DIY: Alternator replacement - Club RSX Message Board
Notices
Reply
Thread Tools
Old 09-24-2011, 11:38 PM   #1
LimaRSX
#selfie
LimaRSX's Avatar
LimaRSX is not even half way to the top LimaRSX is not even half way to the top
LimaRSX is not even half way to the top LimaRSX is not even half way to the top LimaRSX is not even half way to the top LimaRSX is not even half way to the top LimaRSX is not even half way to the top LimaRSX is not even half way to the top LimaRSX is not even half way to the top LimaRSX is not even half way to the top LimaRSX is not even half way to the top LimaRSX is not even half way to the top
Hey guys, since I have had to change my alternator 3 times already and with no DIY I thought I'd make my first one.
I am not going to get really specific with material as all you will need is your new alternator and a typical socket/wrench set.
If I were to rate the difficulty of this it would be a 5/10 just mainly because it is a pain in the ass. First timers this can take you a couple hours. I manage to do it in 30 mins now since this was my third time.
First thing to do is to remove the front bumper. I am sure most of you know how to do this. Al you have to do is take all the over prices plastic clips off the top and bottom (if you have any left I know I don't.) The buttom of the bumper with have 2 screws on each side of the bumper. Then there is 1 screw on the side of the bumper where it meets the fender on each side.
Then you're going to want to remove your passenger headlight which has 4 10mm bolts to remove. Two on the top, 1 of the side, and 1 under neath which you will need a really long extension for.
Top:
Bottom:
Side:
Then unplug all your light harnesses and remove the light.
Next you will want to loosen the power steering reservoir which is connected to one 10mm bolt.
Next you will want to disconnect the positive terminal on your battery since you will be disconnecting the alternator wire that goes to it. Don't skip this step as I guarantee you will get shocked.
If you want to be extra safe you can use a towel or glove to cover the terminal:
Ok now it is time to get the serpentine belt off which is a PITA if you don't have a long wrench, I had a short one so it took a couple try's. This step is much easier if you have a helper.
First you get a 14mm wrench and place it on the auto tensioner like so:
You're gonna push down as much as you can to get the belt loose enough to slip off the power steering pully and alternator to free the alternator. Do not take the whole belt off as you will not enjoying putting it all back together for no reason.
Time for the alternator, the alternator has 3 bolts, 1 longer one on the top and 2 shorter ones on the bottom.
The 1 bottom bolt to the left is a PITA to get to but don't worry you can do it with some patience. If you need more room just loosen these two 10mm bolts on the passenger and driver side that hold the rad, it doesn't give much but its something.
After you remove the 3 alternator bolts it is time to remove the ground that goes from the alternator to the chasis. Then disconnect the positive terminal attached to the alternator, I believe it is either a 10 or 8mm nut. (my wires looks different because I upgraded the wiring.). Lastly you will need to unplug a green socket that plugs into your alternator regulator.
Now it is time to slide, wiggle n play with that alternator to get it out where the headlight is. The only way I figured to get it out is the have the pulley facing into side giving it just enough space to get it out. Just be patient at this part, it will fit.
Fuck this fucking build crew
IG: LimaRSX
HotAvy&SigKrew
LimaRSX is offline   Reply With Quote
Sponsored Links
Advertisement
Old 09-24-2011, 11:38 PM   #2
LimaRSX
#selfie
LimaRSX's Avatar
After you get it out basically follow these steps in reverse by putting it all back together.
After everything is back together start her up and get out a voltage tester. Ideally you will want your idle to be around 14.3-14.7 volts. Turn on everything electrical and see how low it goes. You should be in the 13's or higher under load at idle. With all that load have a buddy rev the car steady at 2000 rpms and test to see if the voltage jumps back up into the 14's. If you get different values, you probably picked up a bad alternator. First time I switched my alternator it was doing 16-17 volts which messed up the whole car.
I hope this helps you guys, I am on often so don't hesitate to ask a question or for clarification on something.
IG: LimaRSX
HotAvy&SigKrew
Old 09-26-2011, 08:36 PM   #3
chunktwo
i eat f00d
chunktwo's Avatar
chunktwo is an unknown quantity on c-rsx
Thanks for the DIY. May I ask why you neededto replace your alternator three times? Were they failing?
chunktwo is offline   Reply With Quote
Old 09-26-2011, 08:56 PM   #4
LimaRSX
#selfie
LimaRSX's Avatar
No problem
My guess is the first OEM alt died due to age and my sound system.
Second one I installed was a shitty rebuild which was giving too much voltage messing up my electrical.
I returned that and got another one which basically lasted 2 months passed its warranty. My guess is of course a shitty rebuild and my system.
This one I am ing it is good as it was rebuilt by bosch.
IG: LimaRSX
HotAvy&SigKrew
Old 09-26-2011, 09:25 PM   #5
JayDEmm722
BECAUSE! racecar...
JayDEmm722's Avatar
JayDEmm722 is an unknown quantity on c-rsx
Man 3 times? Fuck that noise.
Boost Slut Krew Member #20
Formerly JayRSXS
11.86 @ 116.97 1.77 60ft.... First Run Ever!
HaLFAmAzinG120 (2:31:52 PM): fuck me like you hate me!
HaLFAmAzinG120 (2:31:56 PM): oh wrong IM sorry
LoSt1nY3RpAnTIEz (2:32:23 PM): O.O
JayDEmm722 is offline   Reply With Quote
Old 09-26-2011, 09:30 PM   #6
LimaRSX
#selfie
LimaRSX's Avatar
Lifes rough sometimes, at least I am a pro now at replacing it and providing CRSX with a DIY
IG: LimaRSX
HotAvy&SigKrew
Old 09-28-2011, 05:40 PM   #7
BeaterEP
Still the Master Beater
BeaterEP's Avatar
BeaterEP might be well recognized one day on c-rsx BeaterEP might be well recognized one day on c-rsx BeaterEP might be well recognized one day on c-rsx BeaterEP might be well recognized one day on c-rsx BeaterEP might be well recognized one day on c-rsx BeaterEP might be well recognized one day on c-rsx BeaterEP might be well recognized one day on c-rsx BeaterEP might be well recognized one day on c-rsx
Oh man, just in time with this! My EP alternator just died on me, waiting on AAA to show up right now and digging around to see how bad the install is.
Fucking MASSIVE for this thread!
Looks like I've got a project this weekend!
ENGINE/I/H/E: K20A3 (262,000+ miles), Hondata Reflash, Mobile1 5w30, Injen CAI, ITR header/cat/midpipe, OBX Twin Loop muffler
SUSPENSION/BRACING: HFP, Mugen compliance bushings, Comptech FSB, Progress 22mm rear sway/tie bar, Ingalls rear camber arms, ITR rear strut gussets
WHEELS/TIRES/BRAKES: XXR 513s (15x7 +15), Kumho Ecsta 4X (205/55/15), Wilwood DPHA calipers (front), Wilwood BP-10 pads, Hawk HPS pads
BeaterEP is offline   Reply With Quote
Old 09-28-2011, 05:42 PM   #8
itskien
Doesn't Give A F*ck
itskien's Avatar
itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with
Empty Tank Crew #1
Twitter: KiensAJauk
Instagram / Snapchat: ItsKien
Originally Posted by AzianK View Post
kien you fat fuck, no set of wings can lift your cinna bun ass up to heaven anyway.
itskien is offline   Reply With Quote
Old 09-28-2011, 05:48 PM   #9
LimaRSX
#selfie
LimaRSX's Avatar
Glad I could help, good luck with the install
IG: LimaRSX
HotAvy&SigKrew
Old 09-28-2011, 06:01 PM   #10
BeaterEP
BeaterEP's Avatar
Haha thanks man!
Just hope I don't get a dud unit right outta the box, one headache is enough
Old 09-28-2011, 11:42 PM   #11
LimaRSX
#selfie
LimaRSX's Avatar
I agree, it is not a fun install to install a dud.
IG: LimaRSX
HotAvy&SigKrew
Old 09-29-2011, 09:40 AM   #12
BeaterEP
BeaterEP's Avatar
Found Denso factory remans at Advance Auto's website. Pricier, and they take longer to get here since they're coming straight from factory, but apparently they're 100% Denso, which sounds like peace of mind to me.
Ordered one, just have to share the wife's Element for a week or so until it gets here.
/411
EDIT:
oh wow, nevermind. Thats not really a great option for you RSX folks.
Denso reman EP3: $260
Denso reman DC5: $475
Damn. Sorry guys.
Old 09-29-2011, 08:29 PM   #13
LimaRSX
#selfie
LimaRSX's Avatar
/411
EDIT:
Damn. Sorry guys.
Heh I just buy used off members for now... most sell pretty cheap.
Let us know how the install goes.
IG: LimaRSX
HotAvy&SigKrew
Old 09-29-2011, 08:56 PM   #14
EP303
ΜΟΛΩΝ ΛΑΒΕ
EP303's Avatar
EP303 is a rep WHORE
EP303 is a rep WHORE EP303 is a rep WHORE EP303 is a rep WHORE EP303 is a rep WHORE EP303 is a rep WHORE EP303 is a rep WHORE EP303 is a rep WHORE EP303 is a rep WHORE EP303 is a rep WHORE EP303 is a rep WHORE EP303 is a rep WHORE EP303 is a rep WHORE EP303 is a rep WHORE EP303 is a rep WHORE EP303 is a rep WHORE
Gonna use this soon!
UKDM>JDM
EP303 is offline   Reply With Quote
Old 09-30-2011, 09:57 PM   #15
BeaterEP
BeaterEP's Avatar
Sooo, how exactly are we normal people supposed to get to the harness connection and the ground connection that are hiding under the intake manifold?
I've been trying to just get an angle where I can get the harness unplugged for 45 minutes now and nothing, WTF?
Old 09-30-2011, 10:05 PM   #16
six_grand
Member
six_grand's Avatar
six_grand is a jewel in the rough of c-rsx six_grand is a jewel in the rough of c-rsx six_grand is a jewel in the rough of c-rsx six_grand is a jewel in the rough of c-rsx six_grand is a jewel in the rough of c-rsx six_grand is a jewel in the rough of c-rsx six_grand is a jewel in the rough of c-rsx six_grand is a jewel in the rough of c-rsx
I feel your pain, just gotta be patient.
six_grand is offline   Reply With Quote
Old 09-30-2011, 10:56 PM   #17
BeaterEP
BeaterEP's Avatar
Goddamn, FINALLY got those connections loose!
Old unit is out, gonna start fresh in the morning and hope reinstalling the new one is a bit smoother
One thing I've learned, universal joint FTW; never could have gotten that last bolt that's closest to the middle of the car without one!
Also noticed that the harness is secured to the alternator with a bracket, and then to the engine further down...is that completely necessary you think? That was what made getting those connections so difficult: had no slack in the harness to turn the alternator around and get at them.
Old 10-01-2011, 08:00 AM   #18
LimaRSX
#selfie
LimaRSX's Avatar
Told you it is an install about patience . I forgot what bracket you're talking about but if the harness is not super lose it should be fine. Mine is lose a bit, I probably took it off the first time and forgot about it.
IG: LimaRSX
HotAvy&SigKrew
Old 10-01-2011, 11:45 AM   #19
BeaterEP
BeaterEP's Avatar
Haha no kidding! Got everything back together but the bumper, waiting on that.
Question: since the alternator gave up while I was driving, and the battery (Odyssey PC925) is only showing about 11.4v after being discharged, do I need to top off the battery first, or can I just start her up and let the alternator do its thing?
...cuz I don't have a battery charger
Old 10-01-2011, 02:59 PM   #20
BeaterEP
BeaterEP's Avatar
Well, had to wait for the wife to get home to jump the car, but everything is running beautifully now.
Thanks again fr the thread/advice!
Old 10-02-2011, 09:48 AM   #21
LimaRSX
#selfie
LimaRSX's Avatar
Just drive around for a few day and see if it gets better. 11.4 is not bad for a car that has been sitting for a bit. It does show the time to change the battery is coming up but that won't be for awhile. My battery gets down to 10v at times and its been like this for 4+ months lol.
No problem glad it all worked out.
IG: LimaRSX
HotAvy&SigKrew
Old 10-02-2011, 12:14 PM   #22
BeaterEP
BeaterEP's Avatar
I figured the low voltage was due to the battery being actively drained when the alternator died, plus the two restarts I managed afterwards.
Now that everything is working again, it shows a steady 12.75v like it should.
Old 10-02-2011, 12:42 PM   #23
LimaRSX
#selfie
LimaRSX's Avatar
12.75 at idle or turned off?
IG: LimaRSX
HotAvy&SigKrew
Old 10-03-2011, 03:50 PM   #24
BeaterEP
BeaterEP's Avatar
Turned off.
High 13s at idle.
Old 10-03-2011, 03:54 PM   #25
LimaRSX
#selfie
LimaRSX's Avatar
Turned off.
High 13s at idle.
Turned off its fine.
High 13's with no load at idle? its alright but ideal is 14-14.7 with no load.
IG: LimaRSX
HotAvy&SigKrew
Reply
Bookmarks
alternator , diy , replacement
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
