Tools and Techniques: Ways to make life easier - Club RSX Message Board
Go Back   Club RSX Message Board > ADVANCED PERFORMANCE > Welding, Fabrication, & Tools
Reply
Thread Tools
Old 07-20-2009, 12:15 AM   #1
Keith DC5
997 C4S
Keith DC5's Avatar
Keith DC5 is on a distinguished roadKeith DC5 is on a distinguished road
Several of us are employed within the automotive industry, so I thought it'd be nice to network and share some "tricks of the trade." As automotive professionals, we're introduced to revolutionary new tools and techniques every day, so I'm willing to bet that our fellow forum members can learn from us as well
We've all been in this position before: There's an obscure bolt that needs to be fastened, but it sits at an extremely ridiculous angle. Using a conventional socket, you attempt to install said fastener, but gravity prevails. The bolt has now fallen into the black abyss of the modern engine compartment. If you're lucky enough to find the bolt, what will you do next? A) do the same thing twice?, B) spend $300 on magnetized sockets?, C) have someone else deal with it?
Well here's a free solution:
Using a small piece of tissue paper (or paper towel), you can wedge the fastener within the socket. This prevents the nut/bolt from falling out, even when the ratchet is fully inverted. You can also use this technique when removing fluid drain bolts. We've all gone "fishing" for drain bolts before, so please feel free to utilize this technique the next time around. The last thing that anyone needs, is to be wrist-high in extremely hot carcinogenic fluids.
Keith DC5 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 07-20-2009, 12:18 AM   #2
mr_fobster
Senior Member
Hammer......every ford technician should need at least 15 different sizes. fixes everything......hehehe
but umm ratcheting closed end wrenches! i LOVE these to death! also if they were a flexhead ratcheting wrenches.......ooouuuuhh.
TEAM ULTRASPEED
mr_fobster is offline   Reply With Quote
Old 07-20-2009, 12:24 AM   #3
Keith DC5
997 C4S
Keith DC5's Avatar
http://www.youtube.com/watch?v=Qjt8xrZWb4A
I absolutely love my Snap-On variable extensions. They're expensive, but you'll never have to "test fit" various extensions just to find the right length.
Old 07-20-2009, 02:04 AM   #4
jesselyons2002
Need Help ?
Using another wrench as leverage to loosen a stubborn bolt or nut.
(Example)
jesselyons2002 is offline   Reply With Quote
Old 07-20-2009, 03:56 AM   #5
Bath Tussue
Master Baiter
Bath Tussue's Avatar
(Example)
http://i83.photobucket.com/albums/j2..._1580Large.jpg
I do that all the time!
The only problem I have is that it gives me to much torque that I sometimes strip the bolt trying to take it out.
http://blog.bathtussue.com/
Bath Tussue is offline   Reply With Quote
Old 07-20-2009, 02:46 PM   #6
blursx03
re-inspired
blursx03's Avatar
anyone have a technique that would work for getting that darn nut in the back that goes on the rear struts? Nothing I have quite fits in their.
ABP Crew Member #5
follow グッドスマイルレーシング 日本語が分かる。
blursx03 is offline   Reply With Quote
Old 07-20-2009, 03:52 PM   #7
Bath Tussue
Master Baiter
A flexable joint.
Old 07-20-2009, 06:28 PM   #8
Ktec
ya'll got hot wing?
Ktec's Avatar
Originally Posted by Bath Tussue View Post
wrapping ^^^that, a flexible joint, with electrical tape to keep it at a 90 or 45 degree angle while you insert the bolt or nut....
its a life saver when working on the intake manifold's bottom bolts!
Forgotten more than you ever learned.
Armenian crsx crew member #?
Function Over Form.
GMThe heartburn of America
Ktec is offline   Reply With Quote
Old 07-20-2009, 08:37 PM   #9
Keith DC5
997 C4S
Keith DC5's Avatar
You can bend or remove the plastic panels covering the C-pillars, to reach the nuts straight-on (using an extension). The reason why this is preferable is because you CANNOT use a universal joint when torquing a fastener.
Since we're on the topic of hard-to-reach areas, you're working too hard if you don't own some flexible extensions:
Old 07-21-2009, 04:09 AM   #10
jesselyons2002
Need Help ?
http://home.jtan.com/~joe/KIAT/fig_8c.jpg
http://www.drillspot.com/pimages/145/14548_300.jpg
Omg. I didnt know they made flexible extension. Do they work out good ???
Old 07-21-2009, 06:55 AM   #11
Keith DC5
997 C4S
Keith DC5's Avatar
If you're constantly working in tighter areas (ie. under the dash), they're worth their weight in gold. God knows that some screws, nuts, and bolts are impossible to access even with a universal joint.
Keep in mind that it's only to be used for low torque fasteners, such as distributor cap bolts, or panel screws, etc. Snap-On only offers a 1/4" drive flexible extension, but Matco does sell a 3/8" drive version. Depending on the application however, you may prefer the conventional flexible driver instead:
http://buy1.snapon.com/catalog/item....re&dir=catalog
If you don't already own a ratcheting driver, here's a kit I would recommend:
http://www.gearwrench.com/catalog/sc....jsp?part=8940
Old 07-21-2009, 04:14 PM   #12
blursx03
re-inspired
blursx03's Avatar
I have a universal joint, but nothing like the flexible one in your post. That thing looks amazing! I ended up using a wrench a just hand tightened it with some decent force.
ABP Crew Member #5
Old 07-26-2009, 01:43 AM   #13
kg98921byrams
Senior Member
kg98921byrams's Avatar
Since a handful of us are within the automotive industry, I thought it'd be nice if we could share some tools and techniques with our fellow forum members. As professionals, we're introduced to revolutionary new tools and techniques everyday, so I'm sure we can all learn from each other as well
We've all been in this position before: There's an obscure bolt that needs to be fastened, but it sits at an extremely ridiculous angle. Using a conventional socket, you attempt to install said fastener, but gravity prevails. The bolt has now fallen into the black abyss of the modern engine compartment. If you're lucky enough to find the bolt, what will you do next? A) try again?, B) spend $300 on magnetized sockets?, C) have someone else deal with it?
http://img181.imageshack.us/img181/6274/90556048oa8.jpg
Using a small piece of tissue paper (or paper towel), you can wedge the bolt within the socket. This prevents the fastener from falling out, even when the ratchet is fully inverted. You can also use this technique when removing fluid drain bolts. Why drop the bolt into an oily mess, when you can retain it with a small piece of tissue?
usually i just use tape such as electrical tape.
[img]http://rds.yahoo.com/_ylt=A0WTb_31BwpKmeMAm8ujzbkF/SIG=12930smlr/EXP=1242257781/**http%3A//www.oddjack.com/wp-content/boston_celtics3.jpg[/img]
kg98921byrams is offline   Reply With Quote
Old 07-26-2009, 04:28 AM   #14
J-sPeEd
Stock or Bust
crowfoot sockets. helps me out with tightening bolts and nuts in awkward areas such that found on top mount turbo manifolds for example.
For Sale:
J-sPeEd is offline   Reply With Quote
Old 07-26-2009, 10:10 PM   #15
2 Cuda's
9's or bust!
2 Cuda's's Avatar
I got one from an odd source... Normally I wouldnt listen to a redneck, but an old timer once told me, if you ever have a bolt you cant loosen, just heat it slightly, and put a candle on it. Capillary action pulls the wax in between the threads and it will litterally just spin out. Pb blaster, aero kroil, wd, whatever cant hold a candle, to this method.... yes the pun was intended... Has saved many a busted knuckle and bolt, especially on some older vehicles that have seen salt corrosion. Like on lower control arm bolts, spring shackle bolts, etc...
SLOWMARO!
http://img.villagephotos.com/p/2002-...wheelie(2).jpg
Bitch slapping newbs and tools since 03....
Originally Posted by Mr. Spade View Post
Need for speed only lets you use manual in drag, so thats how it should be in real life.
2 Cuda's is offline   Reply With Quote
Old 09-01-2009, 11:13 PM   #16
DzMiniz
New Member
http://images.buzzillions.com/images...629129_raw.jpg
These are awesome, HAD to use some a while back
DzMiniz is offline   Reply With Quote
Old 11-04-2009, 08:47 PM   #17
jester0110
Master Member
^x2
good tips
jester0110 is offline   Reply With Quote
Old 11-04-2009, 09:58 PM   #18
2002 Sleepr
Member
http://www.germes-online.com/direct/...tish_Type_.jpg
I know I would be completely lost without my BFH tool
2002 Sleepr is offline   Reply With Quote
Old 11-09-2009, 10:10 AM   #19
Relapse
That's very interesting. I'm going to have to try that some time
Relapse is offline   Reply With Quote
Old 11-09-2009, 10:52 PM   #20
Extra Krispy
Harder Faster Stronger
Extra Krispy's Avatar
Extra Krispy is a rep WHORE
Extra Krispy is a rep WHOREExtra Krispy is a rep WHOREExtra Krispy is a rep WHOREExtra Krispy is a rep WHOREExtra Krispy is a rep WHOREExtra Krispy is a rep WHOREExtra Krispy is a rep WHOREExtra Krispy is a rep WHOREExtra Krispy is a rep WHOREExtra Krispy is a rep WHOREExtra Krispy is a rep WHOREExtra Krispy is a rep WHOREExtra Krispy is a rep WHOREExtra Krispy is a rep WHOREExtra Krispy is a rep WHORE
these make life so much easier when working with anything with clips, esp when removing the front bumper on a rsx
2006 Yamaha R6
2006 Volvo S60 R
Motorcycle Crew #67
02 RSX-S 13.805@101- SOLD
Extra Krispy is offline   Reply With Quote
Old 11-09-2009, 11:50 PM   #21
killertofupanda
killertofupanda's Avatar
for those too cheap to buy a breaker bar, pvc pipes make good extension to get more torque out of a regular hand ratchet. my ghetto honda friends passed down this sacred knowledge in my first oil changes, and i am still grateful for the lesson to this day.
killertofupanda is offline   Reply With Quote
Old 11-10-2009, 06:16 PM   #22
Blown330
Blown is Better
Blown330's Avatar
Impact driver. Great tool.
Originally Posted by smiley4284
I suck blue and orange donkey cocks and let them finish in my asshole.
Blown330 is offline   Reply With Quote
Old 11-11-2009, 07:54 AM   #23
Extra Krispy
Originally Posted by killertofupanda View Post
http://www.slpipe.com/images/Bryce%20PVC.jpg
I have dont that many times except with a 2ft piece of metal pipe
2006 Yamaha R6
2006 Volvo S60 R
Motorcycle Crew #67
Old 11-12-2009, 03:17 PM   #24
Mugen-Rwantanabe
Senior Member
Mugen-Rwantanabe's Avatar
Alot of floor jacks ive seen have 2 peice handles, including mine and i just take one of the handle peices from it and theres my breaker bar works every time.
Mugen-Rwantanabe is offline   Reply With Quote
Old 11-13-2009, 09:39 PM   #25
SaYjAiBaO
Senior Member
SaYjAiBaO's Avatar
those open end crowfoots suck balls. they'll get the job done if you work at the dealership and work on cars that are only a few years old tops.
i'm a huge snap-on guy and my whole tool box consists of snap on tools. being in canada has it's benefits . when i'm in school training (2 months a year, 3 years total) i get 20-40% off snap on tools. my philosophy is that you will be using these tools to make a living for the rest of your career, why not use the best?
SaYjAiBaO is offline   Reply With Quote
Reply
Bookmarks
easier, life, make, techniques, tools, ways
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © 2001-2012, Club RSX, Inc. All rights reserved worldwide.
