Leaking Transmission Fluid from Driveshaft area - Club RSX Message Board
Go Back   Club RSX Message Board > GENERAL RSX > Problems & Solutions RSX
Notices
Reply
Thread Tools
Old 03-21-2010, 06:18 PM   #1
n19htmare
Member
n19htmare is an unknown quantity on c-rsx
Hey guys, Today I was cleaning my CAI air filter and noticed a lot of oil under my car. Upon further inspection, it looks like I'm leaking transmission fluid from where the RIGHT side driveshaft goes into the transmission.
What parts do I need (seals im assuming) and how hard is it to DIY?
Thanks in advance.
n19htmare is offline   Reply With Quote
Sponsored Links
Advertisement
Old 03-21-2010, 08:02 PM   #2
freerider_4life
I make dyslexia sexy
freerider_4life's Avatar
freerider_4life is an unknown quantity on c-rsx
Sounds like an output shaft seal, I've done mine a few times. Its relatively easy to do. Take off the axle nut,(either drop the BJ or loosen the arm off) drop the drive shaft, old seal out, new seal in and throw it back together.
freerider_4life is offline   Reply With Quote
Old 03-21-2010, 08:50 PM   #3
Drewpreme
( ‾ʖ̫‾)
Drewpreme's Avatar
Drewpreme is not even half way to the top Drewpreme is not even half way to the top
Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top
much easier to remove the two bolts on the bottom of the strut to get the axle out. removing that lower ball joint can be hell.
Drewpreme is offline   Reply With Quote
Old 03-21-2010, 08:57 PM   #4
n19htmare
Member
as far as the part goes.
http://www.acuraoemparts.com/delray/...All&vinsrch=no
i looked there and did not see the seal or anything...what do i need?
Old 03-21-2010, 09:27 PM   #5
Drewpreme
( ‾ʖ̫‾)
Drewpreme's Avatar
manual or automatic? just to be clear, it is the passenger side seal that is leaking? where the half shaft goes into the transmission?
Old 03-21-2010, 10:03 PM   #6
n19htmare
Member
6 spd Manual. yes, passenger side where the half-shaft goes into the transmission.
Old 03-22-2010, 09:48 AM   #7
03-GMC
Searching for 12's
03-GMC's Avatar
03-GMC is a jewel in the rough of c-rsx 03-GMC is a jewel in the rough of c-rsx 03-GMC is a jewel in the rough of c-rsx 03-GMC is a jewel in the rough of c-rsx 03-GMC is a jewel in the rough of c-rsx 03-GMC is a jewel in the rough of c-rsx 03-GMC is a jewel in the rough of c-rsx 03-GMC is a jewel in the rough of c-rsx
Make sure you clean out where the seal goes really good. Also make sure you dont put it in to far or the it will eat up the seal almost instantly. I had this problem on the GF's car went through two seals before i got it right. Should only take you an hour tops to do it with a break here and there. Also if the seal dont work it could be a bearing and thats a pricey fix. Seal is $10 from the dealer.
Good luck
2003 GMC Duramax
EFI tuned, Twins, Suncoast Trans (12.78 @ 106 Fuel Only 4500' elevation) Daily Driven
GF's Car- 2002 RSX Type S
Injen CAI and Catback exhaust
03-GMC is offline   Reply With Quote
Old 03-25-2010, 11:35 AM   #8
n19htmare
Member
anyone know the part number or a name for the seal???
Edit 1:
ok I think it's part number 91206-PHR-003
Dealer price is a whopping $16.60
Online price from acura dealer, $6.60.
How is the local dealer charging twice the retail of this seal???? (Retail is only $8.80)
edit 2:
haha as soon as i mentioned i knew the list price was 8.80 and why the dealer was charging 2x above retail they immediately told me they can do $8.80.
Old 03-25-2010, 11:38 AM   #9
03-GMC
Searching for 12's
03-GMC's Avatar
I think its called a intermediate shaft seal.... i could be wrong though
2003 GMC Duramax
Old 03-25-2010, 11:47 AM   #10
03-GMC
Searching for 12's
03-GMC's Avatar
Ok its just called a differential oil seal
2003 GMC Duramax
Old 03-25-2010, 12:05 PM   #11
n19htmare
Member
Thanks
dealer just called it a shaft seal (either passenger side or driver side)
Here are the part numbers for future reference.
Driver side shaft Oil seal: 91205-PL3-B01 List price is $10.50
Passenger side shaft oil seal: 91206-PHR-003 List Price is $8.80
Dealer price will be higher, just tell them you'll pay list price only.
Old 03-25-2010, 01:29 PM   #12
03-GMC
Searching for 12's
03-GMC's Avatar
Originally Posted by n19htmare View Post
Thanks
Yeah I was going off what AllData.com said it was.
2003 GMC Duramax
Old 03-25-2010, 08:44 PM   #13
n19htmare
Member
Thanks for your help. I just posted the part numbers incase someone else is looking for it.
Reply
Bookmarks
area , driveshaft , fluid , leaking , transmission
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
