DIY: Honda CRV Turn Signal Switch "Replaces Cheapo Ebay Switch" - Club RSX Message Board
Notices
Reply
Thread Tools
Old 12-23-2011, 06:09 PM   #1
02civic629
02civic629 is a jewel in the rough of c-rsx 02civic629 is a jewel in the rough of c-rsx 02civic629 is a jewel in the rough of c-rsx 02civic629 is a jewel in the rough of c-rsx 02civic629 is a jewel in the rough of c-rsx 02civic629 is a jewel in the rough of c-rsx 02civic629 is a jewel in the rough of c-rsx 02civic629 is a jewel in the rough of c-rsx
Ok well starting off i know alot of people on here run the ebay fog light kit and there's nothing wrong with the kit but the cheap ass switch they send you. This DIY replaces that with the honda crv switch. Its a cheap and clean looking idea. If you dont like it idgaf and you can keep your cheap gay ebay switch....... Sorry for the shity pictures and no detail in write-up. Im pushing for time and this should be good enough. If you have more questions just post them below and i will gladly answer them later
FYI: THIS DIY WAS DONE ON A BASE RSX....... not sure if there are differences on a type s but should be the same
Parts/Tools Needed
1.) Honda CRV Turn Signal Switch "Obviously"
2.) Phillips Head Screwdriver
3.) Flat Head Screwdriver
4.) 3-4 Ft Of Wire
5.) 2 Wire Connectors
6.) Electrical Crimper/Splicer
FIRST OFF PLEASE READ THROUGH THE WHOLE THING!!!!! IF YOUR NO GOOD WITH WIRES PLEASE STOP HERE AND FIND SOMEONE THAT DOES...............
Ok first you can unplug your battery if you feel like it, i didnt, but thats all up to you, just adding it in there
Next get in the car and look for these three screws under the steering collum, they should come outta these three holes on the bottom
Then take a flat head and separate the top and bottom pieces apart, it wont break there just clips holding it together
Then look for these two screws on the turn signal switch, they come from this area right here, there is a little push clip holding it in once the screws are removed, IT WAS A PAIN TO REACH, so i just gave up and gave it a strong pull and out came the turn signal switch lol
Unplug the connector on the back and this is what it should look like
Ok now grab the flat head again and pop the side console out, its the one with the sunroof button in it, "yes i know my cruise is upside down its an inside joke" lol lol
Pull the cheapo fog switch out, mine was half broken anyway and it should have a green tab on it
Next go back to the turn signal switch pin holder thing and tap in two wires in the top left side "they are the slighter bigger blue wires, you can see witch ones they go in, i just cut the ends some, pushed it in and bend the metal part of the wire inside so they wouldnt just fall out, and when the switch gets pushed in it should really hold it, but just in case i zip-tied the wires to the factory wires so there no chance of them slipping out
Here are some shots of the factory one vs crv one
Go back to the ebay wire switch thing, take it off and you should see 4 wires coming out, with mine i had to cut the two middles wires, i just tucked the switch back behind the dash when i had cut them
Here are the two cut middle wires
Now connect those two the two blue wires you tapped off of the turn signal switch, you can connect them this way to see if everything works properly, test them this way cause if the wires have to swapped just swap them if your fogs are on when on the off switch, but if its off and the fogs are off its wired correctly, then wire connect them together then crimp the wires like this
Now put everything back together following the reverse of this "if you cant get it back together thats pretty sad" but re-read the beginning if you need help, and here are some finished pictures, i needed to remove the ebay fog so i could install my purge button for my nitrous
And of course since this was the HARDEST thing in world to do, once you finish sit back and crack open a nice ice cold beer and relax……. Lol lol lol lol lol
02civic629 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 12-23-2011, 06:10 PM   #2
02civic629
Res for questions and answers
Which switches will work, and where can i find one??
you have to just find one on ebay or go to the dealership because all models didnt come with the fog light add on for the switch, all these models will work though if you can find one with the fog light switch add on >>> 03-08 PILOT, 07-08 FIT, 02-06 CR-V, and 03-08 ELEMENT switch
Whats the part number for the switch??
The part number for the combination switch with the fog light switch is: 35255-S5K-F12.
How much does the switch cost??
Retail is about $100. Discounted retail is about $70 + shipping. eBay: $35 shipped, sold by alphaautomotive. Linked. I just bought one off of eBay, so 8 more remains.
Old 12-23-2011, 06:26 PM   #3
Type-Spaz
Hybrid-Racing.com
Type-Spaz's Avatar
Type-Spaz has disabled reputation
I have a factory setup and its more in-depth than the whay cheapo setup. I tried just doing that and it didn't want to work for me... when I get home from Disney world I will try it again.. oh wait my cars in a million pieces! Well I'll save this this thread for when my cars back together.
Type-Spaz is offline   Reply With Quote
Old 12-23-2011, 06:28 PM   #4
02civic629
well if i get a hold of the factory wire diagram i can deff help you out, should be cake
Old 12-23-2011, 06:30 PM   #5
josolanes
kprotuners.com
josolanes's Avatar
josolanes might be well recognized one day on c-rsx josolanes might be well recognized one day on c-rsx josolanes might be well recognized one day on c-rsx josolanes might be well recognized one day on c-rsx josolanes might be well recognized one day on c-rsx josolanes might be well recognized one day on c-rsx josolanes might be well recognized one day on c-rsx josolanes might be well recognized one day on c-rsx
What are you up to now spaz?
josolanes is offline   Reply With Quote
Old 12-23-2011, 07:39 PM   #6
prxr88
Garrett
prxr88's Avatar
prxr88 is a jewel in the rough of c-rsx prxr88 is a jewel in the rough of c-rsx prxr88 is a jewel in the rough of c-rsx prxr88 is a jewel in the rough of c-rsx prxr88 is a jewel in the rough of c-rsx prxr88 is a jewel in the rough of c-rsx prxr88 is a jewel in the rough of c-rsx prxr88 is a jewel in the rough of c-rsx
nice and "OEM" good shit
466hp 319tq 15psi Pump 93
545hp 392tq 22psi C16
GTX3076R
prxr88 is offline   Reply With Quote
Old 12-23-2011, 07:42 PM   #7
LimaRSX
#selfie
LimaRSX's Avatar
LimaRSX is not even half way to the top LimaRSX is not even half way to the top
LimaRSX is not even half way to the top LimaRSX is not even half way to the top LimaRSX is not even half way to the top LimaRSX is not even half way to the top LimaRSX is not even half way to the top LimaRSX is not even half way to the top LimaRSX is not even half way to the top LimaRSX is not even half way to the top LimaRSX is not even half way to the top LimaRSX is not even half way to the top
Wow this is perfect, great diy, never would of thought of that.
Fuck this fucking build crew
IG: LimaRSX
HotAvy&SigKrew
LimaRSX is offline   Reply With Quote
Old 12-23-2011, 08:20 PM   #8
Obleezie
:Drool:
Obleezie's Avatar
Obleezie might be well recognized one day on c-rsx Obleezie might be well recognized one day on c-rsx Obleezie might be well recognized one day on c-rsx Obleezie might be well recognized one day on c-rsx Obleezie might be well recognized one day on c-rsx Obleezie might be well recognized one day on c-rsx Obleezie might be well recognized one day on c-rsx Obleezie might be well recognized one day on c-rsx
did this couple of years back think i was one of the first that did it but i used a Fit switch and i love it! nice job
[SIGPIC][/SIGPIC]
Obleezie is offline   Reply With Quote
Old 12-23-2011, 08:25 PM   #9
NinetySixYenko
The CRSX Philosopher
NinetySixYenko's Avatar
NinetySixYenko is on a distinguished road NinetySixYenko is on a distinguished road
That's pretty baller. Only question I have is do they turn off then hi beams get turned on? I always thought that was stupid, why mine are wired to corner markers.
14 RAM
00 S2000
15 WRX
04 RX-8
03 RSX-S
NinetySixYenko is offline   Reply With Quote
Old 12-23-2011, 09:20 PM   #10
bsivoljr
Dafkup
bsivoljr's Avatar
bsivoljr is a jewel in the rough of c-rsx bsivoljr is a jewel in the rough of c-rsx bsivoljr is a jewel in the rough of c-rsx bsivoljr is a jewel in the rough of c-rsx bsivoljr is a jewel in the rough of c-rsx bsivoljr is a jewel in the rough of c-rsx bsivoljr is a jewel in the rough of c-rsx bsivoljr is a jewel in the rough of c-rsx
does the fit switch look better than the crv?
Had a K long before I bought the RSX...
bsivoljr is offline   Reply With Quote
Old 12-23-2011, 09:21 PM   #11
Obleezie
:Drool:
Obleezie's Avatar
there the same thing
[SIGPIC][/SIGPIC]
Old 12-23-2011, 09:32 PM   #12
bsivoljr
Dafkup
bsivoljr's Avatar
thnks You have a DIY?
Nice job O.P. Thanks for the DIY. Now I just need to convince myself to get fogs :P. Doing 05-06 Conversion though so I'll need 05-06 style I guess
Old 12-23-2011, 09:38 PM   #13
Obleezie
:Drool:
Obleezie's Avatar
its basically the same DIY as this, he did a great job on it i just dont have the patience to do DIY but i made my own harness so i can turn them at any time
[SIGPIC][/SIGPIC]
Old 12-23-2011, 09:41 PM   #14
bsivoljr
Dafkup
bsivoljr's Avatar
Nice. Yeah so many things I could have D.I.Y but didn't feel like snapping pics. I would want the wiring to appear stock more than just rigged to work if that makes sense. IDK
Old 12-23-2011, 09:52 PM   #15
02civic629
Probably something sick to blow us all away
well now you can do it
yea i saw yours but no DIY so i made one but used to crv one
no mine dont cause there wired through the side markers like yours, thats the baller way lol, and yes having them go off on high beams is dump lol
correct just the honda crv switch is cheaper
well do the 05-06 conversion its better imo, but i do have a spot for the 02-04 though, just matters the look your going for
yea honestly it is the same, you can use any switch, its the same wiring, its just harder to find fit switches vs crv switches
Old 12-23-2011, 10:17 PM   #16
chubby1_8888
GET'er DONE
chubby1_8888's Avatar
chubby1_8888 is a jewel in the rough of c-rsx chubby1_8888 is a jewel in the rough of c-rsx chubby1_8888 is a jewel in the rough of c-rsx chubby1_8888 is a jewel in the rough of c-rsx chubby1_8888 is a jewel in the rough of c-rsx chubby1_8888 is a jewel in the rough of c-rsx chubby1_8888 is a jewel in the rough of c-rsx chubby1_8888 is a jewel in the rough of c-rsx
Dam gonna try this when I get my fogs
chubby1_8888 is offline   Reply With Quote
Old 12-23-2011, 10:23 PM   #17
mazharracer
Mazharracer
mazharracer's Avatar
mazharracer is a jewel in the rough of c-rsx mazharracer is a jewel in the rough of c-rsx mazharracer is a jewel in the rough of c-rsx mazharracer is a jewel in the rough of c-rsx mazharracer is a jewel in the rough of c-rsx mazharracer is a jewel in the rough of c-rsx mazharracer is a jewel in the rough of c-rsx mazharracer is a jewel in the rough of c-rsx mazharracer is a jewel in the rough of c-rsx
nice
Instagram: mazharracer
mazharracer is offline   Reply With Quote
Old 12-23-2011, 10:37 PM   #18
bsivoljr
Dafkup
bsivoljr's Avatar
lol. Nice tip...
Yeah The 02-04 is unique and I have a soft spot for it too. It's the original DC5. Im sure I'll be happy with the 05-06 too though
Old 12-23-2011, 10:46 PM   #19
02civic629
i wish i woulda known this when i installed fogs lol
Originally Posted by mazharracer View Post
nice
yea im wondering what to do next....... im working the tl-s steering wheel conrols but i cant seem to get it right yet
lol. Nice tip...
yea your welcome lol, and yea the 02's look more original and aggressive but the 05's look cleaner and sexier lol
Old 12-24-2011, 01:35 PM   #20
plAythiNG
Master Member
plAythiNG's Avatar
plAythiNG is a jewel in the rough of c-rsx plAythiNG is a jewel in the rough of c-rsx plAythiNG is a jewel in the rough of c-rsx plAythiNG is a jewel in the rough of c-rsx plAythiNG is a jewel in the rough of c-rsx plAythiNG is a jewel in the rough of c-rsx plAythiNG is a jewel in the rough of c-rsx plAythiNG is a jewel in the rough of c-rsx
Great diy mate as it frees up a spot in that drivers side console area.
IG: @localauthorityco | @ahoyhoy88
Need anything from Japan/Australia? PM me, paypal accepted!
plAythiNG is offline   Reply With Quote
Old 12-25-2011, 10:03 PM   #21
02civic629
yea true
Old 12-27-2011, 07:44 PM   #22
Alters1did
BROKE BUILD
Alters1did's Avatar
Alters1did is a jewel in the rough of c-rsx Alters1did is a jewel in the rough of c-rsx Alters1did is a jewel in the rough of c-rsx Alters1did is a jewel in the rough of c-rsx Alters1did is a jewel in the rough of c-rsx Alters1did is a jewel in the rough of c-rsx Alters1did is a jewel in the rough of c-rsx Alters1did is a jewel in the rough of c-rsx
What year crv is the turn signal switch from?
2003 type s k20z1 swaped all motor build in the works
Alters1did is offline   Reply With Quote
Old 12-27-2011, 07:54 PM   #23
02civic629
Originally Posted by alters1did View Post
what year crv is the turn signal switch from?
02-06 cr-v
Old 12-28-2011, 08:16 AM   #24
SneakyyJ
Member
SneakyyJ's Avatar
SneakyyJ is a jewel in the rough of c-rsx SneakyyJ is a jewel in the rough of c-rsx SneakyyJ is a jewel in the rough of c-rsx SneakyyJ is a jewel in the rough of c-rsx SneakyyJ is a jewel in the rough of c-rsx SneakyyJ is a jewel in the rough of c-rsx SneakyyJ is a jewel in the rough of c-rsx SneakyyJ is a jewel in the rough of c-rsx
I was looking for the turn signal you used... and I was only able to find this part (#13).
35255-S5A-A02
It doesn't seem to have the fog light switch though. Could you direct me to the right switch?
Thanks for the info!
SneakyyJ is offline   Reply With Quote
Old 12-28-2011, 11:18 AM   #25
02civic629
35255-S5A-A02
Yea i had the same problem, you have to find one with the fog light light switch cause all models didnt come with fog lights, only ones that were pre-ordered with fogs
You just have to search, these are the models that you can look up to find one with fogs that fit in our cars 03-08 PILOT, 07-08 FIT, 02-06 CR-V, and 03-08 ELEMENT switch...... if you find a switch outta those with the fog light add on it will work
Reply
Bookmarks
crv , diy , honda , signal , switch , turn
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright © 2001-2012, Club RSX, Inc. All rights reserved worldwide.
