#1 |
Master Member
k20a2/k24a4 partout. k20a2 rocker assembly, clutch, k24(RAA) intake manifold, etc!
hey guys i have two long blocks i'm parting out, a k20a2 and a k24a4. both blocks were hydrolocked. i'm located in Canada, but will ship to the US
i have both heads for sale and would like to sell them complete, but if i get offers for both the rocker assembly and camshafts i may part out the heads. -i'm not listing prices, just make me an offer with your postal code/ ZIP code so i can get a shipping quote -if you're looking for something that i don't have listed, let me know, i may still have it! -if you want more pictures of something in particular, just let me know -i'm keeping the k20a2 oil pump and prb manifold for myself. *all parts are used, and from hydrolocked blocks. buy and use parts with your own discretion* so here we go! ---------------------------------------------------------------------------------------------- 1.) ------------------------------------------------------------------------------------------------------ 2.) k24a4 head Exhaust rockers sold! ------------------------------------------------------------------------------------------------------- 3.) other parts - Spoiler: -k20z1 flywheel Spoiler: -k20a2 clutch and pressure plate. they came off a stock car with 60k Spoiler: -RAA(k24) intake manifold Spoiler: - Spoiler: - -k24a4 crankshaft pulley -k20a2 timing chain -k20a2 timing chain tensioner -k20a2 timing case cover with tensioner cover -k20a2 timing chain guides -k24a4 exhaust manifold -k20a2 exhaust manifold -k series head bolts -3 k24a4 pistons and rods in great shape! if you want i can throw in the 4th ![]() -i also have a base AEM v2 intake, nearly brand new condition i'm sure there's lots i'm missing! make me an offer!
07 Nissan Frontier SE 4x4 07 GSXR-600 Race bike 02 YZ125 K-Pro Tuners - The #1 Site for Real Calibrations by Real People K20A2/K24A4 PARTOUT Last edited by slama4; 08-29-2011 at 10:39 PM. |
| Sponsored Links | |||
Advertisement | |||
#2 |
Master Member
i also have a k20a2/prb throttle body with throttle position sensor, just added it in!
07 Nissan Frontier SE 4x4 07 GSXR-600 Race bike 02 YZ125 K-Pro Tuners - The #1 Site for Real Calibrations by Real People K20A2/K24A4 PARTOUT |
#4 |
Master Member
they're k24a4 cams from an 03. you're probably looking for 06-08 k24a2 cams
#5 |
Master Member
make me an offer! i'm willing to let this stuff go pretty cheap!
#7 |
Master Member
sorry, only sensor on the tb is the TPS
#9 |
Master Member
#10 |
Master Member
bump
#12 |
Master Member
you NEED kpro for the head swap, and you'll probably want a new head gasket. if you're doing the swap yourself you'll need tools obviously.
were you planning on doing it yourself or getting someone to do it? the intake ports/ intake valves could definitely use a clean up as you can see from the pictures because of the water they took in. you might have to replace a few intake valves, but you'll see if you clean them up. i can do $550 shipped
#13 |
Master Member
Bump!
#14 |
Member
can i use a type s ECU instead of kpro? and is the head complete? intake manifold and all the rest of the things? ive been reading a few threads i guess i need those things too right? yeah i plan o doing it my self
#16 |
Master Member
no intake manifold or valve cover, the head is complete internally. it would probably run on a type-s ecu, but i personally wouldn't do it.
i'd clean it up with carb cleaner or brake cleaner.
#18 |
Master Member
pm'd
#19 |
Master Member
if you're really set on running it with a type-s ecu, (and IF it works, i can't garantee it will) you'll need a type-s intake manifold. (the base has dual runners which the type-s does NOT have), and type s injectors. even though your compression will be lower than a type-s, i would run 91 octane to be on the safe side. the type-s ecu will also let you rev to 8000 rpm, but i would not suggest revving it that high. i wouldn't go past 7500 rpm.
if you're going to do the head swap yourself and use a type-s ecu, i'd suggest getting someone else to help who has done motor work before. you have lots of research ahead of you. when you think you've done enough, do more!
#20 |
Master Member
bump! don't be scared to make an offer!
#21 |
Master Member
bump!
#22 |
Master Member
k20a2 head and throttle body sold!
#23 |
Master Member
bump!
#24 |
Master Member
bump!
#25 |
Master Member
bump
