#1 |
New Member
overfilled oil by 1/2 quart.....is this serious?
So like a doofus, I overfilled the engine oil by about a half quart. I'm wondering how big of a deal this is. I found this: http://www.cartalk.com/content/colum...August/03.html, where they say that a half quart isn't bad for most cars, but some cars (they point out a Volkswagen 4 banger), it can cause problems.
I know that overfilling a car can cause some pretty heinous things (foaming, seal issues, excess air in the engine) but is half a quart really gonna do that? I just bought my base RSX at 30k miles, so the last thing I want is engine damage, but I also don't want to fork over the cash for something that isn't really a concern. Any thoughts? |
| Sponsored Links | |||
Advertisement | |||
#3 |
Hybrid-Racing.com
No you will be ok with our cars. The marker is a full but most the time is designed for just a hair more
The current Show-Off Thread! Spaz Approved Part VI Yes I am Turbo Urban Disturbance Car Club Hybrid Racing PM me if interested in tucked clutch line ![]() |
#4 |
Bańned
ull be fine
Wheel gap can be compared to a vagina. The more fingers you can stick in the worse off you are Don't PM me. I don't give a fuck about who you are and no, I don't have nudes |
#5 |
Mmm, 3rd lobe...
You are probably fine. I did that once by accident on my car.
I got the excess out by unscrewing the oil filter. It makes a bit of a mess, but so would trying to undo the drain plug and put it back in mid stream.
Honda, The Heartbeat of Japan... 2006 Acura CSX Touring 160hp 141lb/ft 2004 Acura RSX Type S 6spd 200hp 142lb/ft 1989 Honda Accord Coupe LX 5spd 2bbl 98hp 109lb/ft Slushies are something to drink, not drive... Nikon Crew Member #23 | Gripped D700/D200/D80, 2.8 from 17-200 |
#6 |
Senior Member
You're fine. I overfill might on purpose a little before a track day or autocross. If it's just at the high mark or just above, you're fine.
02 Acura RSX Type-S - Autocross/Track 00 S2000 - Summer Fun 98 Legacy GT Wagon - Ice Racer/DD Amsoil Dealer |
#10 |
Team Drastic
You got nothing to worry about
#11 |
Senior Member
when i did my last oil change i poured in the amount mentioned in the owners manual, forgetting how much that is right now, but it only reach at the half on the dip stick, that is exactly in between both circles. I don,t know why it didn't make it to the top circle. Do i add more now to make it reach the top or will that be too much since it will exceed the amount recommended by per specification in the owners manual?
#12 | |
Matterater
The total sump capacity is around 6 total. Plus, you have to take into account the fraction of oil you burned. As long as you're between the lines, it's perfect. Just fyi, the distance between the two marks on the dipstick is about a quart. |
#13 |
Senior Member
Start it up and let it run for about 5min, then shut it off and recheck the oil level after 5 additional minutes, this allows the oil to run through it's normal cycle through the engine components and filter and is the true level of oil you should be concerned with.
When I change my oil I always fill up to the recommended 4.9qt and put a little in the oil filter itself (~1/3 of the way up) before installing it, then I recheck it after a drive and I usually still have to add about 1/4qt more... |
#14 |
Sacked!!
The dip stick is an inaccurate tool at best. Many new cars are starting to forgo dipsticks(mostly German at this point) You'll be fine.
#15 | |
Mmm, 3rd lobe...
I usually settle for between the dots right when doing an oil change and get the real level the following morning after it's all settled.
#16 | |
Sacked!!
| Bookmarks |
| Tags |
| 1 or 2, oil, overfilled, quartis, serious |
| Thread Tools | |
