
Old 07-02-2009, 09:27 AM   #1547
rcracin
Senior Member
rcracin's Avatar
The v1 beeps like a bat out of hell so as long as you can see the arrows where its mounted, the concealed display is worthless. Its just more wires to run and more space to take up or searching for a suitable place to mount it.
rcracin is offline
Old 07-02-2009, 09:29 AM   #1548
rcracin
Senior Member
rcracin's Avatar
Also if it starts beeping like hell, you're bound to slow down anyways
rcracin is offline
Old 07-02-2009, 09:29 AM   #1549
stwatson
stwatson's Avatar
camera is still in the same place...not from the drivers perspective...unless you ride like a damn gangsta with your seat leaned back and your head level with the dash. IDK...I sit up higher and look down...which would be better I guess. Tell you what I'll see if I can buy this sucker and take some pics.
13.2 @ 111mph
stwatson is offline
Old 07-02-2009, 09:31 AM   #1550
robry
robry's Avatar
Hey now...
oem o2 sensor can be wrong at times, although its less off an issue at your power level, hence the need for a external wideband gauge to help you 'trust' the oem one. d-rob preaches this often. 250$~ for a gauge/sensor/pod to make sure my engine doesn't pop = worth it.
robry is offline
Closed Thread
Bookmarks
backyard, bbq, cocktails, ctsc, header or exchaust, lxxxi, mixed, paperweight, part, supercharged
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
