Coolant inside Engine Block - Club RSX Message Board
Go Back   Club RSX Message Board > GENERAL RSX > Problems & Solutions RSX
Notices
Reply
Thread Tools
Old 01-04-2010, 09:11 PM   #1
AZNmanAndy
diy guy
AZNmanAndy's Avatar
AZNmanAndy has been a little shit in the past
im aware when u drain the radiator... there is still coolant in the block
so u fill it with distilled water and run the engine to flush out the coolant until it comes out clear
doesnt that mean there is water in the block still, so how can u completely drain the system?
what i want to know is:
1) how much coolant resides inside the block approximately?
2) if i flush with distilled water, then drain the radiator, isn't there water in the block now? even after draining
i just dont see how its possible to completely drain the system, i know that on other cars u can drain the coolant in the block by removing a bolt on the block, but i dont think the rsx is like that
when in doubt, vtec the fuck out!
AZNmanAndy is offline   Reply With Quote
Sponsored Links
Advertisement
Old 01-04-2010, 09:18 PM   #2
BlAcuraRsx
My nose in your coke bag
BlAcuraRsx's Avatar
BlAcuraRsx is a jewel in the rough of c-rsx BlAcuraRsx is a jewel in the rough of c-rsx BlAcuraRsx is a jewel in the rough of c-rsx BlAcuraRsx is a jewel in the rough of c-rsx BlAcuraRsx is a jewel in the rough of c-rsx BlAcuraRsx is a jewel in the rough of c-rsx BlAcuraRsx is a jewel in the rough of c-rsx BlAcuraRsx is a jewel in the rough of c-rsx
you could get an air compressor and blow air into it forcing out the coolant.
Car and Driver: An engine that screams with pleasure, perfectly precise controls, tasteful execution of every detail, red instrument lighting that really works. A jewel of a car, uncorrupted by froufrou.
Sounds like they are talking about the RSX... oh wait.. they are.
BlAcuraRsx is offline   Reply With Quote
Old 01-04-2010, 09:34 PM   #3
lksdG2
Senior Member
lksdG2's Avatar
lksdG2 is an unknown quantity on c-rsx
if you do blow it out be gentle, the cooling system is made for 20 psi max, which is less than 1/5 the pressure of a standard compressor.
it'd be easy to blow a seal out so be gentle
being slammed is like being powerful, if you have to say you are, you're not.
lksdG2 is offline   Reply With Quote
Old 01-04-2010, 09:37 PM   #4
BlAcuraRsx
BlAcuraRsx's Avatar
forgot to touch that subject... haha.
Old 01-05-2010, 02:36 AM   #5
Blown330
Blown is Better
Blown330's Avatar
Blown330 is on a distinguished road Blown330 is on a distinguished road
It isn't reasonably possible unless you pull the engine nor is it even necessary. OEM's don't even flush the engines all the way out when the run them in on the test stands before shoving them in your car. The minor amount left in the block isn't going to affect anything compared to how much your adding to refill the system.
Originally Posted by smiley4284
I suck blue and orange donkey cocks and let them finish in my asshole.
Blown330 is offline   Reply With Quote
Old 01-05-2010, 08:25 AM   #6
2010 admin
Guest
Posts: n/a
There is a drain plug in the block but it's only accessible if the tranny is out.
Old 01-05-2010, 11:25 AM   #7
Jay
likes to troubleshoot
Jay is an unknown quantity on c-rsx
The total coolant capacity (manual transmission) is 6.8 US quarts. That includes the radiator, engine block, coolant hoses, heater, and overflow reservoir. So drain what you can (including the overflow reservoir) and measure what came out. Subtract that from 6.8 quarts. That's how much is left in the engine.
You don't flush the RSX with distilled water because the Honda coolant is premix and the left-over water will dilute the coolant. Flushing isn't necessary. Just remember to get the engine warm and set the heater temp to max heat. That will make sure that coolant drains from the heater.
I removed my coolant plug from the block on my K20A3 to install an engine heater. It wasn't that tough, if you're really determined to get a little more coolant out, but it's not worth the trouble IMO.
base/auto Comptech air filter
Jay is offline   Reply With Quote
Old 01-05-2010, 03:39 PM   #8
Drewpreme
( ‾ʖ̫‾)
Drewpreme's Avatar
Drewpreme is not even half way to the top Drewpreme is not even half way to the top
Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top
agree with it not being worth the trouble, just flush out the most you can and fill her back up. not going to make any difference or changes.
Drewpreme is offline   Reply With Quote
Old 10-14-2010, 12:35 PM   #9
texm3x
Master Member
texm3x's Avatar
texm3x might be well recognized one day on c-rsx texm3x might be well recognized one day on c-rsx texm3x might be well recognized one day on c-rsx texm3x might be well recognized one day on c-rsx texm3x might be well recognized one day on c-rsx texm3x might be well recognized one day on c-rsx texm3x might be well recognized one day on c-rsx texm3x might be well recognized one day on c-rsx
i found coolant in my block aswell looks like its either comming from the throttle body or o-ring seal that goes around the bracket for the water pump is mounted.
i took off my intake TB the other day to clean iacv sensor bay. didn't think nothing of it till i saw my car leaking antifreeze with oil.then i remembered i saw antifreeze in the manifold when i cleaned the iacv sensor area to stop iddleing.also remembered to change out the o-ring seal on the bracket where the waterpump is mounted. don't know what it could be thats throwing coolant from the TB any help?????any suggestions???
Originally Posted by txfg2si View Post
So I had a tripped out dream that I was cruising with texmex in a old white car and for some reason we were falling from the sky lol so I grabbed the car phone to call 911 head off towards the sand dunes and of course Texmex was like you hungry?.....and I woke up lol
you still dreaming about my chorizo ??
texm3x is offline   Reply With Quote
Old 10-14-2010, 01:49 PM   #10
BlAcuraRsx
BlAcuraRsx's Avatar
9mo thread bump
Reply
Bookmarks
block , coolant , engine , inside
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
