#1 |
Man ah Badman
Squeaking in the rear
Hey everyone having a bit of problems recently...i've never had it before but everytime I hit a little bump or go over a little hill the rear of the car is always squeaking...it's starting to get annoying and I don't really know what's the cause of it..I'm on stock suspension...car isn't lowered but I did put in some skunk2 lca's and the progress 24 mm adjustable sway bar with endlinks...the problems never happened when I had everything stock...could it be the lca's or is the suspension going bad??
The car has 66,000 miles on it...thanks in advance
06 BASE VBP/ AEM V2 SHort Ram Intake/ HKS HI-POWER Catback Exhaust/ Progress Rear Tie Bar/Sway Bar/ Skunk 2 LCA's and still a long way to go ![]()
#3 |
Man ah Badman
Sorry to sound like such a noob but I don't usually do my own installs on the car...butthe bushings are the 2 gold things that the bar goes through right...and how hard is it to remove...does it involve any profession tools or the basics...or can I just spray some wd40 over it...thanks for the help bro
#4 |
K24 > K20
you might be able to get it to stop squeaking by spraying something on it, WD-40 wouldnt be my choice, you want something like grease.
Otherwise you just need to remove those 2 gold brackets, then slip the rubber bushings off, clean and re-grease between the sway and rubber bushing, then put it all back together. Should take you no more than 20min. |
#5 |
Man ah Badman
What would be your choice of grease to put on if you don't mind me asking
#6 |
My sex is on fire!
Lithium or Silicone grease.
Or you can just turn up the radio to solve you problem.
Coilovers - Koni Yellow with GC (400/550): Sways - 25.4mm front, Progress 24mm rear: Strut bars - took the fucking things off!: Bushings - ES front and rear poly: Brakes - ATE Superblue brake/clutch fluid: Camber - SPC camber kit: Race rims - 15x7 Kosei K-1 powdercoated black wrapped in Falken Azenis: Shifter - OBX |
| Bookmarks |
| Tags |
| rear, squeaking |
| Thread Tools | |
