ECU tuning *chat* ask your questions here first - Page 5 - Club RSX Message Board
Go Back   Club RSX Message Board > PERFORMANCE BASICS RSX > ECU Tuning RSX
Notices
Reply
Thread Tools
Old 08-10-2009, 05:34 AM   #101
jpirie817
Member
jpirie817 is a jewel in the rough of c-rsx jpirie817 is a jewel in the rough of c-rsx jpirie817 is a jewel in the rough of c-rsx jpirie817 is a jewel in the rough of c-rsx jpirie817 is a jewel in the rough of c-rsx jpirie817 is a jewel in the rough of c-rsx jpirie817 is a jewel in the rough of c-rsx jpirie817 is a jewel in the rough of c-rsx
Originally Posted by keto06 View Post
<in almost a sing song like chant> Should have gone to T1....Should have gone to T1.
where is it?
jpirie817 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 08-10-2009, 07:01 AM   #102
magnEsium
www.magtuning.com
magnEsium's Avatar
magnEsium is a rep WHORE
magnEsium is a rep WHORE magnEsium is a rep WHORE magnEsium is a rep WHORE magnEsium is a rep WHORE magnEsium is a rep WHORE magnEsium is a rep WHORE magnEsium is a rep WHORE magnEsium is a rep WHORE magnEsium is a rep WHORE magnEsium is a rep WHORE magnEsium is a rep WHORE magnEsium is a rep WHORE magnEsium is a rep WHORE magnEsium is a rep WHORE
Originally Posted by jpirie817 View Post
where is it?
http://www.t1racedevelopment.com/
magnEsium is offline   Reply With Quote
Old 08-10-2009, 07:25 AM   #103
keto06
Deliverin Yo Pizza...
keto06's Avatar
keto06 is an unknown quantity on c-rsx
Originally Posted by magnEsium View Post
I would rep ya if I could menz.
where is it?
Though on second thought, call Chris Macellaro.
SOLD!!! 04 PWP Type-S
Currently Rocking: 2004 JBP WRX
Free Hondata s300/KPro Help! PM Me! Best Way To Contact/Paypal=keto06@gmail.com "Stayin' Legal & Goin' Slow" Crew, RIP Always Playin' Reach Crew,
keto06 is offline   Reply With Quote
Old 08-10-2009, 12:08 PM   #104
jpirie817
Member
who's that ? and at what number?.....I don't get it everyone tells me u can tune my car for top end low end whateverend ! MY tuner don't seem to agree.....
Old 08-10-2009, 12:20 PM   #105
keto06
keto06's Avatar
http://www.macellarosperformancetuning.com/
Old 08-11-2009, 01:01 PM   #106
Cinci Turbo S
273whp 211tq
Cinci Turbo S's Avatar
Cinci Turbo S has a clean start Cinci Turbo S has a clean start Cinci Turbo S has a clean start
What spark plugs do you suggest i use with my setup?
K24a1 bottom. tsx pistons. K20z3 head with stage 2 cams and flat face valves.
480cc injectors, race header and exhaust.
Thanks
My Built K24 EP3
My Videos
02 Civic SI K20/K24
02 CBR 954RR
www.healthwarehouse.com
Cinci Turbo S is offline   Reply With Quote
Old 08-11-2009, 03:14 PM   #107
walk
cone head
walk's Avatar
walk is an unknown quantity on c-rsx
FIXED: See here -->http://forums.clubrsx.com/showthread.php?t=668179
I just put my ECU back in after getting Hondata #4 reflash. (Good service btw, sent on Fri UPS overnight, arrived to Torrance on Mon and I got it back Tues before noon..)
When I turn the key to II or whatever "run" is (not to "start"), the dash lights up, CEL light comes on (normal) then about 20 seconds it goes off (normal). But after it goes off, it flashes 5 times, then goes off permanently. It also flashes breifly when I start the car, I don't know if that's normal...
Car seems to run ok, haven't really raced it out yet.. idle will take a few cycles to settle down I guess.. but is the flashing thing a concern?
I should add that I did all this with the battery connected. Should I pull the ECU fuse (#6?) to reset it and see what happens?
02 RSX Type S - SFR SCCA SoloII #67 ST
94 Miata - ES build in progress!
walk is offline   Reply With Quote
Old 08-12-2009, 10:00 AM   #108
archull
The Architect™
archull's Avatar
archull gets around and is known
archull gets around and is known archull gets around and is known archull gets around and is known archull gets around and is known archull gets around and is known archull gets around and is known archull gets around and is known archull gets around and is known archull gets around and is known archull gets around and is known archull gets around and is known archull gets around and is known archull gets around and is known
Anyone ever have a 05-06' Kpro adapter harness break????
Fucking sucks because Hondata is trying to reem me out for a new one. I would just replace the damn pin myself if I could find a male pin for the harness side to the factory engine harness
Here is the thread I started on the Hondata forums. Please read and post up in the thread.
http://www.hondata.com/forum/viewtopic.php?t=9892
*SOLD*St00pid Tuned 06' RSX Type-S, Peakboost Turbo Kit
w/ GT3076 Turbo de-tuned to 400whp & 280ft/lbs on pump
2012' F-250 Crew Cab Lariat, 6.7L Turbo Diesel Daily
archull is offline   Reply With Quote
Old 08-12-2009, 09:11 PM   #109
walk
cone head
walk's Avatar
When I turn the key to II the dash lights up, CEL light comes on (normal) then about 20 seconds it goes off (normal). But after it goes off, it flashes 5 times, then goes off permanently. It also flashes breifly when I start the car, I don't know if that's normal...
Update: put jumper on OBDII DLC as shown here -> http://www.k-series.com/tech_document.php?id=37
CEL does not flash (no code stored).
Pulled ECU fuse = no change.
Pulled ECU fuse, pulled all 3 wiring harness off ECU, checked for loose wires, all wires look ok. Replaced fuse = no change.
Anyone know what 5 flashes means??
Like I said, car seems to run fine, little worried about the CEL flashing though.
CEL does not flash or come on during driving, even extreme acceleration uphill.
Oh I checked fuel cap too, it's tight...
I also put an intake on recently, don't think it flashed after that though (I drove it a little bit, then pulled the ECU the same day). I did check all the sensor wires (AIT, etc) around the intake that you have to mess with when installing intake, they all seem ok..
Old 08-12-2009, 09:20 PM   #110
Agent Smith
It is inevitable
Agent Smith's Avatar
Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more
Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more
just to rule this out, as it gets referred to as the cel often... it's not the maintenence light flashing is it? seems like after 5,000 miles it flashes something like 5 times, then after 7,500 it stays on until reset.
Originally Posted by waltMA70 View Post
The thing I like best about camaros is that they come new from the factory smelling like winston cigarettes.
S/C Crew Member #7 CRSX Zombie Eradication Team Member #10|Anime Crew 三番
http://i2.photobucket.com/albums/y41/Xinu38/Untitled-2_zpsceedtb4z.gif
Agent Smith is offline   Reply With Quote
Old 08-12-2009, 10:46 PM   #111
walk
cone head
walk's Avatar
:Fixed:
Old 08-13-2009, 03:16 AM   #112
blackrsx530
CT
blackrsx530's Avatar
blackrsx530 is a jewel in the rough of c-rsx blackrsx530 is a jewel in the rough of c-rsx blackrsx530 is a jewel in the rough of c-rsx blackrsx530 is a jewel in the rough of c-rsx blackrsx530 is a jewel in the rough of c-rsx blackrsx530 is a jewel in the rough of c-rsx blackrsx530 is a jewel in the rough of c-rsx blackrsx530 is a jewel in the rough of c-rsx
ive got a couple issues I updated my K manager and now im getting an error saying that my current calibration is from an older version and i cannot datalog. i have the original tune. I am also getting an error saying that i must switch from on board memory datalogging to...etc, how can i correct these? ive played with the setting but nothing has worked.
blackrsx530 is offline   Reply With Quote
Old 08-14-2009, 11:13 AM   #113
Mario_Ben22
Another Member
Mario_Ben22's Avatar
Mario_Ben22 is an unknown quantity on c-rsx
ok so i have read several of the ecu threads and im still left with 1 question about the reflash. So someone said that the reflash was basiclly a mild one size fits all. Someone else said it is tuned for no race header or you run lean for an 05/06.
Now my question is... What exactly is the reflash map supposed to support best? Is it just an addition to an Intake and exhaust or does it support other mods?
06 NBP RSX-S
Injen CAI / Injen Dry Flow Filter / Injen Hydroshield / Ingalls Tq Damper / Gates Radiator Hose / Dunlop Direzza DZ101
q/ ___\p
/Oo.\\_. A ._//.oO\
\_o__|R S X|__o_/
Mario_Ben22 is offline   Reply With Quote
Old 08-14-2009, 11:16 AM   #114
keto06
keto06's Avatar
CAI, Hondata IMG, Shorty Header, Catback Exhaust. For sure. Though,their has been 2 threads lately where both people had reflash with RH and were fine AFR wise, FYI.
Old 08-14-2009, 12:11 PM   #115
Mario_Ben22
Another Member
ty.
06 NBP RSX-S
q/ ___\p
/Oo.\\_. A ._//.oO\
\_o__|R S X|__o_/
Old 08-14-2009, 01:29 PM   #116
walk
cone head
walk's Avatar
Originally Posted by hondata web site says
We have tested short ram, cold air intakes, headers, test pipes and exhausts and have done some preliminary work with ITR cams. The programs have been tested to work well with any intake.
(the ITR cams is a seperate program)
also
VTEC
With the stock airbox the VTEC point needs to be set at 5800 rpm. With intakes the power curve benefits from a lower VTEC point. VTEC switching point is important. Switching at the wrong RPM can cause the engine to drop power for the next 1000-1500 rpm. We have found 5200 rpm a good point for cars with intakes.
So it's pretty important to ditch the stock airbox for the lowered vtec point.
Old 08-15-2009, 08:45 PM   #117
con5tant
lettuce be cereal
con5tant's Avatar
con5tant is a jewel in the rough of c-rsx con5tant is a jewel in the rough of c-rsx con5tant is a jewel in the rough of c-rsx con5tant is a jewel in the rough of c-rsx con5tant is a jewel in the rough of c-rsx con5tant is a jewel in the rough of c-rsx con5tant is a jewel in the rough of c-rsx con5tant is a jewel in the rough of c-rsx con5tant is a jewel in the rough of c-rsx
can kpro can read CELs like an OBDII scanner?
con5tant is offline   Reply With Quote
Old 08-15-2009, 08:49 PM   #118
Gotboost98
I don't like you
Gotboost98's Avatar
Gotboost98 is on a distinguished road Gotboost98 is on a distinguished road
Dear Wes
Why does my kpro manager say danger to the manifoldddddd when I hit vtec in 3rd geaaaaaaaaar!?
Impreza-Slow 11 second crew
Rsx Vs All Asshole Crew Member #1< Founder 1 of 37 membersShit and get crew member #2
Originally Posted by rest View Post
it makes me laff that the typical honda n00b thinks the s2k is the pinnacle of engineering and covet them so rabidly. it's like their ultimate goal to get one.
Originally Posted by Fade2Black View Post
god i hate the turbo forum, so full of stupid n00bs
Originally Posted by crazy View Post
Which is embarrassing because the Si gets spanked by anything with wheels
Gotboost98 is offline   Reply With Quote
Old 08-15-2009, 08:53 PM   #119
Agent Smith
It is inevitable
Originally Posted by Gotboost98 View Post
Dear Wes
because your mechanic kittah don't know nothing about that vtak ...
Old 08-15-2009, 08:54 PM   #120
Gotboost98
I don't like you
Gotboost98's Avatar
My kittah broke then Make lauren fix it nao
Old 08-15-2009, 08:56 PM   #121
Agent Smith
It is inevitable
i'll send her on her way... she's had a couple drinks though
didn't think i'd be lurking did you?
Old 08-15-2009, 08:57 PM   #122
Gotboost98
I don't like you
Gotboost98's Avatar
Well as long as she brings her tons of coupons too it will be cool. Kpro coupons
Eh you always do
Old 08-15-2009, 10:29 PM   #123
k20vteck20
Comptech powaaaaa!!!
k20vteck20's Avatar
k20vteck20 is a jewel in the rough of c-rsx k20vteck20 is a jewel in the rough of c-rsx k20vteck20 is a jewel in the rough of c-rsx k20vteck20 is a jewel in the rough of c-rsx k20vteck20 is a jewel in the rough of c-rsx k20vteck20 is a jewel in the rough of c-rsx k20vteck20 is a jewel in the rough of c-rsx k20vteck20 is a jewel in the rough of c-rsx
can someone help me with my tune im hitting lean cut,here are two datalogs in third gear
highway run 5.kdl
highway run 4.kdl
06 RSX-S Comptech Supercharged
Complete 2002 ABP Rsx Type-s part out
k20vteck20 is offline   Reply With Quote
Old 08-16-2009, 06:59 AM   #124
rensoyka
Breast inspector by appt.
rensoyka's Avatar
rensoyka is an unknown quantity on c-rsx
just use lambda overlay to smooth out a few of the spots.
'06 black type-s.
rensoyka is offline   Reply With Quote
Old 08-16-2009, 12:22 PM   #125
con5tant
lettuce be cereal
con5tant's Avatar
Reply
Bookmarks
connected , ctsc , ecu , gage , inspection , knock , kpro , passing , pod , question , questions , reflash , replacing , tuning
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright © 2001-2012, Club RSX, Inc. All rights reserved worldwide.
