Old 03-05-2010, 08:28 PM   #1
My06_types
06 TypeS
My06_types's Avatar
ACL bearings.
What would people prefer when rebuilding a stock motor being boosted.
ACL race or standard bearings or acura oe bearings?
http://www.clubrsx.com/browse/cr/?fM...arch=&limit=30
ASM W/White stockies Showoff::
http://forums.clubrsx.com/showthread...9947:thumbsup:
Build thread::
http://forums.clubrsx.com/showthread.php?t=706345
My06_types is offline   Reply With Quote
Old 03-06-2010, 07:14 AM   #2
My06_types
06 TypeS
My06_types's Avatar
Noone has any info on the acl bearings? Has anyone used them and have emperience with the acl bearings?
Build thread::
Old 03-06-2010, 08:27 AM   #3
Fade2Black
OoooOOoo a red ball
Fade2Black's Avatar
Fade2Black must be an admin because here is no way they could have reached this amount on their ownFade2Black must be an admin because here is no way they could have reached this amount on their ownFade2Black must be an admin because here is no way they could have reached this amount on their ownFade2Black must be an admin because here is no way they could have reached this amount on their ownFade2Black must be an admin because here is no way they could have reached this amount on their ownFade2Black must be an admin because here is no way they could have reached this amount on their own
Fade2Black must be an admin because here is no way they could have reached this amount on their ownFade2Black must be an admin because here is no way they could have reached this amount on their ownFade2Black must be an admin because here is no way they could have reached this amount on their ownFade2Black must be an admin because here is no way they could have reached this amount on their ownFade2Black must be an admin because here is no way they could have reached this amount on their ownFade2Black must be an admin because here is no way they could have reached this amount on their ownFade2Black must be an admin because here is no way they could have reached this amount on their ownFade2Black must be an admin because here is no way they could have reached this amount on their ownFade2Black must be an admin because here is no way they could have reached this amount on their ownFade2Black must be an admin because here is no way they could have reached this amount on their ownFade2Black must be an admin because here is no way they could have reached this amount on their ownFade2Black must be an admin because here is no way they could have reached this amount on their ownFade2Black must be an admin because here is no way they could have reached this amount on their ownFade2Black must be an admin because here is no way they could have reached this amount on their ownFade2Black must be an admin because here is no way they could have reached this amount on their ownFade2Black must be an admin because here is no way they could have reached this amount on their ownFade2Black must be an admin because here is no way they could have reached this amount on their ownFade2Black must be an admin because here is no way they could have reached this amount on their own
ACL's are a standard size bearing, that are about the equivalent to a Honda green bearing. So unless you are looking to get your crank machined to the ACL bearings they aren't worth it over using OEM. OEM crank main and rod journal sizes vary this is why honda offers different thickness to get the clearance the stock motor is spec'd out to have.
Fade2Black is offline   Reply With Quote
Old 03-06-2010, 11:05 AM   #4
My06_types
06 TypeS
My06_types's Avatar
Ok thanks also do you still make those battery brackets for in front of the pass tire?
Build thread::
Reply
Bookmarks
acl, bearings
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
