Go Back   Club RSX Message Board > PERFORMANCE BASICS > All Motor
Reply
Thread Tools
Old 05-18-2003, 03:27 AM   #1
kickinit
K-Series Enthusiast
kickinit's Avatar
Trannies interchangable for k series?
I was just curious whether trannies are interchangeable among all K series engines...
RWD 2.0... C O M I N G - S O O N
kickinit is offline   Reply With Quote
Old 05-18-2003, 12:38 PM   #2
GramLightsTypeS
Senior Member
GramLightsTypeS's Avatar
yes
Team UAS
2002 Rsx Type-S
House of Kolors
Base-Nova Orange
Pearl-Tangerine
Oem Carbon Fiber Hood
JDM Black Housing Headlights
Skunk 2 Race Springs (2.5f,2.25r)
Pop on Filter on Factory intake arm
2 1/2 inch custom exhaust cat-back to apex n1 muffler
Hondata K-Pro
9.489@76.12 (K20a2)
9.330@75.84 (K24a1,torque owns the S)
K20a2 R.I.P. 10/18/05 mileage:80942
K24a1 11/18/05
Dyno 12/11/05: 162 hp@5200rpms/157 tq@2200rpms Air Fuel Tune Only
GramLightsTypeS is offline   Reply With Quote
Old 05-20-2003, 11:38 AM   #3
cUl8rV8
Senior Member
cUl8rV8's Avatar
Originally posted by GramLightsTypeS
yes
no,
I am 99.9% positive that the TSX tranny does not bolt up. I am uncertain about others, but that magnesium case was really interesting.
cUl8rV8 is offline   Reply With Quote
Old 05-21-2003, 11:44 PM   #4
Spy RSX-S
Get Wet!
Spy RSX-S's Avatar
would it be possible just to swap internal tranny parts and use the TSX's magnesium case?
spy
2002 RSX Type-S, NHB
WHP- First Run- 186 WHP @ 7400 RPMS
Second Run- 192 WHP @ 7950 RPMS
Third Run- 192.77 WHP @ 7900 RPMS
[[[TRADED]]]- 350Z/Touring/Aero Kit/Auto
Family Rides
Mom- 97 TT Supra- 427 WHP, 96 Jeep Wrangler, 1967 427 Stingray (red with white stripes), 01'Jaguar XK8, 03Toyota Tocoma, 2 Harleys, 04 SL 500
Dad- 02 E430, 01 S2000 ( AEM CAI + Tanabe SRM), 03 Black Porsche Turbo, 05 Black Porsche Turbo (ordered), Ford GT40 (in the bidding process)
Brother- RSX Type S (U.C.) [[[ TRADED]]]- 350Z/Touring/Nismo Package/6Speed
Spy RSX-S is offline   Reply With Quote
Old 05-21-2003, 11:56 PM   #5
cUl8rV8
Senior Member
cUl8rV8's Avatar
no, the internal parts are not the problem. The case is the item that bolts to the block. Swap the block and the tranny, and you are in business!
again, only 99% certain
Old 05-22-2003, 12:00 AM   #6
Spy RSX-S
Get Wet!
Spy RSX-S's Avatar
i am hoping your wrong hehehe
spy
Family Rides
Old 05-22-2003, 06:12 AM   #7
Hadean
Rice Master
Hadean's Avatar
I am lucky. i got the JDM gearbox and LSD when i got my car
JDM STYLE TUNING.COM
http://www.jdmstyletuning.com
THE TEMPLE OF VTEC
http://www.vtec.net
Hadean is offline   Reply With Quote
Old 05-22-2003, 07:03 AM   #8
RSXracer200
Liquid Shwartz
the "case" of the trans mission is called the bell housing....but anyways, im 99% sure that the all the K series transmissions are interchangable with custom mounting kits.
RSXracer200 is offline   Reply With Quote
Old 05-22-2003, 08:30 AM   #9
cUl8rV8
Senior Member
cUl8rV8's Avatar
Since I am 99% certain you are wrong, Now I have got to know the answer. I think I will do a search.
Old 05-22-2003, 08:03 PM   #10
Glimpse
Don't TILT
Glimpse's Avatar
This has been discussed...
http://forums.clubrsx.com/showthread...threadid=74722
Check edo's post; the mounting is different. I trust he is correct.
2003 NBP A-Spec Type S
Injen: CAI Hayame: Exhaust Toda: Race Header, Valve Springs, Headgasket, N2 Cams, Front Swaybar Skunk2: SS Valves, Ti Retainers Energy Suspension: MM Bushings Hondata: IMG, K-Pro Unorthodox Racing: Ultra SS Pulleys JDM: ITR IM, ITR FD CRSX: Shift Bushings Exedy: Organic Clutch, Flywheel Quaife: LSD StopTech: BBK PowerSlot: Rear Rotors Techna Fit: SS Lines AXXIS: Metal Master Pads Motul: RBF 600 Xenon Depot: 5000k HID Spoon: Drain Bolts Grillcraft: Lower Grill
I love Pink Rsx
Glimpse is offline   Reply With Quote
Old 05-22-2003, 11:00 PM   #11
Spy RSX-S
Get Wet!
Spy RSX-S's Avatar
either way,
theres always a way to get it to fit. i never thought i would see the day a 96' civic HB would have our engines, or even more bizzare a JDM spec DC5-R K20A.
freaky but its true!
spy
Family Rides
Old 05-22-2003, 11:10 PM   #12
cUl8rV8
Senior Member
cUl8rV8's Avatar
Originally posted by Spy RSX-S
either way,
spy
There's not much you can do to modify magnesium. If you drill it it will explode! Much easier to shoehorn a k20 into an eg hatch than what you are proposing. The only way it might work is if there is an adapter.
Old 05-23-2003, 05:49 PM   #13
BlackNite
SS Specialist to the 6th
What about putting a type-R engine and type-S tranny in a base auto? I guess it would be cheaper to trade in my car and get a S hum.. lol
My Home Page
BlackNite is offline   Reply With Quote
Reply
Bookmarks
interchangable, series, trannies
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
