#1 |
bikeracks are for bikes
anyone?> wired front turn signals to parking lights?
i tried searching the forums...
im wondering if anyone has tried wiring the front turn signals to stay on as parking lights? i know its a stupid little mod, but i think the turn signal would look pretty hot if it stayed on as a parking light also. ive never seen it done, but if no one else has a DIY, then im doing it.
VT Straightedge Crew
#2 |
Section 8
you'll blow a fuse
#3 |
Senior Member
haha, i havent gotten to taking the signal connector out yet to see wat i can do but yea im thinking of a way myself too. something like the tail light conversion right?
so itll stay on and blink. if u find out b4 me, be sure to let me know. and ill let you know. |
#4 |
oh. have you done this before?
as long as you run the correct wattage bulb, couldnt you just swap the wires from the side marker lights to the turn signal lights and vice versa? cuz the side marker lights blink too, right? im reffering to the 05-06 headlights btw. any advice would be helpful. thanks
#8 | |
Senior Member
but yea i did think of that i dea too. changing the power wires. but yea the signal watts might be too high for the side markers. but hey it might work? higher watt bulb for the side marker? and it u blow a fuse, then change that too. hahaha i guess we can test things out. ill pull out the signal this weekend. kinda tired on working on the car. just lowered it yesterday and now im tired but cant stop staring at it. hahahaha |
#9 |
yea i think tomarow i will try something. i looked up the wattage- 4.9 watts for the side marker and 27 watts for the turn signal. im assuming it might be as easy as swapping the bulbs, since they are both wedge style, and then extending the wires from the sidemarkers to the blinkers, and vice versa. if anything i might have to dick around with the bulb sockets to get the bulbs to fit properly. seems pretty straight forward, and im surprised there isnt already a DIY on this. it seems like more people would have thought of this. i cant wait til people wake up in the morning and start bashing this thread claiming im an idiot because i dont blow my money jdm parts and bolt them on my car like everyone else! these forums tend to frown on people looking to try something new.
#10 |
Senior Member
hahaha yea true that.
will hell, if they are both wedge bulbs, then thatll be easy to swap. but i havent seen the connector to the signal like i said. the side mark has this kind of an extension from the connector to the bulb. just looking form the outside, the signal bulb looks pretty damn big compared to the side marker's tiny bulb. but it might just be the head light. good luck reaching for that signal? looks hard to get to. |
#13 |
I want an S4...
I did it. My sidemarkers are on when i have my parking lights on. Then when I use my turn signal, they blink off then back on... etc etc. Looks tight. No blown fuses for like... 5 years??
#14 | |
jumper wire or something? did you have to change the bulbs to a different wattage? lemme know holmes!!
#15 |
toot it and boot it!
#17 | |
so youre saying take the taillight connector from the turn/parking bulb and use it up front, splicing the parking light wire into the parking light on the corner? im gunna check on this as soon as possible and let you guys know. anyone else think this is a neat mod, or useless? if i dont get any good feedback then im not gunna bother doing a write up.
#18 |
Senior Member
no, thats not wat i ment. becuase wat you're thinking of doing wont make a difference. hahaha
if the connectors are the same, then you can do the rewire just like the tail light rewire.....get it? unless thats what you ment already. hahaha |
#19 |
i guess that way makes more sense. i thought you meant the other way, and it didnt make much sense to do it that way, but it seams like it would work. but def better the other way.lol
#20 |
Senior Member
have you already taken out the front signals? if so the compare the two. im to lazy to even mess with it. i think ill try to find the time if i remember tomorrow. i hope its the same.
if anyone knows. let us know. thanks |
#23 |
BoooYa
found a link based on the 05-06 tail light conversion that may help - try wiring one of your wires for the light you want on all the time to the parking light wire (tap into that)
and the other wire to the turn signal wire (tap into that) Net effect = light on all the time and flashes when signalling. I'd recommend low voltage LEDs. Check bottom of page for side notes. Let me know if it works! |
#24 |
Senior Member
kinda confusing but i think i get wat your saying. so instead of the side markers. just do it with the fron turn signals. but the thing is the front and rear wont blink together. but that wouldnt matter anyways. ill read into it. did you aleady figured it out, how to wire it up? because we're not using side markers.
#25 |
Senior Member
i dont think itll work. this is a wiring for a seperate light.(side markers)
if you wire it to the parking light. itll send power to the signals. even if you signal, it wouldnt make a difference because its already on. i dont think itll blink. |
| Bookmarks |
| Tags |
| anyone>, front, lights, parking, signals, turn, wired |
| Thread Tools | |
