Car won't start, clicking noise and weak battery - Club RSX Message Board
Go Back   Club RSX Message Board > GENERAL > Problems & Solutions
Notices
Reply
Thread Tools
Old 05-17-2012, 04:35 PM   #1
PackerManDan35
Master Member
PackerManDan35's Avatar
PackerManDan35 is an unknown quantity on c-rsx
2003 Acura RSX Type-S. Battery is 2 years old.
I drove to work this morning just fine, car started right up and everything was great. 5 hours later I go to start my car and it doesn't even attempt to turn over, the dash lights come on but the radio won't turn on, the horn sounds very weak and I get this very rapid clicking noise coming from the glove box area.
My friend jumped me and it started right up. I let the car idle for about 20 minutes then shut it off. Came back to the car about 30 minutes later, tried starting it and it wouldn't even attempt to turn over, get the same rapid clicking noise from the glovebox.
Is this the battery? Starter? Alternator? Starter solenoid?
If I get it jumped before I leave for work will the car make it back home if I live 25 miles away?
2007 Suzuki GSX-R600 - Fender Eliminator
-- Motorcycle Crew #35 --
PackerManDan35 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 05-17-2012, 04:49 PM   #2
XG624
OG Base Crew
XG624's Avatar
XG624 is an unknown quantity on c-rsx
Sounds like the battery to me. I wouldn't risk driving 25 miles on it.
03 DSM Base Auto R.I.P.
07 Magnetic Black Pearl 350z Touring
10 Audi A5 3.2L Prestige
XG624 is offline   Reply With Quote
Old 05-17-2012, 05:03 PM   #3
RHCP0801
Member
RHCP0801's Avatar
RHCP0801 is an unknown quantity on c-rsx
100% battery, change it. Yes you will make it home but if you shut it off and try to restart it, it wont start
RHCP0801 is offline   Reply With Quote
Old 05-17-2012, 05:10 PM   #4
PackerManDan35
Master Member
Thank you both for the responses. Quick question though, if it truly is the battery then why wouldn't you risk driving home on it? I was under the impression that once I get jumped via jumper cables and the car is running...it will continue to run until I shut it off, so why would you not risk driving home if it's just the battery?
My friend said if it is a bad alternator I should not drive home because then the car is just running off of battery power and could shut down but if it's just the battery then it's fine.
Old 05-17-2012, 05:14 PM   #5
RHCP0801
Member
RHCP0801's Avatar
your friend is correct and so are you, ignore XG624. You will make it home fine
Old 05-17-2012, 05:17 PM   #6
PackerManDan35
Master Member
Thank you. Glad to know it's just the battery. Much less of a headache than if it was a bad starter, alternator, etc....
Cute dog by the way.
Old 05-17-2012, 05:49 PM   #7
XG624
OG Base Crew
XG624's Avatar
Will you be fine to drive it that distance on a jump? Most likely. Would I do it? No, that is why I said I would not take the chance, not that everyone should follow suit.
OP you're welcome for the feedback, best of luck to you and yes getting a new battery is definitely the best case scenario here. I went through the same symptoms 3 years ago and solved it by simply replacing the battery.
Old 05-17-2012, 06:08 PM   #8
lilbabykenny
Senior Member
lilbabykenny's Avatar
lilbabykenny is a jewel in the rough of c-rsx lilbabykenny is a jewel in the rough of c-rsx lilbabykenny is a jewel in the rough of c-rsx lilbabykenny is a jewel in the rough of c-rsx lilbabykenny is a jewel in the rough of c-rsx lilbabykenny is a jewel in the rough of c-rsx lilbabykenny is a jewel in the rough of c-rsx lilbabykenny is a jewel in the rough of c-rsx lilbabykenny is a jewel in the rough of c-rsx
Bro just get a battery... This thread seemed kind of useless as it seemed you already have an idea of what is wrong. Replacing the battery would be the start to diagnosing the problem regardless.
BB CREW It's not about who lives the longest, it's about who dies the biggest
xbox 360 gt: LiL Baby Kenny
Instagram LiLBabyKenny
PWP Type S CURRENT BUILD
lilbabykenny is offline   Reply With Quote
Old 05-17-2012, 08:45 PM   #9
PackerManDan35
Master Member
Here is a question for you. I got my friend to jump my car with jumper cables and I drove home (30 minute drive) with no problems at all. When I got home I parked the car and locked it. Usually when I hit my lock button twice the car horn beeps and the brake lights flash. This time there was no beep at all, but the lights still flashed. Doesn't the lack of car horn mean my battery is dead?
If that is true then isn't there a different issue at hand here other than my battery? If my battery is bad then wouldn't it be charged by the alternator on my 30 minute drive home and it should have enough charge to beep my horn when I lock my car? That is why I'm thinking maybe there is another issue at hand here. I can't get a battery until Saturday morning so that is why I'm asking questions so I can get as much info as I can first.
Old 05-17-2012, 08:50 PM   #10
futat2
Member
futat2's Avatar
futat2 is a jewel in the rough of c-rsx futat2 is a jewel in the rough of c-rsx futat2 is a jewel in the rough of c-rsx futat2 is a jewel in the rough of c-rsx futat2 is a jewel in the rough of c-rsx futat2 is a jewel in the rough of c-rsx futat2 is a jewel in the rough of c-rsx futat2 is a jewel in the rough of c-rsx
if your battery has a dead cell then no it wont keep a charge or take one. just get the battery and be done with it.
futat2 is offline   Reply With Quote
Old 05-17-2012, 09:03 PM   #11
imbest123
Bańned
imbest123's Avatar
imbest123 is an unknown quantity on c-rsx
this is the most moronic thread in the world. first off, you know the battery is bad. secondly, any auto parts store can test your battery if youre that unsure about it.
if your car is jumped then your car will still run correctly, itll just be running strictly off the alternator. this can damage the alternator, depending on the condition of it.
Wheel gap can be compared to a vagina. The more fingers you can stick in the worse off you are
Don't PM me. I don't give a fuck about who you are and no, I don't have nudes
imbest123 is offline   Reply With Quote
Old 05-17-2012, 09:48 PM   #12
STREET ETHNICS
Sleepers Crew!
STREET ETHNICS's Avatar
STREET ETHNICS is an unknown quantity on c-rsx
Check your terminal ends where it meets the cables and disconnect them from the posts. Use a terminal end cleaning tool which is a wire brush, clean the posts and the inside of the terminal ends That contact the posts. As far as charging the battery goes, if it has a bad cell and the battery is internally damaged it won't take a charge. Driving on just the alernator "as prior stated" is a bad idea. The alternators job is to replenish the battery as the vehicle uses juice for all accessories. Your alternator is obviously good if you ran the car without the battery's help. Don't drive the car until the battery is replaced or the possible terminal end problem is identified. Do the cheapest things first, which would be to inspect the terminal ends and cables. Then clean em up. lmk what happens.
STREET ETHNICS is offline   Reply With Quote
Reply
Bookmarks
battery , car , clicking , noise , start , weak
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
