Powersteering pump whine when cold out - Club RSX Message Board
Go Back   Club RSX Message Board > GENERAL > Problems & Solutions
Notices
Reply
Thread Tools
Old 10-21-2011, 05:38 PM   #1
Theos92vr4
Senior Member
Theos92vr4's Avatar
Theos92vr4 is a jewel in the rough of c-rsx Theos92vr4 is a jewel in the rough of c-rsx Theos92vr4 is a jewel in the rough of c-rsx Theos92vr4 is a jewel in the rough of c-rsx Theos92vr4 is a jewel in the rough of c-rsx Theos92vr4 is a jewel in the rough of c-rsx Theos92vr4 is a jewel in the rough of c-rsx Theos92vr4 is a jewel in the rough of c-rsx
Hey guys. Having a little issue with my 02 type s. Whenever it is colder out (below 50) my car has a whining noise to it. It comes from the power steering pump, and gets louder as you turn the wheel and pick up speed. The car isnt hard at all to turn, but this noise is driving me crazy.
I checked the fluid level, and its right where its supposed to be. But there are some tiny air bubbles at the top, and it kind of smells like it was burning abit.
My friend seems to think it is the resevior and hose thing. He says they go bad alot. Do you think that could be the problem, or do I need a new powersteering pump?
Thanks guys!
Theos92vr4 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 10-21-2011, 05:45 PM   #2
ChadoDC5
Member
ChadoDC5's Avatar
ChadoDC5 is a jewel in the rough of c-rsx ChadoDC5 is a jewel in the rough of c-rsx ChadoDC5 is a jewel in the rough of c-rsx ChadoDC5 is a jewel in the rough of c-rsx ChadoDC5 is a jewel in the rough of c-rsx ChadoDC5 is a jewel in the rough of c-rsx ChadoDC5 is a jewel in the rough of c-rsx ChadoDC5 is a jewel in the rough of c-rsx
hows the belt? i had the same problem, turns out the belt was just worn out, after changing it the whining went away and also cut down on vibrations
ChadoDC5 is offline   Reply With Quote
Old 10-21-2011, 10:32 PM   #3
Theos92vr4
Senior Member
Theos92vr4's Avatar
The belt looks fine, no chunks missing or stress cracks in it.
The noise actually went away. I drove the car to the grocery store, drove home and then parked it for about an hour. got back into the car and no more noise or anything. Idk what is going on
Old 10-22-2011, 04:45 AM   #4
crdom524
Member
crdom524's Avatar
crdom524 is a jewel in the rough of c-rsx crdom524 is a jewel in the rough of c-rsx crdom524 is a jewel in the rough of c-rsx crdom524 is a jewel in the rough of c-rsx crdom524 is a jewel in the rough of c-rsx crdom524 is a jewel in the rough of c-rsx crdom524 is a jewel in the rough of c-rsx crdom524 is a jewel in the rough of c-rsx
Had the same problem wit my 6mt accord. I just replaced the O-ring from the pumps inlet joint and it worked. got the O-ring a the dealer for less than a dollar. The O-ring seals it so that you don't get air in the pump and stop the noise.
here use this as reference http://www.driveaccord.net/forums/sh...ad.php?t=42915
crdom524 is offline   Reply With Quote
Old 10-22-2011, 06:01 PM   #5
Theos92vr4
Senior Member
Theos92vr4's Avatar
Thanks! ill deffinently give that a try
Old 10-28-2011, 06:28 PM   #6
Theos92vr4
Senior Member
Theos92vr4's Avatar
Changed o-ring and powersteering fluid. Problem is still there. Only happens for a few minutes when its cold out. Very hard to turn the car, almost like it has no power steering at all. I have noticed with the new fluid that the power steering pump has quieted down a bit. Once the car warms up and gets driven for like a mile, it is fine, no problems at all. Any idea what could be wrong?
Old 11-08-2011, 06:52 PM   #7
ritak20
Senior Member
ritak20's Avatar
ritak20 is an unknown quantity on c-rsx
hey i have the same exact problem.... changing the pump asap.. ill let u know
ritak20 is offline   Reply With Quote
Old 11-09-2011, 08:58 AM   #8
vtec-dc5turbo
Member
vtec-dc5turbo's Avatar
vtec-dc5turbo is a jewel in the rough of c-rsx vtec-dc5turbo is a jewel in the rough of c-rsx vtec-dc5turbo is a jewel in the rough of c-rsx vtec-dc5turbo is a jewel in the rough of c-rsx vtec-dc5turbo is a jewel in the rough of c-rsx vtec-dc5turbo is a jewel in the rough of c-rsx vtec-dc5turbo is a jewel in the rough of c-rsx vtec-dc5turbo is a jewel in the rough of c-rsx
Did you use OEM PS fluid when you replaced it?
"If you aint first, you're last" Reese Bobby
vtec-dc5turbo is offline   Reply With Quote
Old 11-09-2011, 09:29 PM   #9
Theos92vr4
Senior Member
Theos92vr4's Avatar
Ok Let me know if that makes a difference. I was told by a friend of mine that their is a filter in the resevior (not replaceable) that gets clogged, which starves the pump of fluid. In order to fix this, he said you have to change the whole resevior. I might try that next and see if that makes a difference before I by a new pump.
Yep 100% oem acura stuff. The fluid was very dirty.
After changing the oring and the fluid I have noticed the steering is better. Doesnt make noise as long as it did, and the stiffness goes away quick.
Old 01-19-2012, 12:42 AM   #10
Theos92vr4
Senior Member
Theos92vr4's Avatar
Well this o-ring didnt solve the problem. Now the car is extremely hard to turn when cold out, and the resevior is leaking. Going to replace the resevior and the pump and see if it fixes the problem.
Old 01-22-2012, 01:58 PM   #11
iluvmyrsxjj
Member
iluvmyrsxjj is a jewel in the rough of c-rsx iluvmyrsxjj is a jewel in the rough of c-rsx iluvmyrsxjj is a jewel in the rough of c-rsx iluvmyrsxjj is a jewel in the rough of c-rsx iluvmyrsxjj is a jewel in the rough of c-rsx iluvmyrsxjj is a jewel in the rough of c-rsx iluvmyrsxjj is a jewel in the rough of c-rsx iluvmyrsxjj is a jewel in the rough of c-rsx
I have the same problem and it drives me crazy too! In for answers!
iluvmyrsxjj is offline   Reply With Quote
Old 01-22-2012, 02:20 PM   #12
Theos92vr4
Senior Member
Theos92vr4's Avatar
I have a used powersteering pump and resevior on the way, ill let you know if that fixes the problem when I get it installed in about a week
Old 01-22-2012, 04:32 PM   #13
02kseries
I don't care
02kseries's Avatar
02kseries is a jewel in the rough of c-rsx 02kseries is a jewel in the rough of c-rsx 02kseries is a jewel in the rough of c-rsx 02kseries is a jewel in the rough of c-rsx 02kseries is a jewel in the rough of c-rsx 02kseries is a jewel in the rough of c-rsx 02kseries is a jewel in the rough of c-rsx 02kseries is a jewel in the rough of c-rsx
i just let my car warm up a little before i drive it, then it doesnt wine..... it gets real cold up here in NY
2002 fpr rsx-s
200k+
94 jeep cherokee sport
5in lift 33x12.50s
02kseries is offline   Reply With Quote
Old 02-04-2012, 05:09 PM   #14
Theos92vr4
Senior Member
Theos92vr4's Avatar
Just incase anyone else has this problem, it wound up being a bad powersteering pump. I put a new pump in the car and a new resevior, and now its perfect.
Old 02-05-2012, 07:29 PM   #15
iluvmyrsxjj
Member
How difficult was the install? I'm not very car savvy and I don't want to pay the mechanic.
Old 02-06-2012, 02:37 AM   #16
My02DC5
My02DC5's Avatar
My02DC5 is a jewel in the rough of c-rsx My02DC5 is a jewel in the rough of c-rsx My02DC5 is a jewel in the rough of c-rsx My02DC5 is a jewel in the rough of c-rsx My02DC5 is a jewel in the rough of c-rsx My02DC5 is a jewel in the rough of c-rsx My02DC5 is a jewel in the rough of c-rsx My02DC5 is a jewel in the rough of c-rsx My02DC5 is a jewel in the rough of c-rsx
Just move the tensioner back, pull the belt off. Remove the hoses going to it and unscrew the two bolts keeping the pump in place, and it comes right off.
APB RSX TYPE-S
NHBP RSX TYPE-S
Yamaha R6
Motorcycle Crew #19
My02DC5 is offline   Reply With Quote
Old 09-20-2013, 01:10 PM   #17
Acuratype-s04
Member
Acuratype-s04's Avatar
Acuratype-s04 is a jewel in the rough of c-rsx Acuratype-s04 is a jewel in the rough of c-rsx Acuratype-s04 is a jewel in the rough of c-rsx Acuratype-s04 is a jewel in the rough of c-rsx Acuratype-s04 is a jewel in the rough of c-rsx Acuratype-s04 is a jewel in the rough of c-rsx Acuratype-s04 is a jewel in the rough of c-rsx Acuratype-s04 is a jewel in the rough of c-rsx
i have an 04 type s and was wondering if i should replace my power steering pump because when i turn left it will vibrate and whine as well i replaced the belt 2 or 3 months ago. could some of the noise be from a bad pulley? and also all my fluid are fine.
Acuratype-s04 is offline   Reply With Quote
Reply
Bookmarks
cold , powersteering , pump , whine
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
