Go Back   Club RSX Message Board > PERFORMANCE BASICS > Turbo
Closed Thread
Thread Tools
Old 07-17-2009, 11:01 PM   #1001
Creepy Chris
Former Member
Creepy Chris has disabled reputation
Maybe power Josh. I've put these gauges in my car and a Speed3, and the Speed3 was picky about where you got power from.
Can't remember where I pulled my power from though...think it was IGN.
Creepy Chris is offline
Old 07-17-2009, 11:01 PM   #1002
Creepy Chris
Former Member
Originally Posted by iBoost View Post
ignition fuse? u mean the fuse box under the steering wheel? u wedged the wires in there?
Add a fuse FTW
Old 07-17-2009, 11:03 PM   #1003
405adamDC5
Senior Member
405adamDC5's Avatar
haha yeah i just ran one wire to the fuse then split all the other 3 into one. then ran all the grounds to the engine bay and the dimmer to the headlight. works just fine except when the turbo timer is working the guages stay on till the car shuts off
03 SSM type-s turbo
magnesium tuned
PSN COD = b00sted_k20
405adamDC5 is online now
Old 07-17-2009, 11:04 PM   #1004
iBoost
Nut Up or Shut Up
iBoost's Avatar
iBoost probably needs to buy a Wii FitiBoost probably needs to buy a Wii FitiBoost probably needs to buy a Wii FitiBoost probably needs to buy a Wii FitiBoost probably needs to buy a Wii FitiBoost probably needs to buy a Wii Fit
iBoost probably needs to buy a Wii FitiBoost probably needs to buy a Wii FitiBoost probably needs to buy a Wii FitiBoost probably needs to buy a Wii FitiBoost probably needs to buy a Wii FitiBoost probably needs to buy a Wii FitiBoost probably needs to buy a Wii FitiBoost probably needs to buy a Wii FitiBoost probably needs to buy a Wii FitiBoost probably needs to buy a Wii FitiBoost probably needs to buy a Wii FitiBoost probably needs to buy a Wii FitiBoost probably needs to buy a Wii FitiBoost probably needs to buy a Wii FitiBoost probably needs to buy a Wii FitiBoost probably needs to buy a Wii FitiBoost probably needs to buy a Wii FitiBoost probably needs to buy a Wii Fit
IGN wire? you spliced into it? wheres it at? what color?
Add a fuse FTW
Add a fuse to the fuse box?
If there was another thing i knew more about, it would be wiring.
Boost Slut Krew Member #16
Custom Slowmotion Motorsports GT35R Setup
458whp / 325 wtq @ 12psi - Pump Gas
iBoost is offline
Old 07-17-2009, 11:06 PM   #1005
405adamDC5
Senior Member
405adamDC5's Avatar
are you wanting to know what color the ignition wire is under the column?
03 SSM type-s turbo
magnesium tuned
Old 07-17-2009, 11:08 PM   #1006
iBoost
Nut Up or Shut Up
iBoost's Avatar
uhhh yeah... if thats what chris wired his too... ill try that to see if it makes a diff.
iBoost is offline
Old 07-17-2009, 11:09 PM   #1007
405adamDC5
Senior Member
405adamDC5's Avatar
i believe its black and yellow. might wanna double check though. there is two under there one is constant and the other is just what starts the car, let me see if i still have the diagram for it.
03 SSM type-s turbo
magnesium tuned
Old 07-17-2009, 11:10 PM   #1008
Creepy Chris
Former Member
Google add a fuse for images Josh...they plug into the place of an existing fuse in the box, then have two slots, one for the original fuse and one for whatever you're wiring into it. Then you also have a wire coming off it, connect that wire to the gauges for power.
http://images.google.com/images?hl=e...-8&sa=N&tab=wi
Pretty sure it was IGN I used. If that doesn't work, you can always pull it out and try another power source off the fuse box.
Old 07-17-2009, 11:12 PM   #1009
405adamDC5
Senior Member
405adamDC5's Avatar
yeah thats a hell of a lot easier lol
03 SSM type-s turbo
magnesium tuned
Old 07-17-2009, 11:13 PM   #1010
Creepy Chris
Former Member
Very easy...a little ghetto maybe, but works fine for me. And if by any chance I go somewhat back to stock, at least my wiring won't be all spliced up.
Old 07-17-2009, 11:15 PM   #1011
iBoost
Nut Up or Shut Up
iBoost's Avatar
Aight. back out to the garage.
iBoost is offline
Old 07-17-2009, 11:22 PM   #1012
Creepy Chris
Former Member
If you can't find it Josh, let me know and I'll run out to my car. I don't have all my dash trim back in, so it'll be easy to look.
Old 07-17-2009, 11:54 PM   #1013
Silver RSX-S
Noob
Silver RSX-S's Avatar
they are different colors most likely because the voltage or something is dropping as you put more on that one wire.
Try to find a new, stronger source for the lights and that should fix the color fading issue.
Sorry i'm not too technical, i'm not an eletrical type person, i just no the basics/concepts of some things.
Silver RSX-S is offline
Old 07-18-2009, 12:47 AM   #1014
iBoost
Nut Up or Shut Up
iBoost's Avatar
I found the IGN wire under the steering wheel... i have a wire spliced into it, i think it goes to my hondata boost control solenoid... anyways...
I tried moving my boost gauge power wire to the ign, leaving the other 2 gauges on the 12v and nothing changed. i even tried moving the grounds because the brightest gauge was on its own ground behind my dash while the other 2 shared one...
idk what to do they don't look different when i connect the wire to light them up amber
iBoost is offline
Old 07-18-2009, 01:04 AM   #1015
Creepy Chris
Former Member
Hmmm...not sure then Josh. I only ran the light for a little while before I put it back to amber all the time. I'm also colorblind, so I probably wouldn't really notice it if the white was slightly different across the gauges.
The only other thing I could say would be to hook all three up to the IGN and see what it does.
Old 07-18-2009, 01:24 AM   #1016
Flores45
Silver Bullet
Flores45's Avatar
Flores45 gets around and is known
Flores45 gets around and is knownFlores45 gets around and is knownFlores45 gets around and is knownFlores45 gets around and is knownFlores45 gets around and is knownFlores45 gets around and is knownFlores45 gets around and is knownFlores45 gets around and is knownFlores45 gets around and is knownFlores45 gets around and is known
hi everyone?
Spring 2010: Aftercooled Supercharged Nitrous
Flores45 is offline
Old 07-18-2009, 01:28 AM   #1017
iBoost
Nut Up or Shut Up
iBoost's Avatar
Tried a few different combos with power and grounds... nothing.
now when i connect the orange wire to light amber for all 3, they all have the same shade.
im about to say fuck it and make them amber all the time even tho i cant read them for shit if there is any glare
iBoost is offline
Old 07-18-2009, 01:41 AM   #1018
Push
Full Race EBP
Push's Avatar
Push is a rep WHORE
Push is a rep WHOREPush is a rep WHOREPush is a rep WHOREPush is a rep WHOREPush is a rep WHOREPush is a rep WHOREPush is a rep WHOREPush is a rep WHOREPush is a rep WHOREPush is a rep WHOREPush is a rep WHOREPush is a rep WHOREPush is a rep WHOREPush is a rep WHORE
Originally Posted by Flores45 View Post
hi everyone?
What's up man... drunk off my ass
Hi everyone drunk post ftw
http://forums.clubrsx.com/picture.php?albumid=264&pictureid=3867
424 whp, 294 ft/lb tq GT3076R @15psi on 93 octane
Push is offline
Old 07-18-2009, 01:42 AM   #1019
Flores45
Silver Bullet
Flores45's Avatar
drinking also a bit.
Flores45 is offline
Old 07-18-2009, 08:19 AM   #1020
robry
BSK#17 Whale Penis Power!
robry's Avatar
josh are you running the gauge lighting in series or parallel? or our they just such poor quality LEDs that they all look different? lol
Precision SC6162S powered 06' Type-S | 417whp/289wtq @ 13.5psi | Synapse WHORE Krew #1
"It isn't about passing everything on the road, its about knowing you can"
robry is offline
Old 07-18-2009, 08:26 AM   #1021
JUANonJUAN
The OFFICIAL vtec dealer
JUANonJUAN's Avatar
Is there a certain amount to torque them down? something I can measure?
be careful josh because the "T" bolt will snap..... my buddy broke one of mine ... and IIRC I paid like $40 to replace it..
[SIGPIC][/SIGPIC]
"Lo que uno siembra, es lo que uno cosecha"
JUANonJUAN is offline
Old 07-18-2009, 08:29 AM   #1022
JUANonJUAN
JUANonJUAN's Avatar
a little bit of fun
http://videos.streetfire.net/video/J...-vs_695656.htm
the guy actually told me that he puts down 300whp... he works at velocity trends, a local shop here.. and is fucking with the dyno all day....
he was a little sneaky... he put only 1 gallon of gas to race me.... I had a full tank
either way.... when I started pulling hard.... BOOST/LEAN cut :fml:
[SIGPIC][/SIGPIC]
Old 07-18-2009, 08:32 AM   #1023
JUANonJUAN
JUANonJUAN's Avatar
he also has an EK coupe with 450whp, I will run his EK when/if I can fix my fuel cuts..
oh also, i didn't brake boost
[SIGPIC][/SIGPIC]
Old 07-18-2009, 09:02 AM   #1024
magnEsium
needs a yob nom nom nom
magnEsium's Avatar
magnEsium is a rep WHORE
magnEsium is a rep WHOREmagnEsium is a rep WHOREmagnEsium is a rep WHOREmagnEsium is a rep WHOREmagnEsium is a rep WHOREmagnEsium is a rep WHOREmagnEsium is a rep WHOREmagnEsium is a rep WHOREmagnEsium is a rep WHOREmagnEsium is a rep WHOREmagnEsium is a rep WHOREmagnEsium is a rep WHOREmagnEsium is a rep WHOREmagnEsium is a rep WHORE
still looked like a good race Juan
magnEsium is offline
Old 07-18-2009, 09:42 AM   #1025
D-Rob
Member
D-Rob's Avatar
I wanted to shoot myself yesterday.
Stupid B-Series cars. Distributors, FTL.
Two bad ones in a row, then the customer's car ran out of gas (since evidently his gauge didn't work...)
- Derek
'98 Honda Civic DX Coupe: K20-Powered, Full-Race Motivated: 452whp / 334wtq @ 15psi
InnovativeMotorWorks
ClubRSX K-Pro Dyno Tuning Special! <-- Flat-rate K-Pro Dyno Tuning in the Northeast/Mid-Atlantic region
D-Rob is offline
Closed Thread
Bookmarks
lazy, make, turbo
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
