MTEC Shifter springs: Chota endorsed, so you know this shit is epic. - Club RSX Message Board
Go Back   Club RSX Message Board > PERFORMANCE BASICS RSX > Transmission & Drive Train RSX
Notices
Reply
Thread Tools
Old 07-29-2010, 05:16 AM   #1
Dr.Honda
1 of 1
Dr.Honda's Avatar
Dr.Honda is an unknown quantity on c-rsx
Let's just get this out of the way...
If you don't want to end up being a ricer (like shown above), you're going to need these springs. Nothing is worse than grinding 2nd gear, hitting that stupid 3rd gear wall, or just straight up botching a shift and ending up driving in reverse, giving the finger to your bro, with the top down. Forget that shit.
On a serious note (because I hate ricers, as it's my job), I've installed these on my weekend/race car toy and all I can say is amazing things.
But a few things to honestly consider before my input on the springs themselves:
1) The ability to clock a fast sector/lap time is not just dependent on how well the car is setup but how well the driver can drive. One main thing people forget to address is driver interface.
If the car doesn't give good feedback to the driver, it makes it that much harder to clock a fast time. It doesn't matter how fast the car is, if no one can drive it at 100%, it might as well be not as highly tuned, (the performance potential is wasted). MANY things contribute to driver interface and this is one of the main ones.
2) Overall positive driving feel is the main reason car enthusiasts like to drive cars. A lot of the time, race cars are miserable to drive and are only built for the sole purpose of competing and lap times. A faster car isn't necessarily more fun to drive, at a certain point it becomes more of a pain to live with. Often times, a slow car is fun to drive (if you know what you're doing) just because it has good feel.
A good example would be the S2000. It's definitely not the fastest thing on four wheels but it just feels so damn good to drive. Everything about the car is great, including the driver interface and the damn shifter is probably one of the best in the industry. It has won many awards and best motoring still claims it to be the most fun to drive production car, much more fun than cars with a lot more power/speed.
The point is, is that the driving FEEL is the MAIN reason the S2000 receives such high acclaims and these springs improve the FEEL of the car bringing similar positive feedback to the driver which doesn't necessarily mean the car is faster (even though you can drive it better, which does make it faster) but the overall driving pleasure is improved making it more enjoyable on a winding road or just cruising around.
Moving on from the whole philosophical aspect of things and back to the actual springs...
www.mtecind.com
Please check out the manufacture's website above for pictures, DIY install and other information on the springs.
1) The springs are installed on the shifter assembly located inside the transaxle. The transaxle does not need to be dropped to install the springs, the install can be easily performed with it in the car. All that is required is simple hand tools, Hondabond and a firm grasp of basic automotive servicing.
2) The springs influence the lateral location and feel of the shifter. Meaning as you move it left and right, the stiffer springs resist the normal motion more than the factory springs.
Overall change in feel are as follows:
Driver knowledge of which gear the shifter has selected is more acute. When selecting gears like 1st, 2nd, 5th (and 6th, if you're cool like me), the shifter requires more effort than stock which means the driver is more aware of which gear is selected. When selecting gears like 3rd or 4th, the shifter jumps towards it's center position (as it normally would) but with more force.
Again, this gives the driver better feel as for what gear they have selected and better feel for what gear they WANT to select and the hand motion required to select that gear quickly, precisely and with zero fuss.
Side benefits to this are:
-Much less chance of a miss-shift
-More manly (Chuck Norris has these in his trans).
-The precision given in shift feel helps reduce gear grind, wallage, reverse-finger-flippin-top-down-FF action we all love to hate.
-Just feels effing good.
I've had the pleasure of testing BOTH versions (yes...I'm really that special) and have had good results with both.
Sport Springs - These springs I feel should have been the OEM equipment from Honda. The springs offer a slightly more rigid shifter re-centering action than stock but nothing overbearing. Benefits mentioned above are there, nothing super dramatic or ridiculous but they're there and noticeable. If you don't do any type of motor-sport with your car (drag racing, circuit or auto-x), this might be a better option for you unless you want more manly, then the race springs are the way to go.
Race Springs - I preferred these springs a lot more. Much more of a noticeable change over stock, to me, it was NOT overbearing or too fatiguing, the perfect balance in my honest opinion. I don't daily the car, it is a track monster/weekend sexy beast. I do feel that if I were to daily the car, I would still end up with the race springs. With how affordable they are, it's not the end of the world if you end up switching to another rate anyways. The race springs though were clearly the ones for me.
Side note - I have lots of other shifter mods, including a different shifter assembly (P-Spec shifter vs OEM or some other brand) but the overall driving feel and changes I felt should be consistent regardless of what shifter you're using.
I can not say if the springs alone will make a dramatic change in 2nd gear grinds or 3rd gear wallage and other ricer drama but it can't hurt!
Side note #2 - Everyone complains the K-series trans isn't as good as older Honda transaxles and that there's constant gear grinds and other problems associated with the design of the trans itself. The problem is not so much the transaxle but again, the interface. By making the shifter more precise, the gear selection is improved to the point where there are zero issues.
I want to make this clear for anyone who is interested in the springs...with my P-Spec shifter I had ZERO problems with the notorious 2nd gear grind, 3rd gear wall, etc. The metal spherical used at the base of the shifter and the metal retainer made it so much more precise that it just fixed any issues I ever had with the trans. The springs definitely improve the feel and precision of the shifter as well but seeing how I installed these after I put on my P-spec shifter, I can't say if they will help as much as reducing gear shifting issues commonly related to the k-series transaxle. I still HIGHLY recommend these springs (especially for the price) and if you are going to run ANY shifter BESIDES OEM, make sure you invest in a P-SPEC shifter, I know, I know, it's not cheap, but I've tried basically everything out there and your mom, you've seen how analytical I am about this shit, it's just the best ten fold. Chris REALLY needs to carry it in the store, you get what you pay for and you definitely get a great shifter.
Summation:
-MTEC springs + w/e shifter you have = Epic
-P-spec shifter = Epic
-MTEC springs + P-spec shifter = winning combo, I've tried it all, take it from me...my race car is the definition of driving perfection.
Originally Posted by MITeggy17 View Post
Good luck getting any pictures of Chota's car. You have better chances of seeing a unicorn.
Originally Posted by Xander View Post
The Chota Spec in this chat is over 9000
Originally Posted by 1slowrex View Post
Doug builds his motors according to chota spec
Originally Posted by Brock View Post
I guess there can be only one full Chota Spec.
Imma Chota Spec dat ass
Dr.Honda is offline   Reply With Quote
Sponsored Links
Advertisement
Old 07-29-2010, 06:43 AM   #2
iBoost
U mad bro?
iBoost's Avatar
iBoost probably needs to buy a Wii Fit iBoost probably needs to buy a Wii Fit iBoost probably needs to buy a Wii Fit iBoost probably needs to buy a Wii Fit iBoost probably needs to buy a Wii Fit iBoost probably needs to buy a Wii Fit
iBoost probably needs to buy a Wii Fit iBoost probably needs to buy a Wii Fit iBoost probably needs to buy a Wii Fit iBoost probably needs to buy a Wii Fit iBoost probably needs to buy a Wii Fit iBoost probably needs to buy a Wii Fit iBoost probably needs to buy a Wii Fit iBoost probably needs to buy a Wii Fit iBoost probably needs to buy a Wii Fit iBoost probably needs to buy a Wii Fit iBoost probably needs to buy a Wii Fit iBoost probably needs to buy a Wii Fit iBoost probably needs to buy a Wii Fit iBoost probably needs to buy a Wii Fit iBoost probably needs to buy a Wii Fit iBoost probably needs to buy a Wii Fit iBoost probably needs to buy a Wii Fit iBoost probably needs to buy a Wii Fit
Nice review!
I originally purchased the sport spring (haven't installed it yet)... After reading this, I think I'll buy the race
PSPEC + RACE SPRING + PPG Trans = should be badass!
iBoost is offline   Reply With Quote
Old 07-29-2010, 07:31 AM   #3
GreyMetallicTeg
Lead, Follow, or GTFO!
GreyMetallicTeg's Avatar
GreyMetallicTeg is a jewel in the rough of c-rsx GreyMetallicTeg is a jewel in the rough of c-rsx GreyMetallicTeg is a jewel in the rough of c-rsx GreyMetallicTeg is a jewel in the rough of c-rsx GreyMetallicTeg is a jewel in the rough of c-rsx GreyMetallicTeg is a jewel in the rough of c-rsx GreyMetallicTeg is a jewel in the rough of c-rsx GreyMetallicTeg is a jewel in the rough of c-rsx GreyMetallicTeg is a jewel in the rough of c-rsx GreyMetallicTeg is a jewel in the rough of c-rsx
Putting the Race Springs on my "list"
_Clean it, Drive it, Fix it_
GreyMetallicTeg is offline   Reply With Quote
Old 07-29-2010, 07:39 AM   #4
paulkramer
Member
paulkramer's Avatar
paulkramer is an unknown quantity on c-rsx
think pretty highly of yourself, don't you?
paulkramer is offline   Reply With Quote
Old 07-29-2010, 11:51 AM   #5
paulkramer
Member
paulkramer's Avatar
those introductory pics are really freaking creepy too
Old 07-29-2010, 12:22 PM   #6
2010 admin
Guest
Posts: n/a
I almost binned this thread because I thought it was spam or trolling when I clicked on it and the first thing that popped up was those pics.
Old 07-29-2010, 12:27 PM   #7
iBoost
U mad bro?
iBoost's Avatar
Hahaha me too!
I gotta agree with paulkramer.... those pics are gay.
Old 07-29-2010, 12:34 PM   #8
MITeggy17
El Chapo
MITeggy17's Avatar
MITeggy17 probably needs to buy a Wii Fit MITeggy17 probably needs to buy a Wii Fit MITeggy17 probably needs to buy a Wii Fit MITeggy17 probably needs to buy a Wii Fit MITeggy17 probably needs to buy a Wii Fit MITeggy17 probably needs to buy a Wii Fit
MITeggy17 probably needs to buy a Wii Fit MITeggy17 probably needs to buy a Wii Fit MITeggy17 probably needs to buy a Wii Fit MITeggy17 probably needs to buy a Wii Fit MITeggy17 probably needs to buy a Wii Fit MITeggy17 probably needs to buy a Wii Fit MITeggy17 probably needs to buy a Wii Fit MITeggy17 probably needs to buy a Wii Fit MITeggy17 probably needs to buy a Wii Fit MITeggy17 probably needs to buy a Wii Fit MITeggy17 probably needs to buy a Wii Fit MITeggy17 probably needs to buy a Wii Fit MITeggy17 probably needs to buy a Wii Fit MITeggy17 probably needs to buy a Wii Fit MITeggy17 probably needs to buy a Wii Fit MITeggy17 probably needs to buy a Wii Fit MITeggy17 probably needs to buy a Wii Fit MITeggy17 probably needs to buy a Wii Fit
Hands down the best review on CRSX.
ThePremSociety | Stella | Team Tuna | Infamous O.G. | G.O.A.T
MITeggy17 is offline   Reply With Quote
Old 07-29-2010, 01:01 PM   #9
paulkramer
Member
paulkramer's Avatar
Originally Posted by iBoost View Post
Hahaha me too!
Old 07-29-2010, 01:09 PM   #10
2010 admin
Guest
Posts: n/a
It would have been better to put the smoking crab instead of those guys. I thought it was gay porn spam at first. The crab is interesting.
Old 07-29-2010, 01:11 PM   #11
paulkramer
Member
paulkramer's Avatar
But - are these springs any better than the beefier (shit, I'm afraid to use that word in this thread) springs Alex (I think it's Alex) sells for the interior shift box?
Surely those are much easier to replace.
Old 07-29-2010, 01:12 PM   #12
2010 admin
Guest
Posts: n/a
What interior springs are you talking about. There are none inside the car.
For this, you just bolt the whole change lever assembly and lift it out.
Old 07-29-2010, 01:13 PM   #13
MITeggy17
El Chapo
MITeggy17's Avatar
Old 07-29-2010, 01:15 PM   #14
2010 admin
Guest
Posts: n/a
The crab was fine. It can only go downhill, so that's enough. Let's not whore out this thread any further.
I'm going to let it stand for now, then clean out all our off-topic remarks and pics once the TS logs back in, sees what he caused, then (hopefully...) edits the post.
Old 07-29-2010, 02:13 PM   #15
paulkramer
Member
paulkramer's Avatar
There are some springs in the interior shift box - I swear I saw them when I installed my PSPEC.
Unless I'm losing my mind - those pics might have caused some brain damage.
Old 07-29-2010, 02:37 PM   #16
nanim0n
Member
nanim0n is a jewel in the rough of c-rsx nanim0n is a jewel in the rough of c-rsx nanim0n is a jewel in the rough of c-rsx nanim0n is a jewel in the rough of c-rsx nanim0n is a jewel in the rough of c-rsx nanim0n is a jewel in the rough of c-rsx nanim0n is a jewel in the rough of c-rsx nanim0n is a jewel in the rough of c-rsx
great review!
nanim0n is offline   Reply With Quote
Old 07-29-2010, 02:41 PM   #17
iBoost
U mad bro?
iBoost's Avatar
I've got the PSPEC also and I don't remember seeing any springs
lol
Old 07-29-2010, 03:41 PM   #18
Dr.Honda
1 of 1
Dr.Honda's Avatar
Don't ruin the thread, Paul, it's called having a sense of humor.
I was thinking of putting little asian baby pics up for you but figured other people would view the thread.
Pics are for the lulz, if people read the thread it would make sense.
True story.
Is no one seeing the Fast/Furious ricer connection in the pictures? Did people not go to the movies years ago?
Alex springs are exactly the same type of product as these, they go in the trans and the race ones are probably about the same stiffness.
Troof.
LOL, CRSX almost crashed. Lmk what you want, I can sub in the pictures for something else for the lulz, didn't think everyone would be so paranoid about FF coming back to haunt them. If you want to delete everyones' posts, that's fine by me, I hate to see non-sense about insecurities clutter a thread about a good product.
Don't blame me for your old age related drama.
Old 07-29-2010, 09:21 PM   #19
kb58
Member
kb58 is an unknown quantity on c-rsx
Couldn't get through the first post... just reeks too much of a paid infomercial, whether it is or not. Billy Mays would be proud.
midlana.com:Soon-to-be turbo K24-powered mid-engine Super 7
Book: How to build a mid-engine sports car using a FWD drivetrain.
kb58 is offline   Reply With Quote
Old 07-29-2010, 09:23 PM   #20
vash_the_stampede
popcorn playa
vash_the_stampede's Avatar
vash_the_stampede Golden Rep Whore vash_the_stampede Golden Rep Whore
vash_the_stampede Golden Rep Whore vash_the_stampede Golden Rep Whore vash_the_stampede Golden Rep Whore vash_the_stampede Golden Rep Whore vash_the_stampede Golden Rep Whore vash_the_stampede Golden Rep Whore vash_the_stampede Golden Rep Whore vash_the_stampede Golden Rep Whore vash_the_stampede Golden Rep Whore vash_the_stampede Golden Rep Whore vash_the_stampede Golden Rep Whore vash_the_stampede Golden Rep Whore
will read later
IDGAF
/anime crew#4/lefty crew #1/ Late Night Crew#10/All Motor Crew #21/vAsh vAse cR3w! #1 TcK~!!!!
Originally Posted by SEvoIX View Post
I want cream cheese on my baked potato
vash_the_stampede is offline   Reply With Quote
Old 07-30-2010, 02:35 AM   #21
Dr.Honda
1 of 1
Dr.Honda's Avatar
Billy Mays is my hero.
Old 07-31-2010, 02:24 AM   #22
GreyMetallicTeg
The one I was talking about, was the centering return spring on the driver side of the shifter assembly. But I have been Schooled by Chota wisdom... next time you pop off your center console, look down and you'll see what I'm talking about. Alot of the shifter slop comes into play with that pivot piece/weak sauce return spring, I'll get a pic in the morning to show you exactly what I'm talking about.
Old 07-31-2010, 07:27 AM   #23
paulkramer
Member
paulkramer's Avatar
thank you - I am not losing my mind after all
well, at least not on that item
Old 07-31-2010, 08:33 AM   #24
2010 admin
Guest
Posts: n/a
I cannot for the life of me remember what that spring looks like.
Old 07-31-2010, 08:35 AM   #25
paulkramer
Member
paulkramer's Avatar
IIRC, they are very small and not available separately.
I always thought it made more sense to beef them up rather than the ones at the transmission.
I suppose either/both would do the trick.
Reply
Bookmarks
chota , endorsed , epic , mtec , shifter , shit , springs
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
