Question about 255/40/17 on 17X9 +35 wheels - Club RSX Message Board
Go Back   Club RSX Message Board > SUSPENSION > Wheels & Tires
Notices
Reply
Thread Tools
Old 03-01-2012, 02:28 PM   #1
Harry Paratestes
Member
Harry Paratestes's Avatar
Harry Paratestes is a jewel in the rough of c-rsx Harry Paratestes is a jewel in the rough of c-rsx Harry Paratestes is a jewel in the rough of c-rsx Harry Paratestes is a jewel in the rough of c-rsx Harry Paratestes is a jewel in the rough of c-rsx Harry Paratestes is a jewel in the rough of c-rsx Harry Paratestes is a jewel in the rough of c-rsx Harry Paratestes is a jewel in the rough of c-rsx
I know this has been discussed to death but I'd like to hear from the people who are running this combination what modifications, aside from rolling the rear fender, will need to be done. I'm running -1.5 in the front and -.75 in the rear. I haven't ordered the tires yet and now thinking about stepping down to a 245/40/17 to avoid excessive fender modifications.
Does anybody currently run this setup? If so, could you post pictures of what the fitment looks like. I found some other pictures of people running this setup and it looks like I'd need to run more camber in the front and rear to make it work.
Thanks.
Harry Paratestes is offline   Reply With Quote
Sponsored Links
Advertisement
Old 03-01-2012, 03:39 PM   #2
shattered_memory
member
shattered_memory's Avatar
shattered_memory is an unknown quantity on c-rsx
Usually I would tell people to search, but since you are doing the right thing by getting 255s all around I'll help u out. Basically it depends how low you are. The lower you are the more negative camber you will need. Generally you should get -2 camber front and -1 or -1.5 rear. Remember to run 0 toe all around. And the only fender mod you need is a rear fender roll. You can leave the front fenders alone.
shattered_memory is offline   Reply With Quote
Old 03-01-2012, 04:13 PM   #3
Harry Paratestes
Member
Thanks a lot for your help. Here's a picture of the car as it sits right now:
There's a 1.5 finger gap between the wheel and fender in all 4 corners.
I've searched on the topic and haven't really found anybody that has said what you just did. What I have found most is the +22 vs +35 debate. Maybe I'm not using the right search terms.
Do those camber settings cause accelerated tire wear?
Old 03-01-2012, 06:19 PM   #4
shattered_memory
member
^as long as you keep the toe at 0, there shouldn't be accelerated tire wear.
Old 03-01-2012, 06:50 PM   #5
traviswsparks
Senior Member
traviswsparks's Avatar
traviswsparks is a jewel in the rough of c-rsx traviswsparks is a jewel in the rough of c-rsx traviswsparks is a jewel in the rough of c-rsx traviswsparks is a jewel in the rough of c-rsx traviswsparks is a jewel in the rough of c-rsx traviswsparks is a jewel in the rough of c-rsx traviswsparks is a jewel in the rough of c-rsx traviswsparks is a jewel in the rough of c-rsx
Im guessing that if you are getting an alignment from a shop...one can tell them the camber and toe specs you want, and they can put it there. Is that correct? Bc I also have some 17x9 +35 with 245/40 on the way.
K24 Turbo Crew
403whp/ 386lb/ft 11psi 6265 turbo
traviswsparks is offline   Reply With Quote
Old 03-01-2012, 10:25 PM   #6
shattered_memory
member
Most alignment shops will do custom alignments. Just call and Ask them.
Old 09-08-2014, 12:18 PM   #7
APB604
Member
APB604 is a jewel in the rough of c-rsx APB604 is a jewel in the rough of c-rsx APB604 is a jewel in the rough of c-rsx APB604 is a jewel in the rough of c-rsx APB604 is a jewel in the rough of c-rsx APB604 is a jewel in the rough of c-rsx APB604 is a jewel in the rough of c-rsx APB604 is a jewel in the rough of c-rsx
bumping an old thread.. did you ever go for 255/40/17?
I'm looking at 17x8.5" and curious if the tires would be a good match.
I'm lowered 3/4 of an inch currently and will never be going any lower than 1".
APB604 is offline   Reply With Quote
Old 10-14-2014, 08:39 PM   #8
kmouze
that niqqa
kmouze's Avatar
kmouze is a jewel in the rough of c-rsx kmouze is a jewel in the rough of c-rsx kmouze is a jewel in the rough of c-rsx kmouze is a jewel in the rough of c-rsx kmouze is a jewel in the rough of c-rsx kmouze is a jewel in the rough of c-rsx kmouze is a jewel in the rough of c-rsx kmouze is a jewel in the rough of c-rsx
i thought i was going to be trouble free doing 17x9 35 with 255 40 tires ended up with non of my tires fitting!!!! > so angry. front fenders rubbed. rears rubbed, but thats a given didnt roll fenders
slow slow slow
kmouze is offline   Reply With Quote
Old 10-23-2014, 01:47 AM   #9
Killabaku
New Member
Killabaku is a jewel in the rough of c-rsx Killabaku is a jewel in the rough of c-rsx Killabaku is a jewel in the rough of c-rsx Killabaku is a jewel in the rough of c-rsx Killabaku is a jewel in the rough of c-rsx Killabaku is a jewel in the rough of c-rsx Killabaku is a jewel in the rough of c-rsx Killabaku is a jewel in the rough of c-rsx
So you think with rolled fenders/ a little negative camber you won't rub at all?
Killabaku is offline   Reply With Quote
Old 10-23-2014, 03:03 AM   #10
Killabaku
New Member
Curious to know because I plan on going 17x9 +35. I have all my fenders rolled and was planning on going with a 245 tire but if I can get a 255 might go that route since I already own 255s.
Old 10-23-2014, 05:50 AM   #11
dan_nguyen
Vietnamese Singer
dan_nguyen's Avatar
dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own
dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own
Yes, depending on your ride height. You don't really need that much camber at all, just roll the rears. Your fronts will probably rub on full lock turns, but that's just something to live with. Will probably rub on fender liners too if you still have them, I ended up trimming the liners
dan_nguyen is offline   Reply With Quote
Old 10-23-2014, 05:56 AM   #12
Killabaku
New Member
Yea I have rolled fronts and rears and no gender liner. Car was tucking tire on 17x9.5 +18 before with 215 tires lol. Not a big fan of the stretched/slammed thing although I have to admit it looks cool but switching up the car and thinking of going 17x9 +35 with the 255.
Old 10-23-2014, 06:19 AM   #13
dan_nguyen
Vietnamese Singer
dan_nguyen's Avatar
Boom you'll be fine then. Depending on the height you might not need a ton of camber.
Old 10-25-2014, 11:59 PM   #14
a4andy
dafuq?
a4andy's Avatar
a4andy might be well recognized one day on c-rsx a4andy might be well recognized one day on c-rsx a4andy might be well recognized one day on c-rsx a4andy might be well recognized one day on c-rsx a4andy might be well recognized one day on c-rsx a4andy might be well recognized one day on c-rsx a4andy might be well recognized one day on c-rsx a4andy might be well recognized one day on c-rsx
Yeah you're fine.
I fit 17x9 +22 245/40 fine in the rears
Had a little trouble with 17x9 +17 245/40 for the fronts but I got it to work.
1/2 finger gap all around.
Follow me on INSTAGRAM: @DailyDC5
a4andy is online now   Reply With Quote
Reply
Bookmarks
17x9 , or 17 , question , wheels
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
