#126 | |
GM Engineer Wannabe
"If it ain't broke, you're not trying hard enough." |
#128 |
CLUB RSX.com Supporter
Yes and .82
Full-Race stage 3.7* 10second/no weight reduction street RSX!!!***Evans Tuned*** 689whp484lbft
#129 | |
凸(-_____-)凸
And there are a ton of 40r evo's making over 800. Hell a 35r one I personally know makes 700awhp on c16 and 40psi. No meth or nitrous. Anyhow, I was just curious why people kept saying its not possible. |
#130 | |
And the Evo with a 35R making 700whp is completely out of his efficiency range. The 35R will boost 40psi but it's so inefficient most tuners stop at 30psi. I think people are way to hung up on dyno numbers rather than how fast the car really is. Most guys make big numbers hit the track and run what a car with half the hp does....It makes no sense producing huge numbers if the car is slow. My buddy's Subie with a 30R and meth runs 11.0 all day long. His car has never been on a diet or even had slicks on it. I believe he is the fastest or second fastest street 30R subie. I'm sure GotBoost knows him from the Subie forums. He doesn't make big hp numbers but he stomps the competition. I guess what I'm saying is get the car to the track and then see what she can really do. Dyno numbers mean nothing, ET's mean everything.
#131 | ||
I don't like you
http://www.youtube.com/watch?v=yfo8sOnP3Yw http://videos.streetfire.net/video/2...BBQ_176931.htm
Impreza-Slow 11 second crew Rsx Vs All Asshole Crew Member #1< Founder 1 of 37 membersShit and get crew member #2 Quote:
#133 | |
I don't like you
sti's are about 250lbs heaviers than wrx's pending on year wrx. Evos are I believe 40lbs lighter than sti's. Im too lazy to check.
Wrxs have better gearing imho for drag racing than sti's. Too short in the sti's. but to really drag race a wrx like those evos you would need PPG gears. Evos have a much better motor. They are just better top end. Hell subarus have yet to break out of the 9s to my knowledge. Evos are in the 7s. with 1000whp, which COULD be daily driven but isnt.
#134 |
凸(-_____-)凸
The thing here is: we're talking about dyno numbers. I understand that it really doesn't mean shit and the real power figure is trap speed but that's not what the conversation is about right now.
BTW I disagree with your "35r inefficient above 30psi" statement. The car in question runs low 10's at 140 with shitty driving, and while the turbo might be pretty much maxed out, it is not way beyond its efficiency range. The hotside is .86 so it holds power/boost all the way to 8500rpm and ait's don't skyrocket or any knock is detected. He's currently trying to get into 9's by improving his launch/shifts. Check it out: http://www.youtube.com/watch?v=kMa6X...layer_embedded |
#135 | |
凸(-_____-)凸
#136 | ||
I don't like you
hot damn we made it out of the 9s
#138 | |
Master Member
your numbers are very nice congrats... now think of this if you put my brakes my rims and tires on your car and used the same dyno what numbers do you think your car would hit... you would be probably be close to 80 to 100 less... next time i am on the dyno i will bleed my brakes put some stock brakes on with drag wheels and i will be in the 700s with out changing the boost or my tune...there are so many ways to manipulate the dyno to get a high whp reading... i would never dyno my car on a dyno pack either its not true whp... RSXIN AZ said it right to many people are concerned about what horse power they run... i flared my fenders out for a reason so i can run a bigger rim and tire... i have very good traction with the bigger tire so i dont care that i am losing power by using a larger tire and rim because in the long run my car is faster that way then if i had small tires and more power...
KPRO/Garret GT40R BB TURBO/Dual Tial 44mm WGS/Turbo Smart Supersonic BOV/Full Race T4 Manifold + 3inch Downpipe/Custom Piping/Custom 3" Exhaust/Forged Rods/9:1 Pistons/Fast-Turbo Fuel System/Return Line/1600cc Precision Injecors/Golden Eagle Fuel Rail/Aeromotive Fuel Pressure regulator/Tilton Twin Disc Cerametallic Clutch/Quaife LSD/spd Transmission Gears/IPS KT1 Cams/Eibach EVS w/Ti retainers/Custom Dual Oil Coolers//Benson Sleeves |
#139 | |
Master Member
ok so i think your the only one on here so far that understands that i will lose alot of power running my big wheels and brakes.. when you say that u knew that my car would be tough to reach 800whp because of my set up is that what you were you talking about my set up ... alot of people on here dont realize that i am running very big wheels on my car because i had my fenders flared i am running 18 x 9 275 18 40 tire..... once i get 4bar map sensor i am going to change my brakes and put on the drag wheels crank the boost i dont see how i will not hit 800.....
#140 |
Master Member
Needless to say your build is quite impressive and I hope you achieve your goals.
Boost Slut Krew Member #20 11.86 @ 116.97 1.77 60ft.... First Run Ever! HaLFAmAzinG120 (2:31:52 PM): fuck me like you hate me! HaLFAmAzinG120 (2:31:56 PM): oh wrong IM sorry LoSt1nY3RpAnTIEz (2:32:23 PM): O.O |
#141 | |
GM Engineer Wannabe
#142 | ||
Instead of switching out the wheels and rotors just hit up a dynapack. You still lose a bit from the rotors but you'll be fine. I think your biggest limiting factor for hitting 800whp will be on your intake side. The guys I've seen hit 800+whp had massive throttle bodies, sheet metal intakes and 3in charge pipes. All in all don't sweat it, you have great traction on the street and more than enough horespower
#144 | |
Master Member
#145 |
Bar'd TWICE
proops
06 CBR600RR 09 Toyota Pruis Full Loaded(Navi and leather) rolling @48.6mpg 01 EM2 - Built K24--PICS OF THE k24 EM2 NA tune 9:1...240.7 hp and 190.9 tq Stuff for Sale |
#147 |
Master Member
gt4094r 1.06 exhaust ar
#148 | |
凸(-_____-)凸
I've seen the compressor maps. Ive seen the turbine maps for the different back housings. I've seen the dyno charts. Most don't take them past 30psi, true, but the few that do still make a bit more power. There are ways to bring the temps down such as water/meth injection. As far as what I've built I really don't think you wanna get into that with me. We have a shop that has put out quite a few big turbo sti's. I'm not acting like you're making this shit up, I'm saying you're exhaggerating a little. That's all Anyways, before this gets into a flamefest, lets get back on topic: Good work TomsRSX, I'm really curious to see your future re-dyno with more pressure and smaller wheels. |
| Bookmarks |
| Tags |
| 800, gt40r, rsx, street, whp |
| Thread Tools | |
