heat shields, do they actually work ?! - Club RSX Message Board
Go Back   Club RSX Message Board > PERFORMANCE BASICS > Bolt-On Basics: RSX Type-S
Notices
Reply
Thread Tools
Old 05-27-2011, 04:14 PM   #1
twitchy_15
Member
twitchy_15's Avatar
twitchy_15 is a jewel in the rough of c-rsx twitchy_15 is a jewel in the rough of c-rsx twitchy_15 is a jewel in the rough of c-rsx twitchy_15 is a jewel in the rough of c-rsx twitchy_15 is a jewel in the rough of c-rsx twitchy_15 is a jewel in the rough of c-rsx twitchy_15 is a jewel in the rough of c-rsx twitchy_15 is a jewel in the rough of c-rsx
do heat shields actually make a difference on short ram intakes?
2005 MM ACURA RSX-TYPE S
twitchy_15 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 05-27-2011, 04:14 PM   #2
itskien
Doesn't Give A F*ck
itskien's Avatar
itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with
Nope. All you're really doing on sri is sucking up the hot air.
itskien is offline   Reply With Quote
Old 05-27-2011, 04:55 PM   #3
rensoyka
Breast inspector by appt.
rensoyka's Avatar
rensoyka is an unknown quantity on c-rsx
it won't affect the air temperature but it will deflect any direct radiation heat coming off of the exhaust header away from the filter.
'06 black type-s.
rensoyka is offline   Reply With Quote
Old 05-28-2011, 02:51 AM   #4
baker02
Function > Form
baker02's Avatar
baker02 is easy..................when it comes to rep
baker02 is easy..................when it comes to rep baker02 is easy..................when it comes to rep baker02 is easy..................when it comes to rep baker02 is easy..................when it comes to rep baker02 is easy..................when it comes to rep baker02 is easy..................when it comes to rep baker02 is easy..................when it comes to rep baker02 is easy..................when it comes to rep baker02 is easy..................when it comes to rep baker02 is easy..................when it comes to rep baker02 is easy..................when it comes to rep baker02 is easy..................when it comes to rep baker02 is easy..................when it comes to rep baker02 is easy..................when it comes to rep baker02 is easy..................when it comes to rep baker02 is easy..................when it comes to rep baker02 is easy..................when it comes to rep
x2
Team IDGAF Troll Crew
Hellafunctional... Driven Not Hard Parked
baker02 is offline   Reply With Quote
Old 06-01-2011, 11:30 AM   #5
DC4Teggy
Member
DC4Teggy's Avatar
DC4Teggy is a jewel in the rough of c-rsx DC4Teggy is a jewel in the rough of c-rsx DC4Teggy is a jewel in the rough of c-rsx DC4Teggy is a jewel in the rough of c-rsx DC4Teggy is a jewel in the rough of c-rsx DC4Teggy is a jewel in the rough of c-rsx DC4Teggy is a jewel in the rough of c-rsx DC4Teggy is a jewel in the rough of c-rsx
Heat shields DO block SOME heat from reaching your SRI, but you will always have more heat entering the intake with an SRI compared to a CAI which is routed away from the engine bay. I would use a heat shield plus wrap the intake tube with heat wrap if you are that anal about heat.
1994 Acura Integra LS-VTEC :SOLD
1996 Acura Integra RS
2006 Acura RSX Type-S
DC4Teggy is offline   Reply With Quote
Old 06-01-2011, 12:20 PM   #6
wketchin
Seņior Memberish
wketchin's Avatar
wketchin has a clean start wketchin has a clean start wketchin has a clean start wketchin has a clean start
Might as well wrap the filter in heat wrap too, because that's where the heat gets sucked in from.
I don't drive fast, I accelerate quickly.
I produce music.
wketchin is offline   Reply With Quote
Old 06-01-2011, 12:26 PM   #7
DC4Teggy
Member
DC4Teggy's Avatar
This is true. Really it's not going to matter if you wrap the tube or not. I was just saying if he is that anal about soaking up heat, wrap it. DON'T WRAP THE FILTER THOUGH! lol
Old 06-01-2011, 02:25 PM   #8
nperkins
Senior Member
nperkins's Avatar
nperkins is a jewel in the rough of c-rsx nperkins is a jewel in the rough of c-rsx nperkins is a jewel in the rough of c-rsx nperkins is a jewel in the rough of c-rsx nperkins is a jewel in the rough of c-rsx nperkins is a jewel in the rough of c-rsx nperkins is a jewel in the rough of c-rsx nperkins is a jewel in the rough of c-rsx
Any blocked heat is still blocked heat... Any reduction is something... Dropping your intake temps 10 degrees makes a difference... So if you can build a good shield, and wrap the metal intake tube to prevent heat soak, you WILL make a difference... Alot? Probably not.. Also depends on your driving... More important on a road race car where it gets driven hard for longer periods of time...
nperkins is offline   Reply With Quote
Old 06-01-2011, 02:37 PM   #9
wketchin
Seņior Memberish
wketchin's Avatar
Price vs. Power Difference = fucking retarded to heat wrap your short ram. the air doesn't remain inside the intake long enough for heat wrap to effect the IAT's.
I produce music.
Old 06-02-2011, 08:10 AM   #10
nperkins
Senior Member
nperkins's Avatar
Then why do they make phenolic spacers? To cool the intake manifold by separating it from the motor, therefore reducing its heat... The intake is nothing more than an extension of the intake manifold..
The air moves just as fast through the manifold as it does the intake...
The same reason that people thermal coat their intake & exhaust manifolds...
To keep the air temps inside of the item inside, and the air temps outside the item outside..
Old 06-02-2011, 09:36 AM   #11
2010 admin
Guest
Posts: n/a
1.) Phenolic spacers only work when you are not inhaling heated engine bay air.
2.) Nobody thermal-coats an intake manifold. At least nobody who cares about performance.
3.) Exhaust manifolds and turbines are coated to reduce radiant heat. Radiant heat is not as big a factor for short ram intakes as the fact that, as mentioned many, many times already, you are breathing in heated engine bay air.
Your logic is flawed. Don't really know what else to say about it.
Old 06-02-2011, 10:54 AM   #12
nperkins
Senior Member
nperkins's Avatar
1. Seriously?? Explain... Because last I knew, reducing from 130 degrees to 110 degrees is about the same thing as reducing from 110 degrees to 90 degrees..
2. Really?? Tell that to Subaru, who coats the manifolds on all STis to keep temps down some.. Also tell that to Hondata, who says to thermal coat the inside of the intake manifold to get better gains..
3. ) Thats right. They are coated to reduce radiant heat. To keep the hot air in the tubes... Exactly what I said... To keep the hot air in the pipes and moving... And as it keeps hot air in the pipes, it will also keep hot air OUT of pipes... So therefore, shielding the intake filter to prevent radiant heat, along with coating of the pipes/manifolds WILL help.
Old 06-02-2011, 12:47 PM   #13
wketchin
Seņior Memberish
wketchin's Avatar
1) I thought the phenolic material separated your metal intake manifold from the metal head, thus preventing heat soak from the head (one of the hottest locations on the engine)
2) I will tell that to subaru, that all their engineering is equivalent to a honda driver coating their short ram intake with exhaust wrap.
3)Why would you keep hot air in, and hot air out? What does this have to do with sucking in hot radiant air through the filter?
I produce music.
Old 06-02-2011, 12:49 PM   #14
wketchin
Seņior Memberish
wketchin's Avatar
btw.. this is like arguing which retard with a bum leg will win the special Olympics.
I produce music.
Old 06-03-2011, 12:43 PM   #15
nperkins
Senior Member
nperkins's Avatar
Here we go...
1. Thats right. It separates the metals to prevent the manifold from heat soaking, thus preventing the air passing through it from heating up. Think of your heater for your AC system.. How fast is that air moving? How fast does it heat up? Same principal.
2. You should tell that to Honda's F1 team then too... They must make their intakes out of carbon fiber for its bling factor, not its thermal factors..
3. Because if you keep what's in in, and what's out out, then they can't change one another.. Here's a non car example..
Thermal coatings on exhausts/manifolds help to keep the heat in the pipes, preventing the pipe from radiating heat and causing the engine bay to heat up.. The same principal applies to an intake manifold/pipe... If you can insulate it to prevent the heat from the engine bay from making the outside of the part hotter, you will be keeping the inside of the part (And the air passing through it) cooler..
NOW... I understand what you mean that the filter can still suck in the hot air... Which is why I was saying if you had a good shield/box, then you are keeping that hot engine bay air away from the filter, and therefore the engine.
Old 06-03-2011, 01:00 PM   #16
2010 admin
Guest
Posts: n/a
nperkins, since you are so insistent on being right, here is what you should do:
1.) Replace your Honda IAT sensor with a GM "open"-style unit. They are abundant and cheap. Can't use the Honda unit here, since it doesn't read fast enough.
2.) Datalog a mix of freeway and stop-and-go city driving, then note the IAT's of your wrapped (or whatever...) short ram.
3.) Then, make a jumper and hang the IAT sensor down in the fenderwell, where the CAI element normally sits and record the same mix of driving.
I already know what the results will be but in case I am wrong, you can be the first in line to tell me that. Remember, I'm not the one with anything to prove, since every manufacturer pulls intake air from outside the engine bay with their OEM airboxes.
Old 06-03-2011, 10:03 PM   #17
yakaka
yakaka is a jewel in the rough of c-rsx yakaka is a jewel in the rough of c-rsx yakaka is a jewel in the rough of c-rsx yakaka is a jewel in the rough of c-rsx yakaka is a jewel in the rough of c-rsx yakaka is a jewel in the rough of c-rsx yakaka is a jewel in the rough of c-rsx yakaka is a jewel in the rough of c-rsx
rip it off and either put heatwrap or aftermarket header
yakaka is offline   Reply With Quote
Old 06-04-2011, 12:36 AM   #18
Homeslice
Senior Member
Homeslice's Avatar
Homeslice is a jewel in the rough of c-rsx Homeslice is a jewel in the rough of c-rsx Homeslice is a jewel in the rough of c-rsx Homeslice is a jewel in the rough of c-rsx Homeslice is a jewel in the rough of c-rsx Homeslice is a jewel in the rough of c-rsx Homeslice is a jewel in the rough of c-rsx Homeslice is a jewel in the rough of c-rsx
oh my god.
the temperature change from wrapping a sri would be so minimal. it would make an unnoticeable amount of difference.
heat shields wont do much once your engine is a normal temperature.
'02 RSX-S with only 102,XXX km on her
Arctic Blue Pearl
GET LIST:
drop, reflash
Homeslice is offline   Reply With Quote
Old 06-04-2011, 12:50 AM   #19
Stig
Because STIGCAR
Stig's Avatar
Stig is an unknown quantity on c-rsx
Buy CAI.
/thread.
I don't know why manufacturers make SRI's where the filter is 2 inches away from the header. You'd have a much more efficient SRI if the filter was towards the edge of the bay (like behind the headlight).
The 'Stig' Showoff <--- Click to see!
DIY Garage Door Opener <----Click to make your own!
Originally Posted by Muse_Chevelle
as always, Stig with the info for the masses!
Stig is offline   Reply With Quote
Old 06-04-2011, 12:02 PM   #20
nperkins
Senior Member
nperkins's Avatar
A friend I actually did testings using thermocouples about 9-10 years ago when we were still big into hondas... We tested AEM CAIs, Iceman Intakes (It was that long ago), DC Sports, HondaSports, and a few others.. And while YES, a CAI would typically have colder IATS than a short ram (Even a wrapped one), THAT IS NOT WHAT THE OP ASKED.. He asked if a shield/wrap would make a difference on a SRI, and the answer is YES IT WILL. It was only 10 years ago, and on an EM1 chassis, but I actually recall an ARC style airbox having the lowest IATs of any of the intakes we tested... And I also recall the iceman giving better IAT's because it was plastic, not metal, so it didn't absorb the heat (But didn't make as much power because of its design)..
And how would measuring air inside an intake in the engine bay in one setup, and in a fenderwell on another test be anywhere near accurate? You have eliminating the soak of the pipe, regardless of if its an SRI or CAI..
Reply
Bookmarks
heat , shields , work
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright Š 2001-2012, Club RSX, Inc. All rights reserved worldwide.
