Door locks, radio, remote lock wont work - Club RSX Message Board
Go Back   Club RSX Message Board > GENERAL RSX > Problems & Solutions RSX
Notices
Reply
Thread Tools
Old 12-18-2009, 03:22 PM   #1
xukinamx
New Member
xukinamx's Avatar
xukinamx is a jewel in the rough of c-rsx xukinamx is a jewel in the rough of c-rsx xukinamx is a jewel in the rough of c-rsx xukinamx is a jewel in the rough of c-rsx xukinamx is a jewel in the rough of c-rsx xukinamx is a jewel in the rough of c-rsx xukinamx is a jewel in the rough of c-rsx xukinamx is a jewel in the rough of c-rsx
Unhappy Door locks, radio, remote lock wont work
I have a 02 rsx base model. I was installing my aftermarket radio and doing all the basic installments untill my radio was not working after I plugged it in. I tried to get it working then my cars remote lock started not to work. is it the anti theft? then i asked my friend to look at the fuse box and i have no idea what he did and the door locks wont work now unless i turn on the car. what is going on with my car!!! WHAT DO I DO!!!
xukinamx is offline   Reply With Quote
Sponsored Links
Advertisement
Old 03-06-2010, 08:54 PM   #2
pumpkinz
Senior Member
pumpkinz is an unknown quantity on c-rsx
i have the same problem!!!!
one of the connections came loose, so I was working on
reconnecting the harness of aftermarket deck,
after putting it together, i have encountered the following problems:
1. the deck won't turn on at all
2. remote keyless entry does not work at all
3. auto lock inside the car only works when the car is turned on
how do i fix this???
Thanks in advance for your help guys!!!
pumpkinz is offline   Reply With Quote
Old 03-06-2010, 09:18 PM   #3
super fly
Member
super fly is a jewel in the rough of c-rsx super fly is a jewel in the rough of c-rsx super fly is a jewel in the rough of c-rsx super fly is a jewel in the rough of c-rsx super fly is a jewel in the rough of c-rsx super fly is a jewel in the rough of c-rsx super fly is a jewel in the rough of c-rsx super fly is a jewel in the rough of c-rsx
Check the fuses under the hood. Im not sure what number it is, maybe 9, I don't remember. It's a 10 amp one though.
Edit: Went outside and confirmed; fuse #9 under the hood.
super fly is offline   Reply With Quote
Old 03-06-2010, 09:23 PM   #4
BlAcuraRsx
My nose in your coke bag
BlAcuraRsx's Avatar
BlAcuraRsx is a jewel in the rough of c-rsx BlAcuraRsx is a jewel in the rough of c-rsx BlAcuraRsx is a jewel in the rough of c-rsx BlAcuraRsx is a jewel in the rough of c-rsx BlAcuraRsx is a jewel in the rough of c-rsx BlAcuraRsx is a jewel in the rough of c-rsx BlAcuraRsx is a jewel in the rough of c-rsx BlAcuraRsx is a jewel in the rough of c-rsx
^^ yes its a fuse thats blown. i cant remember what one it is either, cant hurt to check the underdash fuses either
Car and Driver: An engine that screams with pleasure, perfectly precise controls, tasteful execution of every detail, red instrument lighting that really works. A jewel of a car, uncorrupted by froufrou.
Sounds like they are talking about the RSX... oh wait.. they are.
BlAcuraRsx is offline   Reply With Quote
Old 03-07-2010, 02:17 PM   #5
xukinamx
New Member
xukinamx's Avatar
Yea I found I blown a fuse so I went and got one for the radio because the stock radio has the alarm. Although my drivers side door seems to not to work still. I think its the actuator but I have no idea how to open the door and see it
Old 03-07-2010, 03:45 PM   #6
0RSeX4
Senior Member
0RSeX4's Avatar
0RSeX4 is a jewel in the rough of c-rsx 0RSeX4 is a jewel in the rough of c-rsx 0RSeX4 is a jewel in the rough of c-rsx 0RSeX4 is a jewel in the rough of c-rsx 0RSeX4 is a jewel in the rough of c-rsx 0RSeX4 is a jewel in the rough of c-rsx 0RSeX4 is a jewel in the rough of c-rsx 0RSeX4 is a jewel in the rough of c-rsx
I have a type s with the stock bose stereo, and I can arm my alarm with my windows down. Reach inside pull up the locks and open the door and the alarm doesn't go off...??? any ideas on that?
0RSeX4 is offline   Reply With Quote
Old 03-07-2010, 03:48 PM   #7
DC5KIM
Naturally Aspirated
DC5KIM's Avatar
DC5KIM is a name not to mess with DC5KIM is a name not to mess with DC5KIM is a name not to mess with DC5KIM is a name not to mess with DC5KIM is a name not to mess with DC5KIM is a name not to mess with DC5KIM is a name not to mess with DC5KIM is a name not to mess with DC5KIM is a name not to mess with DC5KIM is a name not to mess with DC5KIM is a name not to mess with DC5KIM is a name not to mess with DC5KIM is a name not to mess with DC5KIM is a name not to mess with DC5KIM is a name not to mess with DC5KIM is a name not to mess with DC5KIM is a name not to mess with DC5KIM is a name not to mess with
You have to realize that the RSX doesnt come with an alarm.. if you want an alarm that chirps.. invest in VIPER
The red blinking light you see isnt an alarm, its Anti Theft for your Radio
DC5KIM is offline   Reply With Quote
Old 05-04-2010, 11:04 PM   #8
masterfoo
New Member
masterfoo is an unknown quantity on c-rsx
I had the same problem with my '06 RSX type S. I had installed an aftermarket stereo and was putting the stock stereo back in. When i hooked it up, no power to stereo. Then discovered that also no power to the power LOCK, but the power UNLOCK worked. Also, the courtesy lights that come on when you open the door weren't working, but the dome could be manually switched on. I think everything else worked: windows, moonroof, blinkers, horn, wipers, ignition, mirror motors, lights.
The fuse that blew in this case was a 7.5A under the hood, not under the dash. It's the one close the the spare fuses.
masterfoo is offline   Reply With Quote
Old 05-04-2010, 11:49 PM   #9
Ktec
<3
Ktec's Avatar
Ktec is an unknown quantity on c-rsx
STFU
you EPICFAIL
it takes 30 seconds for the STOCK ALARM (yes the RSX has an OEM alarm) to arm...SO open your window, lock the doors, wait over 30 seconds, THAN try opening your lock
waiting4
Ktec is offline   Reply With Quote
Old 06-07-2010, 02:40 AM   #10
ninesickzteen
Senior Member
ninesickzteen's Avatar
ninesickzteen is a jewel in the rough of c-rsx ninesickzteen is a jewel in the rough of c-rsx ninesickzteen is a jewel in the rough of c-rsx ninesickzteen is a jewel in the rough of c-rsx ninesickzteen is a jewel in the rough of c-rsx ninesickzteen is a jewel in the rough of c-rsx ninesickzteen is a jewel in the rough of c-rsx ninesickzteen is a jewel in the rough of c-rsx
my car doesnt unlock on a hot day when i use my stock remote transmitter keyfob. so i gotta walk up and unlock my car with the keys
ninesickzteen is offline   Reply With Quote
Old 01-09-2011, 01:25 PM   #11
djardy07
Member
djardy07's Avatar
djardy07 is a jewel in the rough of c-rsx djardy07 is a jewel in the rough of c-rsx djardy07 is a jewel in the rough of c-rsx djardy07 is a jewel in the rough of c-rsx djardy07 is a jewel in the rough of c-rsx djardy07 is a jewel in the rough of c-rsx djardy07 is a jewel in the rough of c-rsx djardy07 is a jewel in the rough of c-rsx
Having the same problem with my alarm, doors, and radio. Checked the fuse. I blew the "back up" fuse under the hood. Don't know if that relates to the problem, but when i try to replace the fuse it blows when i just touch the connector. Should i disconnect the battery before I install a new fuse?
djardy07 is offline   Reply With Quote
Old 01-09-2011, 04:38 PM   #12
djardy07
Member
djardy07's Avatar
Fixed it lol. It was 7.5 "backup" fuse. Its under the interior light 7.5 under the hood. Took the positive terminal off them put the fuse in.......worked like a charm
Old 10-22-2012, 07:12 PM   #13
uptnzfinest
Member
uptnzfinest is a jewel in the rough of c-rsx uptnzfinest is a jewel in the rough of c-rsx uptnzfinest is a jewel in the rough of c-rsx uptnzfinest is a jewel in the rough of c-rsx uptnzfinest is a jewel in the rough of c-rsx uptnzfinest is a jewel in the rough of c-rsx uptnzfinest is a jewel in the rough of c-rsx uptnzfinest is a jewel in the rough of c-rsx
I was trying to short the obd connection pins and instead of connecting pins 4 and 9 i connected something else and i heard something blow. I checked so many fuses that blew and nothing....so far replaced fuses 3 and 9.....if anyone has any input on this id appreciate it
uptnzfinest is offline   Reply With Quote
Old 10-23-2012, 05:26 PM   #14
nastyh
Member
nastyh's Avatar
nastyh is a jewel in the rough of c-rsx nastyh is a jewel in the rough of c-rsx nastyh is a jewel in the rough of c-rsx nastyh is a jewel in the rough of c-rsx nastyh is a jewel in the rough of c-rsx nastyh is a jewel in the rough of c-rsx nastyh is a jewel in the rough of c-rsx nastyh is a jewel in the rough of c-rsx
my deck sometimes twitches and it always ends up being the 7.5 amp backup fuse
nastyh is offline   Reply With Quote
Old 03-06-2013, 10:58 PM   #15
Phase rokk star
Rsx Lover
Phase rokk star's Avatar
Phase rokk star is a jewel in the rough of c-rsx Phase rokk star is a jewel in the rough of c-rsx Phase rokk star is a jewel in the rough of c-rsx Phase rokk star is a jewel in the rough of c-rsx Phase rokk star is a jewel in the rough of c-rsx Phase rokk star is a jewel in the rough of c-rsx Phase rokk star is a jewel in the rough of c-rsx Phase rokk star is a jewel in the rough of c-rsx
I know it's an old thread but I would like to know cuz I just in stalled an aftermarket headunit and my locks don't work with remote or when the car is off. I just wanna clarify is it just a blown fuse?
Phase rokk star is offline   Reply With Quote
Old 03-06-2013, 11:53 PM   #16
djardy07
Member
djardy07's Avatar
Smile
Yes, it was a blown fuse. This has happened to me more than once. Make sure to disconnect your battery before installing a new fuse under the hood.
Old 03-07-2013, 08:20 AM   #17
Phase rokk star
Rsx Lover
Alright awesome thanks! And by any chance do you know which fuse is it?
Old 03-11-2013, 03:27 PM   #18
djardy07
Member
djardy07's Avatar
I posted it ^^^. Read the thread.
Old 03-11-2013, 03:37 PM   #19
Phase rokk star
Rsx Lover
Yeah I read it and found it thanks
Old 04-07-2013, 03:57 PM   #20
cheechjpezlo
New Member
cheechjpezlo is a jewel in the rough of c-rsx cheechjpezlo is a jewel in the rough of c-rsx cheechjpezlo is a jewel in the rough of c-rsx cheechjpezlo is a jewel in the rough of c-rsx cheechjpezlo is a jewel in the rough of c-rsx cheechjpezlo is a jewel in the rough of c-rsx cheechjpezlo is a jewel in the rough of c-rsx cheechjpezlo is a jewel in the rough of c-rsx
what fuse did you guys use? I kept blown them out till I put in a 20.... then it smelt like burnt in the cabin
cheechjpezlo is offline   Reply With Quote
Old 04-07-2013, 04:09 PM   #21
rmadrigal
New Member
rmadrigal is a jewel in the rough of c-rsx rmadrigal is a jewel in the rough of c-rsx rmadrigal is a jewel in the rough of c-rsx rmadrigal is a jewel in the rough of c-rsx rmadrigal is a jewel in the rough of c-rsx rmadrigal is a jewel in the rough of c-rsx rmadrigal is a jewel in the rough of c-rsx rmadrigal is a jewel in the rough of c-rsx
Hey this happened to me in my 06 Acura RSx Type S but now i lost complete sound. like my Kenwood ddx770 turns on and everything but no sound, and i checked all my fuses all were good. Any one else get this??
rmadrigal is offline   Reply With Quote
Old 11-02-2013, 09:24 PM   #22
Monito
New Member
Monito is a jewel in the rough of c-rsx Monito is a jewel in the rough of c-rsx Monito is a jewel in the rough of c-rsx Monito is a jewel in the rough of c-rsx Monito is a jewel in the rough of c-rsx Monito is a jewel in the rough of c-rsx Monito is a jewel in the rough of c-rsx Monito is a jewel in the rough of c-rsx
same problem!
i have the same problem! tried installing a radio and i messed up. now the car wont lock (when its off) and the radio wont work. ive checked all but 2 fuses. scratch that i double checked them. the two i didnt check are surrounded by this yellow box and it wont let me take them out! they are both numbered 10. i was thinking it was one of the fuses marked 10 on it because it had a music note symbol when i checked the fuse cover. could it be the relays or anything else? maybe the 2 fuses i didnt check? all the 7.5 fuses were good. my main priority is getting the radio working again. im not that great with cars so any help would be greatly appreciated!
Monito is offline   Reply With Quote
Old 11-02-2013, 09:56 PM   #23
djardy07
Member
djardy07's Avatar
Fuse box under the hood. Labeled "back up". Read the thread. I think it was a 7.5. This has happened a couple times for me
Old 11-02-2013, 11:06 PM   #24
Monito
New Member
I'll make sure to try in the a.m. and I'll get back to you then. Thanks for replying!
Old 11-03-2013, 01:46 PM   #25
Monito
New Member
I checked the fuse box under the hood and did not see anything labeled "back up". I took a few pictures but I'm not even sure if you can post pictures here. I'm new to these forums.
Reply
Bookmarks
door , lock , locks , radio , remote , work
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
