#1 |
The power of Dreams
Ive searched, i need clutch advise
I need some reviews on clutches, i need to order asap, my mods are 02 type s, cai/rh/e and im debating on either the exedy organic clutch or perhaps a cc organic clutch. Im not planning on anymore power adders and i want a clutch thats going to grip better than my exedy oem, but still last. I feel like the cc stg 4 would be overkill with a stock flywheel and my mods, but im open for any reviews i have no experience with any other clutches besides oem exedy.
#3 |
Bańned
good choice. i have a stage 2 and love it
1 month infraction free ![]() PedoBear Crew - Member #59 Wheel gap can be compared to a vagina. The more fingers you can stick in the worse off you are |
#5 |
The power of Dreams
well if anyone cares, obviously this tread was an epic failure as most of mine are. i pulled my transmission out saturday morning. I dropped it off at a very reputable local honda. i handed them the bag of parts that i fished out of the transmission with a magnet through the top where shift linkage goes internally into the transmission. There was a 10 mm bolt that i pulled out of the bottom that i assumed held all the shift forks and whatnot to the rod that goes into the trans from the shift linkage, thankfully they verified that the 10mm bolt had backed itself out, nothing was damaged in the process, so i will be installing the transmission and new clutch an flywheel this weekend and i will post up a review of my opinion of the setup shortly after.
| Bookmarks |
| Tags |
| advise, clutch, searched |
| Thread Tools | |
