need help with front motor mount install - Club RSX Message Board
Go Back   Club RSX Message Board > GENERAL RSX > Problems & Solutions RSX
Notices
Reply
Thread Tools
Old 06-15-2010, 05:43 PM   #1
SMaDC5
Senior Member
SMaDC5's Avatar
SMaDC5 is a jewel in the rough of c-rsx SMaDC5 is a jewel in the rough of c-rsx SMaDC5 is a jewel in the rough of c-rsx SMaDC5 is a jewel in the rough of c-rsx SMaDC5 is a jewel in the rough of c-rsx SMaDC5 is a jewel in the rough of c-rsx SMaDC5 is a jewel in the rough of c-rsx SMaDC5 is a jewel in the rough of c-rsx
so i found the thread for installing the motor mounts but it doesnt cover the ftont mount.. i have the OE mount off and im trying to get the new innovative mount in and it seems like the new mount is to fat to fit in between the 2 braces.. any ideas on how to get it in between? im in the middle of the install right now.. any help is appreciated. thanks
SMaDC5 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 07-02-2010, 02:53 PM   #2
STINKY_DC5
ORALE!!!!
STINKY_DC5's Avatar
STINKY_DC5 is a jewel in the rough of c-rsx STINKY_DC5 is a jewel in the rough of c-rsx STINKY_DC5 is a jewel in the rough of c-rsx STINKY_DC5 is a jewel in the rough of c-rsx STINKY_DC5 is a jewel in the rough of c-rsx STINKY_DC5 is a jewel in the rough of c-rsx STINKY_DC5 is a jewel in the rough of c-rsx STINKY_DC5 is a jewel in the rough of c-rsx
It's F'd up that no one helped. I tried following this linkhttp://forums.clubrsx.com/showthread...ighlight=mount but just used it as a reference. I used some mad strength and a little of WD40 on the sides and squeezed right in. It was a B 1 T C H! make sure all your other mounts are somewhat loose. GL
VIVA LA RAZA!!
K-Pro fund, $0
STINKY_DC5 is offline   Reply With Quote
Old 04-14-2013, 09:36 PM   #3
ChenzoDC5
Senior Member
ChenzoDC5's Avatar
ChenzoDC5 is a jewel in the rough of c-rsx ChenzoDC5 is a jewel in the rough of c-rsx ChenzoDC5 is a jewel in the rough of c-rsx ChenzoDC5 is a jewel in the rough of c-rsx ChenzoDC5 is a jewel in the rough of c-rsx ChenzoDC5 is a jewel in the rough of c-rsx ChenzoDC5 is a jewel in the rough of c-rsx ChenzoDC5 is a jewel in the rough of c-rsx
Hey guys I know this is an old thread but I'm currently Doing the exact same thing, but I can't seem to get all 3 bolts to line up plus the one in the middle..any advice?
'02 DC5-R Race Car
'84 Corvette
'95 Eclipse GS-T
'07 VW GTI
'83 Starion Turbo New Project
'13 Focus ST Daily Driver
ChenzoDC5 is offline   Reply With Quote
Old 04-15-2013, 06:43 AM   #4
2010 admin
Guest
Posts: n/a
1.) Loosen the subframe and drop down the front, to give you plenty of clearance.
2.) Grease up both sides of the poly bushing as well as the inner faces of the subframe mount "ears" with some high pressure grease. Not WD-40, actual grease.
3.) Install the mount to the tranny/motor, then use your hydraulic jack to press the subframe back up into place. Once or twice, I have needed to use a prybar to slightly spread the "ears" a bit.
Old 04-14-2014, 11:56 AM   #5
RHD dc5r
To Each His Own
RHD dc5r is a jewel in the rough of c-rsx RHD dc5r is a jewel in the rough of c-rsx RHD dc5r is a jewel in the rough of c-rsx RHD dc5r is a jewel in the rough of c-rsx RHD dc5r is a jewel in the rough of c-rsx RHD dc5r is a jewel in the rough of c-rsx RHD dc5r is a jewel in the rough of c-rsx RHD dc5r is a jewel in the rough of c-rsx RHD dc5r is a jewel in the rough of c-rsx
Is the front mount actually needed? I see hasport only sells 3 mounts (two sides and rear) with their kit for the RSX.
2000 CW JDM RHD ITRx
DC5 small tube ASP header FS:
http://forums.clubrsx.com/showthread.php?t=1104338
RHD dc5r is offline   Reply With Quote
Old 06-15-2014, 08:29 PM   #6
daje00
Master Member
daje00 is a jewel in the rough of c-rsx daje00 is a jewel in the rough of c-rsx daje00 is a jewel in the rough of c-rsx daje00 is a jewel in the rough of c-rsx daje00 is a jewel in the rough of c-rsx daje00 is a jewel in the rough of c-rsx daje00 is a jewel in the rough of c-rsx daje00 is a jewel in the rough of c-rsx daje00 is a jewel in the rough of c-rsx
Yes it is needed. There's a big difference without it in terms of engine movement back and forth.
05 Rsx S k20z1
Ktuner end User (210/158)
Invidia RH, Exedy Stage 1 Clutch
Vibrant Stealth Muffler
Injen CAI , Hondata IMG
VibraTechnics rear mount
daje00 is offline   Reply With Quote
Old 06-16-2014, 04:25 PM   #7
Kamakaze02
Member
Kamakaze02's Avatar
Kamakaze02 is a jewel in the rough of c-rsx Kamakaze02 is a jewel in the rough of c-rsx Kamakaze02 is a jewel in the rough of c-rsx Kamakaze02 is a jewel in the rough of c-rsx Kamakaze02 is a jewel in the rough of c-rsx Kamakaze02 is a jewel in the rough of c-rsx Kamakaze02 is a jewel in the rough of c-rsx Kamakaze02 is a jewel in the rough of c-rsx
is this really true!!?! then why do they only have 3 of them in the kits?
Kamakaze02 is offline   Reply With Quote
Old 06-16-2014, 04:37 PM   #8
daje00
Master Member
Some of the kits have 4. Plus those are a lot stiffer so the engine doesn't move as much
05 Rsx S k20z1
Old 06-16-2014, 04:53 PM   #9
Kamakaze02
Member
Kamakaze02's Avatar
so what you are saying that the front mount is still needed to be swapped out? (like i have innovative 60a driver, pass, rear, with stock front. should i be looking for a innovative front mount?
Old 06-17-2014, 07:36 PM   #10
daje00
Master Member
I'd keep the stock front
05 Rsx S k20z1
Reply
Bookmarks
front , install , motor , mount
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
