Go Back   Club RSX Message Board > STYLE > Lighting
Reply
Thread Tools
Old 03-04-2010, 02:03 PM   #1
BLACK04DC5
Senior Member
doin fogs this second need help
need a quicker answer about fog lights, i'm in the midst of instaling mine right now, using an oem switch harness. Steps 58 through 60 in specific. Tell me If i have it right. I disconnect the twelve pin connector on the vehicle harness. I then connect the male 12 pin connector of my switch harnes to the female 12 pin connector of the vehicle harness, and then the male connector of my vehicle harness to the female connector on my switch harness. Also wondering, the under the hood harness i sort of had to make myself, so assuming it was faulty, would the green light on the fog switch still come on?
thanks
BLACK04DC5 is offline   Reply With Quote
Old 03-04-2010, 07:07 PM   #2
BlAcuraRsx
My nose in your coke bag
BlAcuraRsx's Avatar
the green light on the swtich will still come on, because its a different wire for ilumination.
Car and Driver: An engine that screams with pleasure, perfectly precise controls, tasteful execution of every detail, red instrument lighting that really works. A jewel of a car, uncorrupted by froufrou.
Sounds like they are talking about the RSX... oh wait.. they are.
NUTS IN YO INTAKE CREW #2
BlAcuraRsx is offline   Reply With Quote
Old 03-05-2010, 05:19 PM   #3
BLACK04DC5
Senior Member
do you know which connector on the harness would control the green light because its not coming on so i have reason to believe my fog problem is due to the switch harness. the red does come on with the dashboard so i know that the switch is indeed connected, and it tells me i did somthing right, sorry for the dumb questions just rele stumped.
Old 03-05-2010, 07:26 PM   #4
BlAcuraRsx
BlAcuraRsx's Avatar
oh shit, sorry i had that backwards, i was thikning the red light is the green light. can you post a pic of your harness so i can get a visual on what your working with
Old 03-06-2010, 10:34 AM   #5
BLACK04DC5
Senior Member
its an oem switch harness, and the under the hood harness i made myself pretty much. The red light that illuminates the fog symbol works, but not the green bar above the symbol, similar to the one on the cruise control button. Does anyone know which connector on the harness would affect the green light, just trying to trouble shoot cause clearly the switch harness isn't hooked up right if the green light doesnt come on when I press it.
Old 03-09-2010, 11:31 AM   #6
BLACK04DC5
Senior Member
still wonderin bout this, would rele help me to trouble shoot it, if not I'm just going to hook them up to the parking lights
Old 03-09-2010, 09:19 PM   #7
BlAcuraRsx
BlAcuraRsx's Avatar
can you get a pic of all your wires? ill try to help you out that way, but i need to see the harness's
Old 03-09-2010, 11:20 PM   #8
BLACK04DC5
Senior Member
i ended up getting pissed off and just wiring it to my parking lights with a relay. It tells me that my under the hood harness is good, and I was doing something wrong with my Dashboard harness. I might just sell the harness and switch. the fogs work perfect right now, and part of me says, don't fix what isn't broken, but at the same time i'd like to have it wired as if it was oem. thanks for the help neway
Reply
Bookmarks
doin, fogs
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
