(Soon to be) 6-speed base crew advice - Club RSX Message Board
Go Back   Club RSX Message Board > PERFORMANCE BASICS > Bolt-On Basics: RSX (Base)
Notices
Reply
Thread Tools
Old 03-12-2012, 08:33 PM   #1
turbinator1990
Master Member
turbinator1990's Avatar
turbinator1990 is a jewel in the rough of c-rsx turbinator1990 is a jewel in the rough of c-rsx turbinator1990 is a jewel in the rough of c-rsx turbinator1990 is a jewel in the rough of c-rsx turbinator1990 is a jewel in the rough of c-rsx turbinator1990 is a jewel in the rough of c-rsx turbinator1990 is a jewel in the rough of c-rsx turbinator1990 is a jewel in the rough of c-rsx
I made a new thread so I can get the attention of the 6-speed base crew who can give me some expert input.
I am close to picking up a 05 6-speed transmission from a 05 type-s; $700 SHIPPED
I just need some input to see if this is a good price or worth the effort?
-Also wanted to ask what aftermarket clutch/flywheel should I stick to? Competition, ATC or Exedy? I think I should be fine with a stage 2, budget would be $300-ish ( still need to do a bit more research though)
Here are the details about the transmission:
2005 Acura RSX type S 6 speed manual transmission. This transmission was removed from a customer car who purchased a new transmission because this one had difficulty shifting int 2nd gear. I saved it from going to the core man (for scrap) and replaced the 2nd gearset.
VIN JH4DC53025S010704
Replaced parts with part numbers:
2nd Gearset 23432-PNS-315
Bearing 91002-RAS-003
Bearing 91004-PPP-014
Will include 2 new axle seals part numbers (installed)
91206-PHR-003
91205-PL3-B01
Will also include new crush washers, new tube of HondaBond and new can of Ultraflange
Comes with all sensors and bolts, oem brackets and shifter mechanisim, drain and fill plugs, clutch release fork. In other words its a complete 6 speed manual transmission for a k20Z1.
The transmission has not been installed or driven on since the gearset replacement. It shifts into all gears ok on workbench. The transmission was removed from the customer vehicle with 65,190 miles.
turbinator1990 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 03-12-2012, 09:25 PM   #2
LimaRSX
#selfie
LimaRSX's Avatar
LimaRSX is not even half way to the top LimaRSX is not even half way to the top
LimaRSX is not even half way to the top LimaRSX is not even half way to the top LimaRSX is not even half way to the top LimaRSX is not even half way to the top LimaRSX is not even half way to the top LimaRSX is not even half way to the top LimaRSX is not even half way to the top LimaRSX is not even half way to the top LimaRSX is not even half way to the top LimaRSX is not even half way to the top
Price and tranny condition sounds great, is this from a member or a shop?
As for clutch I would go with the CC 1.5 with 11.5 flywheel combo. If you plan to stay all motor as a 200whp base crew this would be an awesome setup.
I would also get the mtec race spring/pivot ball upgrade while the tranny is out. Also get some crsx metal tranny/shifter bushings.
Fuck this fucking build crew
IG: LimaRSX
HotAvy&SigKrew
LimaRSX is offline   Reply With Quote
Old 03-12-2012, 09:32 PM   #3
LimaRSX
#selfie
LimaRSX's Avatar
Oh n if you have the extra money install an lsd
IG: LimaRSX
HotAvy&SigKrew
Old 03-12-2012, 10:18 PM   #4
RastaRican718
Master Member
RastaRican718's Avatar
RastaRican718 is an unknown quantity on c-rsx
Sounds good bro, my swap went very smoothly, n yea lima is right, Stage 1.5 clutch and the 11.5 flywheel. Thats what I put in it works great.
2013 Subaru WRX
Nameless Performance Muffler DeleteC
RastaRican718 is offline   Reply With Quote
Old 03-12-2012, 10:24 PM   #5
turbinator1990
Master Member
-Its a member who works @ Honda.
-I already have the mtec race spring, and Hybrid Racing shifter bushings and JTC customs SS
- I wish I had the extra $ for a LSD but it would cost me 700 for lsd and more to install it, not worth it in my case
Old 03-12-2012, 10:36 PM   #6
LimaRSX
#selfie
LimaRSX's Avatar
Honestly lsd should be 400ish and 2 hours of labor max to install
IG: LimaRSX
HotAvy&SigKrew
Old 03-12-2012, 10:40 PM   #7
turbinator1990
Master Member
where are u getting these numbers from? Quaife and Wavetrac LSD are around $800 bucks and there would be no point getting a OEM K20z3 or K20a LSD...That 2 hour labor would be around another $200... Honestly I wish I had that kind of $$
Old 03-12-2012, 10:50 PM   #8
LimaRSX
#selfie
LimaRSX's Avatar
Im doin oem lsd on boost. It helps a lot
IG: LimaRSX
HotAvy&SigKrew
Old 03-12-2012, 10:55 PM   #9
turbinator1990
Master Member
I wish I could boost but there is way too much potential problems I could face so I'll stay N/A for now. I wouldnt go through the effort and put a oem LSD thats just me.
Old 03-13-2012, 08:25 PM   #10
cB7Dc5RR
PRO-TECH AutoWorks
cB7Dc5RR is a jewel in the rough of c-rsx cB7Dc5RR is a jewel in the rough of c-rsx cB7Dc5RR is a jewel in the rough of c-rsx cB7Dc5RR is a jewel in the rough of c-rsx cB7Dc5RR is a jewel in the rough of c-rsx cB7Dc5RR is a jewel in the rough of c-rsx cB7Dc5RR is a jewel in the rough of c-rsx cB7Dc5RR is a jewel in the rough of c-rsx
Yeah that's a good price and idea do it...
You should go with a CC 1.5 or stg2 and a street light flywheel 11.5,12lb nothing lighter.
As for a Oem LSD it's worth it but of corse a quaife would be better but it cost more..
"IF you're not going to come correct, don't come at all"
cB7Dc5RR is offline   Reply With Quote
Old 03-13-2012, 08:28 PM   #11
SpartanDC5
Sparta Killa DC5
SpartanDC5's Avatar
SpartanDC5 is a jewel in the rough of c-rsx SpartanDC5 is a jewel in the rough of c-rsx SpartanDC5 is a jewel in the rough of c-rsx SpartanDC5 is a jewel in the rough of c-rsx SpartanDC5 is a jewel in the rough of c-rsx SpartanDC5 is a jewel in the rough of c-rsx SpartanDC5 is a jewel in the rough of c-rsx SpartanDC5 is a jewel in the rough of c-rsx
Who's doing the install?
Show off Thread
http://forums.clubrsx.com/showthread...9#post37175609
-RBC 70MM-Injen-Apexi-Mugen-Spoon-Type-R-AEM-Hondata-Kenwood-Tein-Ingals-BBS-
Daily 2015 Lexus IS-250 F-Sport
2014 BRZ-Limited Subaru
2002 Rsx-s k20a +240 whp
SpartanDC5 is offline   Reply With Quote
Old 03-20-2012, 08:30 PM   #12
turbinator1990
Master Member
I have not thought about the installation just yet. I have yet to decide and order my clutch and flywheel. I could get it done at a family friend's shop (prob going to do it here cause of lift) or do the swap myself with a friend.
I am in no rush for the transmission, Next week in spring break so it would be perfect but I still have to find the clutch and flywheel somewhere since CRSX doesnt have the stage 1.5 in stock...
Know any local stores?
Old 04-19-2012, 03:53 PM   #13
CyberCT
Senior Member
CyberCT's Avatar
CyberCT is an unknown quantity on c-rsx
Gotta be honest .... if you can somehow save up the money and find a used good condition even OEM LSD, it will be WELL worth it. The car will handle SOOO much better. You will feel much less resistance going around turns, the steering wheel will not fight you.
The gearing of the 5-speed is God-awful.
2006 RSX Base (Nighthawk Black Pearl)
Suspension: Type-R Rear Floor Bar & Rear Sway Bar; A-Spec Struts & Springs; Spoon Front Strut Tower Bar; -1.5 Camber Front & -0.5 Rear; Enkei RPF1 17x7 14.6lb
Transmission: RSX-S 6-Speed Trans w/ Quaife LSD & CTR 5.062FD & TSX 6th; CC Stage 1.5 Clutch; CC 8lb Flywheel
I/H/E: Injen CAI; Comptech Type-S Shorty Header; 05-06 Type-S Stock Exhaust
CyberCT is offline   Reply With Quote
Old 07-22-2012, 12:56 AM   #14
turbinator1990
Master Member
The transmission swap is around the corner. I bought a Competition stage 2 clutch and flyweel and all the Honda MTF I need. Now I am reading up on the service manual to see installation and removal.
I read from another thread and I read:
"You might as well change the Clutch master Cylinder with this...
http://www.kseriesparts.com/cr/HON-46920-S5A-G06.html
and for the slave, this one...
http://www.kseriesparts.com/cr/HON-46930-S6M-003.html
it has a different part # than the 05-06 5-speed slave"
I was not sure if I should go with replacing those parts or just stick with my base ones. Also I noticed that the bolt locations for the transmission are in a different location from the 5-speed and the 6-speed, will there be any problems with that? I made sure to get the same gen tranny (K20z1)
Reply
Bookmarks
6speed , advice , base , crew
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
