Speakers on right side of car not working - Club RSX Message Board
Go Back   Club RSX Message Board > STYLE RSX > Car Audio, Security, & Electronics RSX
Notices
Reply
Thread Tools
Old 02-11-2011, 04:27 PM   #1
Yhippa
Senior Member
Yhippa's Avatar
Yhippa is an unknown quantity on c-rsx
I did a search and couldn't find anything so here goes. I noticed my audio sounded funny the other day so I did some basic tests (isolating front, back, left, and right speakers) and found that all of the speakers on the right side of the car don't work. That includes the tweeter and front door and backseat speakers.
Anybody have any ideas what this could be? Blown fuse? I haven't done anything to the stock system.
Yhippa is offline   Reply With Quote
Sponsored Links
Advertisement
Old 02-11-2011, 04:29 PM   #2
Dickbowlmidz
I am the machine
Dickbowlmidz's Avatar
Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more
Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more
type s or base?
could be bad amp or radio if type s
bad radio if its a base.
InFamous / ThePremSociety / Hellafunctional
Dickbowlmidz is offline   Reply With Quote
Old 02-13-2011, 09:57 PM   #3
Nayman
Member
Nayman is a jewel in the rough of c-rsx Nayman is a jewel in the rough of c-rsx Nayman is a jewel in the rough of c-rsx Nayman is a jewel in the rough of c-rsx Nayman is a jewel in the rough of c-rsx Nayman is a jewel in the rough of c-rsx Nayman is a jewel in the rough of c-rsx Nayman is a jewel in the rough of c-rsx
I had the same problem, and it turned out to be a bad head unit. It went away when i got a new one.
Nayman is offline   Reply With Quote
Old 02-14-2011, 08:38 AM   #4
Locotony
The Audio Guru
Locotony's Avatar
Locotony might be well recognized one day on c-rsx Locotony might be well recognized one day on c-rsx Locotony might be well recognized one day on c-rsx Locotony might be well recognized one day on c-rsx Locotony might be well recognized one day on c-rsx Locotony might be well recognized one day on c-rsx
As noted already it is either Amp or HU in a type S or radio in a base. fuses have nothing to do with a channel of audio being on or off
Car Audio, Security, & Electronics Moderator
2014 CBP Civic Si Coupe
Rockford Fosgate 3sixty.3
Illusion Audio Carbon C6 Comps
Precision Power Phantom 900.4 and 1000.1
2 - 12 inch Acoustic Elegance IB12AU Subs
Locotony is offline   Reply With Quote
Old 02-18-2011, 08:42 AM   #5
xkadajx
Senior Member
xkadajx's Avatar
xkadajx is an unknown quantity on c-rsx
Sorry to thread-jack but I didn't want to create a new thread for a similar problem. I've had my setup for 2 years now, but recently both my front speakers (alpine components) keep going on and off when I hit bumps or make sharp turns.... Before I rip off the car panels to check wirings, what else could it be?
I have a 1000w 4 channel amp thats connected to the 2 front components and a sub. the rear speakers are connected via factory wiring and wired into the HU. (Rear speakers are working fine). Problem with amp or wiring on component getting loose?
xkadajx is offline   Reply With Quote
Old 02-18-2011, 09:06 AM   #6
Locotony
The Audio Guru
Locotony's Avatar
Does the sub turn off as well or just the front comps. If the sub goes off as well power wiring to the amp needs to be checked as it could be loose otherwise I would check for loose RCA's
Old 02-18-2011, 09:17 AM   #7
xkadajx
Senior Member
xkadajx's Avatar
I havent noticed the sub turning on and off, the RCAs are fine on the amp, but I haven't checked behind the HU. I'll do that and see if it helps. Do you think the wires on the components could loosen over time?
Old 02-26-2011, 11:01 PM   #8
Yhippa
Senior Member
Yhippa's Avatar
Sigh. I must post what happened because what I did was so tarded.
I have a tape deck adapter for my XM radio. I was listening to music on my phone so I moved the jack from the XM unit to the phone and then back again when I was done. Apparently when I put the jack into the radio I put it in only halfway hence receiving only one of the channels of audio.
So this is how I'm punishing myself for being stupid. By posting it for the world to see!
Old 02-27-2011, 05:32 PM   #9
mallen600
Pancakes
mallen600's Avatar
mallen600 is a jewel in the rough of c-rsx mallen600 is a jewel in the rough of c-rsx mallen600 is a jewel in the rough of c-rsx mallen600 is a jewel in the rough of c-rsx mallen600 is a jewel in the rough of c-rsx mallen600 is a jewel in the rough of c-rsx mallen600 is a jewel in the rough of c-rsx mallen600 is a jewel in the rough of c-rsx mallen600 is a jewel in the rough of c-rsx
You may have a speaker grounding out on the metal of the door.
TN CREW #6[/b]ABP Crew Member #79[/b]
Zombie Eradication Team #68
BB Crew
***PIC OF BUFFALO HERE***
mallen600 is offline   Reply With Quote
Reply
Bookmarks
car , side , speakers , working
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
