Cost of Clutch Replacement - Club RSX Message Board
Go Back   Club RSX Message Board > PERFORMANCE BASICS RSX > Transmission & Drive Train RSX
Notices
Reply
Thread Tools
Old 01-25-2011, 01:32 PM   #1
ahaqrsx-s
Member
ahaqrsx-s is a jewel in the rough of c-rsx ahaqrsx-s is a jewel in the rough of c-rsx ahaqrsx-s is a jewel in the rough of c-rsx ahaqrsx-s is a jewel in the rough of c-rsx ahaqrsx-s is a jewel in the rough of c-rsx ahaqrsx-s is a jewel in the rough of c-rsx ahaqrsx-s is a jewel in the rough of c-rsx ahaqrsx-s is a jewel in the rough of c-rsx
I'm tryin to get a quote for a clutch replacement, and most places are telling me about 600-700 in labor. When I looked on here people were saying it should be more around 300-400 in labor. I live in Seattle, just wondering if anyone knows a place where I can get it done for a good price ?
Is the stage 1 organic exedy a good choice?
ahaqrsx-s is offline   Reply With Quote
Sponsored Links
Advertisement
Old 01-27-2011, 02:48 AM   #2
dizxboi
SpoOn Fed..
dizxboi's Avatar
dizxboi is a jewel in the rough of c-rsx dizxboi is a jewel in the rough of c-rsx dizxboi is a jewel in the rough of c-rsx dizxboi is a jewel in the rough of c-rsx dizxboi is a jewel in the rough of c-rsx dizxboi is a jewel in the rough of c-rsx dizxboi is a jewel in the rough of c-rsx dizxboi is a jewel in the rough of c-rsx
if you take it to acura it is about 600-700 in just labor they should finish on the same day so I would say drop it off at 7 or 8 when ever they open, I use the Oem replacement by exedy works perfectly fine. P.S. if acura fucks up you have lifetime warranty on your clutch job they do other cheap place usually won't learn that the hard way....
8===D
dizxboi is offline   Reply With Quote
Old 01-27-2011, 03:52 AM   #3
mikhaelbt189
Senior Member
mikhaelbt189's Avatar
mikhaelbt189 is a jewel in the rough of c-rsx mikhaelbt189 is a jewel in the rough of c-rsx mikhaelbt189 is a jewel in the rough of c-rsx mikhaelbt189 is a jewel in the rough of c-rsx mikhaelbt189 is a jewel in the rough of c-rsx mikhaelbt189 is a jewel in the rough of c-rsx mikhaelbt189 is a jewel in the rough of c-rsx mikhaelbt189 is a jewel in the rough of c-rsx
i worked mine on speedracing, it cost me 850 dollars with labor+parts. stage1.5 clutch.
mikhaelbt189 is offline   Reply With Quote
Old 01-27-2011, 08:31 AM   #4
JayDEmm722
BECAUSE! racecar...
JayDEmm722's Avatar
JayDEmm722 is an unknown quantity on c-rsx
Wrong section.
Boost Slut Krew Member #20
11.86 @ 116.97 1.77 60ft.... First Run Ever!
HaLFAmAzinG120 (2:31:52 PM): fuck me like you hate me!
HaLFAmAzinG120 (2:31:56 PM): oh wrong IM sorry
LoSt1nY3RpAnTIEz (2:32:23 PM): O.O
JayDEmm722 is offline   Reply With Quote
Old 01-27-2011, 09:57 AM   #5
2010 admin
Guest
Posts: n/a
Your first labor price is fair for a professional shop, the second is fair for a shade tree mechanic's install. Both have their pluses and minuses.
As far as the actual clutch, that Exedy unit is fine if your car is basically stock.
Old 01-27-2011, 01:00 PM   #6
method:K20Z1
cyprus
method:K20Z1 is an unknown quantity on c-rsx
I second Eric's post and it's a big job for a guy with a jack and jack stands which woould likely put you in the $300-$400 range. Might not be the best idea to skimp on this job. You want it done right and a lift is going to make that much easier. It's less about installing the parts and more about all of the little details of everything that has to come off and go back on correctly.
method:K20Z1 is offline   Reply With Quote
Old 01-27-2011, 03:45 PM   #7
DonniDC5
RSX-S driven
DonniDC5's Avatar
DonniDC5 has been a little shit in the past
How often do clutches have to be replaced?
I LOVE MY DC5
DonniDC5 is offline   Reply With Quote
Old 01-27-2011, 07:14 PM   #8
Vermonter
As Seen In VT
Vermonter's Avatar
Vermonter is a jewel in the rough of c-rsx Vermonter is a jewel in the rough of c-rsx Vermonter is a jewel in the rough of c-rsx Vermonter is a jewel in the rough of c-rsx Vermonter is a jewel in the rough of c-rsx Vermonter is a jewel in the rough of c-rsx Vermonter is a jewel in the rough of c-rsx Vermonter is a jewel in the rough of c-rsx
the obvious answer: whenever needed.
mine was done at 114k but it wasn't completely gone, just started showing signs of wear. i guess it all depends on how well you drive standard and what kind of abuse you put it through.
Vermonter is offline   Reply With Quote
Old 01-29-2011, 08:20 AM   #9
neuspeeddc5
100K Club as of 10/10/09
neuspeeddc5's Avatar
neuspeeddc5 is an unknown quantity on c-rsx
i have 117000 miles on mine still on stock clutch with no signs of wear
Greddy l Neuspeed l Koni l Depo l Mugen l DC Sports l Hondata l Progress l Apexi l Megan l CHARGESPEED
100K Club
member since 2004
neuspeeddc5 is offline   Reply With Quote
Old 01-29-2011, 06:32 PM   #10
sharpy rsx
instagram:SLOWRSX
sharpy rsx's Avatar
sharpy rsx is an unknown quantity on c-rsx
im fixing to replace my stock one to. its really not that hard to change it if u can get a lift . just time consuming .
Who says a base cant be fast?406whp base <a http://forums.clubrsx.com/showthread.php?t=866180
sharpy rsx is offline   Reply With Quote
Old 01-29-2011, 07:47 PM   #11
clean3two3
Master Member
clean3two3 is an unknown quantity on c-rsx
I paid 130 for my clutch which is a exedy oem replacement came with pressure plate and bearing and tool, took it to my shop they charged me 200 for labor and 20 to resurface my flywheel. My clutch was replaced at 130k now I'm at 151k no problems. 350 in total not bad compared to the other guy who wanted 800 just for labor told him to somb lol
clean3two3 is offline   Reply With Quote
Old 02-01-2011, 02:36 PM   #12
ahaqrsx-s
Member
wow 220 for labor?? That's a deal
Old 02-01-2011, 06:59 PM   #13
Laborchet
Master Member
Laborchet's Avatar
Laborchet might be well recognized one day on c-rsx Laborchet might be well recognized one day on c-rsx Laborchet might be well recognized one day on c-rsx Laborchet might be well recognized one day on c-rsx Laborchet might be well recognized one day on c-rsx Laborchet might be well recognized one day on c-rsx Laborchet might be well recognized one day on c-rsx Laborchet might be well recognized one day on c-rsx
I got quoted 350 plus tax at a very reputable shop in my area but i didnt have the money and i was so tired of the way my old clutch felt and slipped so i just did it myself. It went alot smoother than i expected.
Laborchet is offline   Reply With Quote
Old 02-08-2011, 11:29 AM   #14
ahaqrsx-s
Member
Do you guys know if I were to get the Exedy Organic Clutch for $284 (EXE-08806) , would I need to replace the flywheel as well or just keep stock?
Old 02-08-2011, 12:43 PM   #15
Vermonter
As Seen In VT
Vermonter's Avatar
stock should be fine. most will tell you that a lighter flywheel will help, but it depends on what you use your car for. a lighter flywheel will kill your fuel econemy if you do mostly highway driving. if you do a lot of city driving or accelerating, i wouldnt worry about the econemy aspect, it might actualy improve your econemy.
Old 03-04-2011, 11:50 AM   #16
ahaqrsx-s
Member
Exedy Organic Clutch or Compettion Organin Clutch? Competition is a little cheaper, but if exedy is better I won't mind spending the extra 30 bucks? Any suggestions?
Old 03-04-2011, 12:05 PM   #17
Type-Spaz
Hybrid-Racing.com
Type-Spaz's Avatar
Type-Spaz has disabled reputation
If you lived close to WI Id say bring it to me. Much cheaper
As far as which clutch what are your supporting mods
Type-Spaz is offline   Reply With Quote
Old 03-05-2011, 12:14 AM   #18
ahaqrsx-s
Member
Just a few basic bolt ons, but I use it as a daily driver and just want something a little stiffer. In terms of quality is one better than the other? Or would I be fine with just paying a little less for the Competition organic clutch?
Old 03-07-2011, 10:04 AM   #19
therestRSX
Member
therestRSX is a jewel in the rough of c-rsx therestRSX is a jewel in the rough of c-rsx therestRSX is a jewel in the rough of c-rsx therestRSX is a jewel in the rough of c-rsx therestRSX is a jewel in the rough of c-rsx therestRSX is a jewel in the rough of c-rsx therestRSX is a jewel in the rough of c-rsx therestRSX is a jewel in the rough of c-rsx
Im now considering replacing my clutch because under hard accelaration it seems as if the clutch starts to slip. Idk which im going to get though. Do ya know if the K20A3 clutch would work on my Type-S? theres a local selling a new exedy oem one for 125!
Now I have planned a trip out of town and will be driving about 700+ miles. Would ya say its ok to go for it if it seems as if my clutch is going out? I would just be driving normal no hard accelerating or high revving.
therestRSX is offline   Reply With Quote
Reply
Bookmarks
clutch , cost , replacement
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
