Old 03-18-2010, 08:03 AM   #1
Imagine3
Senior Member
Imagine3's Avatar
02 RSX Tape won't eject
I woke up this morning and unfortunately the tape deck will not read the tape in it and I cannot get it to eject. I am stuck in the past and have the stock Bose 6 disc changer (in dash) and use a tape for my ipod.
Any ideas?
Imagine3 is offline   Reply With Quote
Old 03-18-2010, 08:04 AM   #2
cl0ckw0rksi02
Modelrator
cl0ckw0rksi02 must be an admin because here is no way they could have reached this amount on their owncl0ckw0rksi02 must be an admin because here is no way they could have reached this amount on their owncl0ckw0rksi02 must be an admin because here is no way they could have reached this amount on their owncl0ckw0rksi02 must be an admin because here is no way they could have reached this amount on their owncl0ckw0rksi02 must be an admin because here is no way they could have reached this amount on their owncl0ckw0rksi02 must be an admin because here is no way they could have reached this amount on their own
cl0ckw0rksi02 must be an admin because here is no way they could have reached this amount on their owncl0ckw0rksi02 must be an admin because here is no way they could have reached this amount on their owncl0ckw0rksi02 must be an admin because here is no way they could have reached this amount on their owncl0ckw0rksi02 must be an admin because here is no way they could have reached this amount on their owncl0ckw0rksi02 must be an admin because here is no way they could have reached this amount on their owncl0ckw0rksi02 must be an admin because here is no way they could have reached this amount on their owncl0ckw0rksi02 must be an admin because here is no way they could have reached this amount on their owncl0ckw0rksi02 must be an admin because here is no way they could have reached this amount on their owncl0ckw0rksi02 must be an admin because here is no way they could have reached this amount on their owncl0ckw0rksi02 must be an admin because here is no way they could have reached this amount on their owncl0ckw0rksi02 must be an admin because here is no way they could have reached this amount on their owncl0ckw0rksi02 must be an admin because here is no way they could have reached this amount on their owncl0ckw0rksi02 must be an admin because here is no way they could have reached this amount on their owncl0ckw0rksi02 must be an admin because here is no way they could have reached this amount on their owncl0ckw0rksi02 must be an admin because here is no way they could have reached this amount on their owncl0ckw0rksi02 must be an admin because here is no way they could have reached this amount on their owncl0ckw0rksi02 must be an admin because here is no way they could have reached this amount on their owncl0ckw0rksi02 must be an admin because here is no way they could have reached this amount on their own
whats a tape?
★★Ep Crew / XBL: cl0ckw0rksi02★★
FACELIFT SSM Crew #1
Guerrilla Royale / Vimeo
G.O.A.T. Status Crew
cl0ckw0rksi02 is offline   Reply With Quote
Old 03-18-2010, 08:15 AM   #3
Imagine3
Senior Member
Imagine3's Avatar
Originally Posted by cl0ckw0rksi02 View Post
whats a tape?
Its that old outdated piece of plastic that used to have music on it. Came after the 8-Track and before the CD. People used to stand on corner with huge music playing devices on their shoulders blaring music that was on these things.
Maybe I should find an 8-Track player that would fit in my car and jive to some Simon and Garfunkel. lol
Old 03-18-2010, 08:19 AM   #4
WONG_89
B a n n e d
WONG_89's Avatar
WONG_89 is a glorious c-rsx memberWONG_89 is a glorious c-rsx memberWONG_89 is a glorious c-rsx memberWONG_89 is a glorious c-rsx memberWONG_89 is a glorious c-rsx memberWONG_89 is a glorious c-rsx memberWONG_89 is a glorious c-rsx memberWONG_89 is a glorious c-rsx memberWONG_89 is a glorious c-rsx memberWONG_89 is a glorious c-rsx memberWONG_89 is a glorious c-rsx memberWONG_89 is a glorious c-rsx memberWONG_89 is a glorious c-rsx memberWONG_89 is a glorious c-rsx memberWONG_89 is a glorious c-rsx member
Stick jn a pin or hairclip or something to the middle bottom area. Be careful not to fuck up thr tape reader thing though. If u take a look you'll see a little thingy there holding the tape in. Gently pry it and press eject. Unless your eject button Is ducked up... This should work.
FYI my friend and I did this pm his type s and it worked. Not responsible for anything
WONG_89 is offline   Reply With Quote
Old 03-18-2010, 08:28 AM   #5
Imagine3
Senior Member
Imagine3's Avatar
Thanks. I was pretty sure I would have to jimmy it out. I was hoping though that I could maybe disconnect it an then when it receives power again, it might recognize there is a tape in it.
When I press the eject button now, nothing happens and when I press the tape button, nothing happens most of the time but every so often, I will get a "TAPE ERROR" on the screen. or it might be "TAPE EROR" or something like that.
Old 03-18-2010, 08:31 AM   #6
cl0ckw0rksi02
Modelrator
what about disconnecting the battery for a bit?
Old 03-18-2010, 09:41 AM   #7
Imagine3
Senior Member
Imagine3's Avatar
Well, I looked under the tape and tried to jimmy it out, the reason it won't eject is there is a spring from somewhere (probably what pushes the tape up to eject) laying on its side and rolling around. Guess it is time for a new stereo.
Anybody know if a later model RSX stereo has an AUX jack in it and would fit an '02? I like the stock look but I unfortunately think I am going to have to get an aftermarket radio and a kit (http://www.clubrsx.com/cr/MET-99-7867.html)
Old 03-21-2010, 09:54 PM   #8
luk2004
Master Member
luk2004's Avatar
Nope the 05/06 rsx also have a 6cd with tape player bose system with no aux input.
2005 Magnesium Metallic Type S
2008 Honda CBR 600rr
Motorcycle Crew #599
luk2004 is offline   Reply With Quote
Old 03-23-2010, 03:24 PM   #9
himynameismatt
Senior Member
himynameismatt's Avatar
I think this is a sign/excuse to upgrade your stereo.
Originally Posted by Jay Leno
Race Car driving is like sex all men think they're good at it
'03 NBP RSX Type-S
himynameismatt is offline   Reply With Quote
Reply
Bookmarks
eject, rsx, tape
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
