How much to rebuild stock 02 Rsx type s motor? - Club RSX Message Board
Go Back   Club RSX Message Board > ADVANCED PERFORMANCE > Engine Building & Design
Notices
Reply
Thread Tools
Old 06-12-2012, 05:32 PM   #1
JM790
New Member
JM790 is a jewel in the rough of c-rsx JM790 is a jewel in the rough of c-rsx JM790 is a jewel in the rough of c-rsx JM790 is a jewel in the rough of c-rsx JM790 is a jewel in the rough of c-rsx JM790 is a jewel in the rough of c-rsx JM790 is a jewel in the rough of c-rsx JM790 is a jewel in the rough of c-rsx
How much not including labor is it to rebuild the motor? What kind of parts are needed?
JM790 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 06-12-2012, 06:02 PM   #2
mathyou
FS: Vtec Fluid
mathyou's Avatar
mathyou is a jewel in the rough of c-rsx mathyou is a jewel in the rough of c-rsx mathyou is a jewel in the rough of c-rsx mathyou is a jewel in the rough of c-rsx mathyou is a jewel in the rough of c-rsx mathyou is a jewel in the rough of c-rsx mathyou is a jewel in the rough of c-rsx mathyou is a jewel in the rough of c-rsx
You'll probably need some duct tape, WD40, maybe some glue.
Nah man, it depends on what exactly is needing to be rebuilt bro. Knowing what's broken will tell you what parts you need to replace and how much labor will be involved.
mathyou is offline   Reply With Quote
Old 06-13-2012, 08:36 AM   #3
JM790
New Member
nothings broken, I just have 179k on the motor and i kinda beat on my car and i dont want it to blow
Old 06-14-2012, 04:41 AM   #4
aldrine
Senior Member
aldrine's Avatar
aldrine is a jewel in the rough of c-rsx aldrine is a jewel in the rough of c-rsx aldrine is a jewel in the rough of c-rsx aldrine is a jewel in the rough of c-rsx aldrine is a jewel in the rough of c-rsx aldrine is a jewel in the rough of c-rsx aldrine is a jewel in the rough of c-rsx aldrine is a jewel in the rough of c-rsx
if its not borken..dont fix it...
once it blows... get a k24...
rebuilding a 179k motor.. you might as well get a new engine..
aldrine is offline   Reply With Quote
Old 06-14-2012, 06:01 AM   #5
Tacticsv
United
Tacticsv's Avatar
Tacticsv is a jewel in the rough of c-rsx Tacticsv is a jewel in the rough of c-rsx Tacticsv is a jewel in the rough of c-rsx Tacticsv is a jewel in the rough of c-rsx Tacticsv is a jewel in the rough of c-rsx Tacticsv is a jewel in the rough of c-rsx Tacticsv is a jewel in the rough of c-rsx Tacticsv is a jewel in the rough of c-rsx
Care to elaborate on your reasoning behind that?
06' MM-S
Tacticsv is offline   Reply With Quote
Old 06-14-2012, 06:07 AM   #6
aldrine
Senior Member
aldrine's Avatar
the money and labour.. itll be easier to drop an engine... unless the rebuild is very minor... but once you open it.. its less of a headache to drop a motor...
my 2 cents cause i dont have all the tools and etc..
Old 06-14-2012, 09:33 PM   #7
Rattlehead7291
Member
Rattlehead7291 is a jewel in the rough of c-rsx Rattlehead7291 is a jewel in the rough of c-rsx Rattlehead7291 is a jewel in the rough of c-rsx Rattlehead7291 is a jewel in the rough of c-rsx Rattlehead7291 is a jewel in the rough of c-rsx Rattlehead7291 is a jewel in the rough of c-rsx Rattlehead7291 is a jewel in the rough of c-rsx Rattlehead7291 is a jewel in the rough of c-rsx
lol im at like 140k and i beat on it.... I've always assumed I'll just get a different engine when it "blows"... seems like a pretty vague term though...
I wouldnt want a k24...yeah it has more torque or whatever but so does a ford explorer..i like a higher rev limit
Can you buy a brand new k20a2?... it sketches me out buying a used engine online
Rattlehead7291 is offline   Reply With Quote
Old 06-14-2012, 10:10 PM   #8
DenDC5
Senior Member
DenDC5's Avatar
DenDC5 is a jewel in the rough of c-rsx DenDC5 is a jewel in the rough of c-rsx DenDC5 is a jewel in the rough of c-rsx DenDC5 is a jewel in the rough of c-rsx DenDC5 is a jewel in the rough of c-rsx DenDC5 is a jewel in the rough of c-rsx DenDC5 is a jewel in the rough of c-rsx DenDC5 is a jewel in the rough of c-rsx
In my opinion not worth it at all. Are you taking the motor out and back in? Or are you going to pay someone to do all the labor? If the motor is still running, start saving up and looking for a decent k20a2/k24 with low mileage, and a transmission along with it.
DenDC5 is offline   Reply With Quote
Old 06-15-2012, 04:54 AM   #9
aldrine
Senior Member
aldrine's Avatar
buying a used or new k20a2/k20 ... is almost 1.5x than a new or used k24... and i know what you mean by revving higher...you dont need to with the k24 and even if u do.. you can still take it up high as 7800...or swap the oil pump and rev as high as ur k20a2.. just saying...
if ur ballin then yea grab a k20a
Old 06-18-2012, 12:06 AM   #10
Rattlehead7291
Member
lmao im not ballin..what about the k20z1 or k20z3 or whatever?...i havent really heard of that being done...but why?
Old 06-18-2012, 06:25 AM   #11
aldrine
Senior Member
aldrine's Avatar
alot of people do that swap..they just dont annonce it as much cause its basically the same engine as k20a2...
if your engine is fine now... and you've been beating on it... dont change a thing just keep up with your maintenance...unless you can do your own labour then yea its worth rebuilding it... otherwise in the future just drop a new engine a little less of a headache...
Old 06-20-2012, 08:08 PM   #12
Rattlehead7291
Member
yeah but i assume you can get them new or easier to find with low miles etc etc
Old 06-21-2012, 03:42 PM   #13
jgnlz87
YOSOLO Tuned.
jgnlz87 is a jewel in the rough of c-rsx jgnlz87 is a jewel in the rough of c-rsx jgnlz87 is a jewel in the rough of c-rsx jgnlz87 is a jewel in the rough of c-rsx jgnlz87 is a jewel in the rough of c-rsx jgnlz87 is a jewel in the rough of c-rsx jgnlz87 is a jewel in the rough of c-rsx jgnlz87 is a jewel in the rough of c-rsx
Its cheaper, easier and less time consuming to buy a motor and swap it than it is to build a motor but it all depends on what you're expecting from your power plant. I myself plan to run my k20a2 to the ground untill honda comes out with something more powerful and efficient. Hopefully by then K24's or > will be the standard. The 2012 honda Civic Si K24's looks promissing with its 6 speed LSD tranny
jgnlz87 is offline   Reply With Quote
Reply
Bookmarks
motor , rebuild , rsx , stock , type
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
