A/C didn't blow cold air when idle - Club RSX Message Board
Go Back   Club RSX Message Board > GENERAL RSX > Problems & Solutions RSX
Notices
Reply
Thread Tools
Old 05-07-2012, 01:40 AM   #1
cty0204
New Member
cty0204's Avatar
cty0204 is a jewel in the rough of c-rsx cty0204 is a jewel in the rough of c-rsx cty0204 is a jewel in the rough of c-rsx cty0204 is a jewel in the rough of c-rsx cty0204 is a jewel in the rough of c-rsx cty0204 is a jewel in the rough of c-rsx cty0204 is a jewel in the rough of c-rsx cty0204 is a jewel in the rough of c-rsx
Smile A/C didn't blow cold air when idle
Hello guys!
My car didn't blow cold air while it's idle but I know it seems a common thing for RSXs with low rpm.
So what i did was just rev up some rpm and the HVAC started blowing cold.
But now it got worse situation. Now the A/C not blows cold air anymore when it's idle with my revving up rpm. It only blows cold while running.
I check the temperature gauge and the fans for coolant, seems they're all good.
Anyone helps?
Thanks!!
cty0204 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 05-07-2012, 07:51 AM   #2
nvmaddog
Member
nvmaddog is a jewel in the rough of c-rsx nvmaddog is a jewel in the rough of c-rsx nvmaddog is a jewel in the rough of c-rsx nvmaddog is a jewel in the rough of c-rsx nvmaddog is a jewel in the rough of c-rsx nvmaddog is a jewel in the rough of c-rsx nvmaddog is a jewel in the rough of c-rsx nvmaddog is a jewel in the rough of c-rsx
Check to see if the condenser fan is blowing (the fan in front of the compressor)
Then if that is working the clutch on the AC may be the culprit.
nvmaddog is offline   Reply With Quote
Old 05-07-2012, 09:56 AM   #3
Fito1211
You Member
Fito1211 is a jewel in the rough of c-rsx Fito1211 is a jewel in the rough of c-rsx Fito1211 is a jewel in the rough of c-rsx Fito1211 is a jewel in the rough of c-rsx Fito1211 is a jewel in the rough of c-rsx Fito1211 is a jewel in the rough of c-rsx Fito1211 is a jewel in the rough of c-rsx Fito1211 is a jewel in the rough of c-rsx
make sure both fans come on when a/c is on and engine running. it might be possible that your a/c system might be low on refrigerant, probable cause of a small leak. recommend to take car to your local shop.
Fito1211 is offline   Reply With Quote
Old 05-07-2012, 12:24 PM   #4
cty0204
New Member
cty0204's Avatar
Thank you guys very much!!
I'll go figure out.
Old 05-08-2012, 08:36 PM   #5
Sweaty Palms
'05 NHBP K24 Type S
Sweaty Palms's Avatar
Sweaty Palms is a jewel in the rough of c-rsx Sweaty Palms is a jewel in the rough of c-rsx Sweaty Palms is a jewel in the rough of c-rsx Sweaty Palms is a jewel in the rough of c-rsx Sweaty Palms is a jewel in the rough of c-rsx Sweaty Palms is a jewel in the rough of c-rsx Sweaty Palms is a jewel in the rough of c-rsx Sweaty Palms is a jewel in the rough of c-rsx
My 98 civic did this. Turned out being the clutch on the A/C compressor.
Sweaty Palms is offline   Reply With Quote
Old 05-09-2012, 04:33 PM   #6
infraredrsx
Zero Tolerance 4 Retards
infraredrsx's Avatar
infraredrsx is on a distinguished road
Check your coolant level.
There are 2 types of people behind the wheel, drivers and operators.
Operators are interested in geting from point A to point B.
Drivers are interested in what's between.
infraredrsx is offline   Reply With Quote
Old 05-16-2012, 01:38 PM   #7
mtxjohn
02 blue type-s
mtxjohn's Avatar
mtxjohn is an unknown quantity on c-rsx
I'm calling FAN problem. If the car cools while running (driving) then ambiant air pushing past the heat exchanger replaced the function of the AC fan. Get on that buddy ASAP.
2002 RSX-S (196,000 miles ) WD-40 stands for Water Displacement. It is NOT a proper lubricant. In fact, if you try to use it as such it will wash away (dissolve) any actual lubricant that was there to start with.
I'm the top RSX on Fuelly!!!
http://www.fuelly.com/driver/mtxjohn/rsx
An armed man in a citizen, an unarmed man is a peasant.
mtxjohn is offline   Reply With Quote
Old 05-16-2012, 03:40 PM   #8
nvmaddog
Member
If the clutch on the compressor is going out it will behave exactly the same way he described also.
Old 06-04-2012, 01:30 PM   #9
infraredrsx
It's also possible that the water pump is going out.
Old 06-04-2012, 04:06 PM   #10
Stitch
Soup to nuts
Stitch is on a distinguished road
I'm gonna say low coolant. Probably have air in the system, and by reving it you circulate the air/coolant.
Street and Remote tuning available - PM me
I don't understand the fascination with dragging your front lips on the floor and having stupid camber. Hellaflush = Hellaretarded
04' RSX Type S - All Motor - Fully Built
These kids don't even know about 5th and 6th gear pulls.
Stitch is offline   Reply With Quote
Old 06-07-2012, 03:06 PM   #11
cty0204
New Member
cty0204's Avatar
Thank all you guys reply.
I checked the level of coolant, its still just at max and I think I reflushed it 30k miles ago.
Both fan work, but not sure works like them suppose.
Basically revving up rpm can make it blow cold, but sometimes depends on the temperature outside, sometimes A/C shuts off while I'm cruising (about 2500rpm, pretty hot outside).
Haven't check the compressor clutch yet. I'll go check further.
Thanks again!!
Old 06-07-2012, 04:08 PM   #12
311unity13b
New Member
311unity13b is a jewel in the rough of c-rsx 311unity13b is a jewel in the rough of c-rsx 311unity13b is a jewel in the rough of c-rsx 311unity13b is a jewel in the rough of c-rsx 311unity13b is a jewel in the rough of c-rsx 311unity13b is a jewel in the rough of c-rsx 311unity13b is a jewel in the rough of c-rsx 311unity13b is a jewel in the rough of c-rsx
a/c system overcharge can cause all sorts of problems.
311unity13b is offline   Reply With Quote
Old 06-09-2012, 10:22 PM   #13
Frunkis
Casual Scum
Frunkis's Avatar
Frunkis is an unknown quantity on c-rsx
Hook a gauge up to your low-side port and make sure your freon is under/over charged.
2005 Silverstone S2000
2003 Berlina Black S2000 RIP
2002 DSM Base: 200hp/151
Frunkis is offline   Reply With Quote
Old 06-10-2012, 09:48 AM   #14
nvmaddog
Member
Thanks again!!
Get it up on stands if you can and have a look at the side of the compressor and see how the clutch is behaving. Sometimes it will stay on for a while, then when it gets really hot it will shut off. I'm willing to bet you have power going to it constantly, just the clutch is failing when it gets hot.
Old 06-10-2012, 10:42 AM   #15
Stitch
Soup to nuts
Thanks again!!
don't check the over fill, pull off the actual radiator cap, start the car, and blip the throttle a couple of times, see if air comes up.
Old 06-10-2012, 10:32 PM   #16
gag23118
Member
gag23118's Avatar
gag23118 is an unknown quantity on c-rsx
had same problem change out condenser and ac compressor turns out it was the compressor thanks
gag23118 is offline   Reply With Quote
Old 06-11-2012, 05:36 AM   #17
Bryanrsx
Senior Member
Bryanrsx is a jewel in the rough of c-rsx Bryanrsx is a jewel in the rough of c-rsx Bryanrsx is a jewel in the rough of c-rsx Bryanrsx is a jewel in the rough of c-rsx Bryanrsx is a jewel in the rough of c-rsx Bryanrsx is a jewel in the rough of c-rsx Bryanrsx is a jewel in the rough of c-rsx Bryanrsx is a jewel in the rough of c-rsx
1st, the engine cooling(coolant) system has nothing to do with A/C or refrigeration. The engine has a radiator and the A/C has his own radiator(called Condenser) only refrigerant flows inside the condenser with his seperate fan to bring down high pressure from compressor.
Most commun situation is that you are low on refrigerant(R-134a) or the fan from condenser is not coming on causing a high pressure cut out to compressor, wich is normal to protect from blowing up. If you had added refrigerant it may be overcharged.
Start by conecting gauges and check if you low on freon.
Any question let me know. If you take to a shop post what they say, just to see if it makes sense and they don't over estimate.
Bryanrsx is offline   Reply With Quote
Old 06-11-2012, 04:14 PM   #18
Stitch
Soup to nuts
This post is full of so much wrong. While they have separate radiators and what not, the condenser sits right in front of/behind the radiator. If you're coolant is low at idle there probably won't be any in the radiator causing it to heat soak. Metal, being the wonderful conductor of heat that it is, will heat soak everything else around it. Empty your coolant and see if your A/C works at idle.
Old 06-11-2012, 06:14 PM   #19
Bryanrsx
Senior Member
Lololololol. This is the most funny thing I've ever heard. It's like trying to "fix a power steering leak but taking apart an A/C line because A/C line is the problem". Lololol.
Sorry man it was hilarious. Let me explain your confusion, if you take a look yourself the condenser is 1 INCH away from the radiator and the support is diferent from radiator with rubber bushings betwen frame and support. The radiator has his own support away from condenser and another thing the condenser sits in front of the radiator, by this meaning there's NO metal to metal heat transfer and because it sits in front of radiator there is no heat soak, the condenser recieve all the fresh air before it travel to radiator.
If in case there's air in the cooling system of the engine, you might be looking at a possible bad head gasket.
I hope you understand this elementary lesson.
I'm a refrigeration technician and this is the first time I've heard this type of solution of yours.
Please people, if you don't have any idea what's going on, please don't post and have this guy pay twice. Like I said if you have any question lmk. Thank You.
Old 06-12-2012, 04:47 AM   #20
Biscuit75
New Member
Biscuit75 is a jewel in the rough of c-rsx Biscuit75 is a jewel in the rough of c-rsx Biscuit75 is a jewel in the rough of c-rsx Biscuit75 is a jewel in the rough of c-rsx Biscuit75 is a jewel in the rough of c-rsx Biscuit75 is a jewel in the rough of c-rsx Biscuit75 is a jewel in the rough of c-rsx Biscuit75 is a jewel in the rough of c-rsx
Knowledge has been dropped!
I agree 100%!
Biscuit75 is offline   Reply With Quote
Old 06-12-2012, 03:40 PM   #21
Stitch
Soup to nuts
Oh ok... so metal has to touch for it to conduct heat? too bad heat can transfer through thin air. Not only from an inch away but sometimes even a foot. That's like saying a short ram intake won't heat soak because there's a rubber coupling separating it from the throttle body. But then again, what do I know.
I'm just saying. I have had this issue where the AC won't blow cold air at idle. Opened the radiator cap, blipped the throttle and gobs of air came up... soon as i poured more coolant in, the car was frigid.
You made your post based on some crackerjax box knowledge. Mine was made from previous experiences.
While you may be a refrigeration "technician", you obviously lack "elementary" knowledge of thermodynamics and laws of cooling
IF rad A is 250 degrees and it is 1 inch from rad B at 66 degrees. The two temperatures will get closer and closer with time until they equalize. Try this for example, take a cup of ice and a hot cup of water and place them next to each other.. NOT TOUCHING OF COURSE, GOD FORBIED. Put a thermometer in each and tell me what happens.
EDIT:
Also in regards to your comment about the condenser getting all the cold air first because it sits in front of the radiator... Are we not talking about a vehicle standing still at idle?? WHAT fresh air is it getting first?
Old 06-13-2012, 01:36 AM   #22
Bryanrsx
Senior Member
Impressive! How you confuse yourself. First you say empty your coolant and see if it works on idle, and of course re-fill it, then you say open your radiator cap, blip the throttle and gobs of air will come up. Hugh!
Let's say we do your first choice, empty the coolant and re-fill it. In the process before you put your radiator cap on, the engine needs to come at its normal temp. range allowing the thermostat to fully open so no air is trapped in the cooling system causing high pressure and temp, if not it won't last long for a new head gasket replacement.
And for your second, it's self explanatory if you read the first one. There might be an engine overheating problem. why blip the throttle if your thermostat is open? Unless there's compression from cylinder causing to react, then head gasket is not your friend.
I'm going through what it say on the original post from cty0204:
At idle A/C won't cool until I rev up,
then situation got worst, now it only cool when driving. Further post down: I checked coolant level and was reflushed 30k miles ago.
Ok now, If is the coolant he would of have this problem a wile ago, and I don't believe he put 30k miles in less than a year, so he probably had it done before last summer when A/C problem could of happen initiative.
But yes if your engine is overheating, could cause problem at idle.
Because of the info that was provided by cty0204 I came with that simple conclusion on my first post.
No hard feelings, I'm just trying to have a solution for the guy.
This is all based on experience of mine in this industry.
Question for you.
Is this your only solution just coolant?
How many other possible causes could be?
This is all about getting this guy A/C going, if you know about this, give this guy other possible causes for him to look for, not just coolant.
Oh! Congratulation on you. A+ on laws of thermodynamic
cty0204 please post if repair was made. Thank you.
Old 06-13-2012, 12:57 PM   #23
Stitch
Soup to nuts
Question for you.
No, i told YOU to empty your radiator fluid, then see if you got cold air from your a/c (to simulate not having enough coolant)
The fact of the matter is that engine coolant temps affect EVERYTHING. Your AC doesn't produce cold air, it simply condenses it and removes moisture... the by product is the ABILITY to produce COLDER air. But if your car is blowing hot air out at idle with the AC off, Then how is it supposed to blow out cold air WITH the AC
Old 06-13-2012, 11:14 PM   #24
Bryanrsx
Senior Member
Do you know anything about HVAC?
Because u don't make any sense to solve this.
If you know that much, just name all possible causes to solve this A/C problem. Ok? Not the solutions that I already posted initially.
The same question ones again. If you don't, then lmk so I can give you a boost.
This is just to solve this guy issue, but it has gotten more of a theory argument with you.
Old 06-16-2012, 12:39 AM   #25
Anjuna
Member
Anjuna is a jewel in the rough of c-rsx Anjuna is a jewel in the rough of c-rsx Anjuna is a jewel in the rough of c-rsx Anjuna is a jewel in the rough of c-rsx Anjuna is a jewel in the rough of c-rsx Anjuna is a jewel in the rough of c-rsx Anjuna is a jewel in the rough of c-rsx Anjuna is a jewel in the rough of c-rsx
You are all retarded.
1. Radiator temperature WILL affect condenser temperature.
2. Fans working at idle, proper refrigerant level, coolant levels, engine temp, etc, my k20a2 based cooling system NEVER cooled properly at idle in 100 degree Houston weather.
3. K24 swap improved lower rpm cooling (tsx engine has larger crank pulley
Maybe try a k24 pulley and belt? Seems like you could find one easy. Tons of k24 swap people swapping because the pulley "robs" so much "power"
Anjuna is offline   Reply With Quote
Reply
Bookmarks
a or c , air , blow , cold , idle
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
