#26 |
Boost Slut Krew Member #1
11.79 @ 120MPH - Bandimere Speedway, CO SuperFlow Dyno Tuned - 91 - 440whp 330wtq @ 18lbs - Thanks Brian! ![]() DynaPack Dyno Tuned - 91 - 525whp 340wtq ![]() My In-Depth Build Threads:http://forums.clubrsx.com/showthread.php?t=674689 |
#27 |
Master Member
Question. Why did you repalced the whole clutch? Why not just the clutch disk and get everything else resurfaced.
Boost Slut Krew Member #20 11.86 @ 116.97 1.77 60ft.... First Run Ever! HaLFAmAzinG120 (2:31:52 PM): fuck me like you hate me! HaLFAmAzinG120 (2:31:56 PM): oh wrong IM sorry LoSt1nY3RpAnTIEz (2:32:23 PM): O.O |
#28 |
The Architect™
St00pid Tuned 06' RSX Type-S, Peakboost Turbo Kit
w/ GT3076 Turbo 400whp & 280ft/lbs on pump partially tuned ![]() PeakBoost krewmember #1 Boost Slut Krew Member #4 Buy my turbo RSXhttp://forums.clubrsx.com/showthread.php?t=694002 |
#29 | |
#30 |
GM Engineer Wannabe
Pressure plates wear out too.
"If it ain't broke, you're not trying hard enough." |
#31 |
Master Member
I know that but he couldnt of had more than 2k miles on that seeing he doesnt really daily it
#32 |
It had 10k on it actually. I did the 85a mounts and the clutch before I did the turbo build. It had been on the car since Febraury of '08.
#33 |
Silver Bullet
sick as fuck
Spring 2010: Aftercooled Supercharged Nitrous Build/Trip/Showoff Thread
http://forums.clubrsx.com/showthread.php?t=689368 |
#34 |
70% Finished
#35 |
IPS K2 Owner #38
u probably have the cleanest car i have ever seen. i mean, all the blue trim from the new shift boot to the rbc mani. the lip kit is subtle, the hood is nice. the interior is clean. the turbo install job couldnt have been more perfect than if it was production like that from the factory.
now you have a built tranny! convert it to awd next (u no u got the $$$)
03 RRP=Tein=IPS=Eibach=ES=BuddyClub=GReddy=Hondata=Injen=JDM=Comptech=CompetitionClutch=ACT=Stoptech=Rota=BFGoodrich=CRSX=Ingals=RP=Mobile1EP |
#36 |
Went to the track tonight. I'll have pictures, videos, and the story of my evening up in a couple hours.
#37 |
Pictures of the Revo SS install from a month ago that I mentioned on Pg. 1.
![]() New Revo SS. ![]() Old B&M SS. I had to modify it to make it not bend the shifer cables, and in doing so, I had to get rid of the throw reduction. ![]() Got the new Revo all lubed. ![]() New Revo in. ![]() ![]()
#38 |
Updates from today.
Took the car to my dent guy this morning at 9am to have a handful of small dings taken out that had accumulated over the last few years. ![]() ![]() This afternoon I decided to take the car to the track. I ran my first run at around 4:40pm. I ran my 2nd pass at 4:50pm. I hot lapped the car and never shut it off and believe that's why I lost a tenth of a second on my second pass. I let the car cool off for about 45 minutes and made a third pass. After the third pass and looking over my datalogs, I was only building about 16psi of boost and I had been tuned up to 19. I raised the boost a tad and was hoping to cut down my 60 ft times a bit. I was very pleased with my first three passes since the install of the new trans. I was about to start the car to run my 4th pass of the day, I was getting excited that I would be able to run a bit more boost and it was getting dark out and cooling off outside. BUT my car wouldn't start. Pushed it out of the way and it wouldn't even turn over. Then we towed it to the pits and called a tow truck to come pick it up and take it home. I was a bit bummed out, I was hoping to cut another couple tenths off my time before the end of the night but oh well. It turned out to be the battery that shit out on me. After we got her home we got it running great again and I'm going to look into running a different battery setup tomorrow. I'm very happy with how she did for only 3 passes. I was also happy at how consistant I drove the car. Ran the same 60' time each of the three passes (which needs to be cut down a tenth of a second or two), ran the same trap speed on all three passes, and essentially the same E.T. on each pass if you consider the 2nd pass was hot lapped. ![]() Hopefully I can cut the E.T. down to an 11.5 or 11.6 if I can get my 60' time down a tenth or two and make some clean passes on 18psi or so. Some pics: ![]() ![]() ![]() The black rsx in this picture tried to do a burnout on street tires and just hopped around in place essentially. I believe he was running 16.7s all night. There was actually another ABP one there that I actually ran against on my 2nd pass. I believe he was running 16.9-ish. Sucks being N/A at 6,000ft altitude. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Like I said, she is all good and up and running again. Just gotta figure out a new battery setup in the next few days.
11.79 @ 120MPH - Bandimere Speedway, CO SuperFlow Dyno Tuned - 91 - 440whp 330wtq @ 18lbs - Thanks Brian! ![]() DynaPack Dyno Tuned - 91 - 525whp 340wtq ![]() My In-Depth Build Threads:http://forums.clubrsx.com/showthread.php?t=674689 Last edited by WooTIHaveATypeS; 09-17-2009 at 04:54 AM. |
#39 |
And a video of my third pass, hoping to get some REAL seat time as soon as possible.
http://videos.streetfire.net/video/T...New_707891.htm
#40 |
Master Member
Oh Well yeah haha. Nice runs man. Alot of possibilities now. Piston rod setup coming soon?
#41 | |
GM Engineer Wannabe
Nice shifter, I have bc ss and love it. What gear do you launch in? Antilag?
#42 |
Internet Crack Dealer
Steve,
we can make you a battery tray and move it to where it should be and you can run a full size one.
Chris Dye Club RSX, Inc. chris@clubrsx.com (866) CLUB-RSX http://www.clubrsx.com | http://www.clubep3.com | http://www.k-series.com All Motor Crew Sensei (aka member #13) |
#44 |
70% Finished
good shit steve!!!
#45 | ||||
#46 |
sweet, give me a reason to buy a tube bender.
#47 |
#49 | |
GM Engineer Wannabe
Right now my battery is sitting on an ACline (I have custom 1piece ic piping). Its tied in by bungee cords and really ghetto.
#50 | |
Hey teach me how to get a 1.70 60' on Sunday! We should race and get some really cool filmsies! John will be there to film.
| Bookmarks |
| Tags |
| build, deuce, part, peakboost, wootihaveatypes |
| Thread Tools | |
