Club RSX Message Board
Club RSX Message Board (https://forums.clubrsx.com/index.php)
-   JDM Only RSX (https://forums.clubrsx.com/forumdisplay.php?f=181)
-   -   JDM DC5 Part Number Thread (https://forums.clubrsx.com/showthread.php?t=698251)
D Fabulous 01-28-2010 06:09 PM
So I need some JDM DC5 Part #'s and I'm having a hell of a time searching for them so hopefully this will make it easier for someone else. this is what i have so far. As i find more i will update my list feel free to post any if you have them! also if anyone knows they are incorrect please also let me know!
Flywheel - 22100-PRC-003
Intake Camshaft - 14110-PRC-000
Exhaust Camshaft - 14120-PRC-000
Intake Manifold - 17100-PRC-000
Pistons - 13010-PRC-010
Piston Ring Set - 13011-PRA-EO2
Red H ABP Front - 7S710-S6M-Z01ZA
Left Front LCA - 51360-S6M-Z01
Right Front LCA - 51350-S6M-Z01
Titanium 6spd Shift Knob - 90310-st7-z00
Rear engine mount: 50810-S7C-003
Auxiliary Belt: 38920-PRC-014
Spark plug: 98079571BV
Interior clips black: 91560-S84-A11
Interior clips white: 91560-S84-A01
Oil filter crush washer: 94109-14000
Inner fender clips: 91501-S04-003
Transmission fluid washer 20mm: 9410920000
Transmission fluid washer 14mm: 9410914000
HID ballast: 33119-S6M-003
Trunk cargo net (set): 08L96-S6M-000
Oil filter: 15400-PLM-A02
HondaBond HT: 08718-0004
Foglight switch (kit): 08V31S5T61035
Engine sealer (hondabond): 087180009
Oil filter wrench: 07AAA-PLCA100
Camshaft alignment tool: 07AAB-RWCA120
Valve cover gasket: 12341-RTA-000
Ignition coil: 30520-RRA-007
Tie rod end: 53541-S7A-003
Cabin filter (pair): 80292-S5D-A01
Timing chain tensioner: 14510-PRB-A01
Exhaust manifold gasket: 18115-PRB-A01
IACV: 16022-PRB-A02
IAT sensor: 37880-PLC-004
MAP sensor: 37830-PGK-A01
Chain case gasket (kit): 06114-PRB-A01
Spark plug tube seal: 12342-PCX-004
1DIN radio pocket: 77280-S6M-A01ZA
Washer jet (cw white): O/S 76810-S6M-J01ZC
Washer jet (cw white): N/S 76815-S6M-J01ZC
Washer jet (cw white): Rear 76850-S6M-J11ZJ
K20A Crank pulley: 13810-PRC-003
Trunk side hanger: 84618-S6M-A01ZA
Clear sidelights (same as EP3 pre-facelift): 34301-S5H-T02
Bolt, flange 10X30: 95701-10030-08 (exhaust manifold bolts for example)
OEM LSD - 41200-PNT-003
OEM 6sp Gearknob -54102-S6M-R00X
OEM FD2 Headgasket - 12251-RRC-004
OEM FD2 Piston set inc. rings - 13010-RRC-000
OEM wind deflectors - 08R04-S6M-001
OEM pedal set - 17010-SL0-Z00X
OEM front lip spoiler - 71110-S6M-Z00ZC
Fuel filter (fuel pump department) - 17516-S5A-930
Fuel filter (main filter) - 16010-S5A-932
Aircon condensor - 80110-S6M-A01
O-Ring (1/2") (needed for aircon condensor) - 80872-ST7-000
O-Ring (8mm) (needed for aircon condensor) - 80873-ST7-000
Water Pump - 19200-PRB-A01
DC5R front end link, R: 51320-S5A-003
DC5R front end link, L: 51321-S5A-003
02-04 51601-S6M-Z050-M1 - Front Suspension part numbers
02-04 52620-S6M-Z030-M1 - Rear Suspension part numbers
02-04 71104-S6M-Z01 - Brake Ducts outer only
02-04 75701-S6M-Z010-M1 - Rear RED "H" emblem
05-06 Hid left head light- 33151-S6M-J51
05-06 Hid right head light- 33101-S6M-J51
05-06 Front RED "H" emblem - 75710-S6M-Z11
05-06 Rear RED "H" emblem - 75701-S6M-Z01
disk, aluminium wheel (asahi)
(17x7jj) *nh95mz*
blade silver metallic-z - 42700-S6M-Z11ZA
____________________________________________
D
DC5_KR 01-28-2010 10:48 PM
D
I a couple of numbers at Home ill update your list tomorrow after work........:thumbsup:
wsr1031 01-31-2010 01:00 AM
'05-'06 hid left head light- 33151-S6M-J51
'05-'06 hid right head light- 33101-S6M-J51
acepty 01-31-2010 02:41 PM
Originally Posted by wsr1031 (Post 31971633)
left head light (hid version)- 33151-S6M-J51
right head light (hid version)- 33101-S6M-J51
for what year model?
RocknRsx 01-31-2010 02:49 PM
I think a 05 06 head light because he has an 05 06.. I think
killertofupanda 01-31-2010 09:01 PM
[Year] [Make] [Model [Trim] [Part description] [Part Number]
wsr1031 01-31-2010 09:38 PM
sorry, yeah those are for '05-'06
D Fabulous 02-01-2010 06:11 AM
Yeah i will update the first post with those too. if possible.
ZeroA 02-21-2010 01:47 PM
I have been looking for the 05+ type R suspension... no luck. Was able to find the 02-04's though (unless they are all the same, which I doubt):
51601-S6M-Z050-M1 - front part numbers
52620-S6M-Z030-M1 - rear part numbers
got it from:
http://forums.clubrsx.com/showthread.php?p=27885547
azngotmilk 02-26-2010 12:30 PM
Anyone know the part number for the jdm 05+ front red h emblem??
wsr1031 02-26-2010 03:21 PM
i dont know it .. but i dont know if this helps, u can buy it here:
http://hmotorsonline.com/shop/whatsn...php?prodID=473
azngotmilk 02-26-2010 03:28 PM
im just trying to find the part number for the 05+ one
D Fabulous 02-26-2010 04:00 PM
well when and if you find it. let me know :)
Brock 02-27-2010 11:00 AM
Piston Rings - 13011-PRA-EO2
Front Lower Control Arms - 51360-S6M-Z01
D
Lower Control Arm you have is for the Left side.
Right side is 51350-S6M-Z01.
caeavesRSX-S 03-04-2010 10:19 AM
02-04 Brake Ducts Outer Only 71104-s6m-z01
caeavesRSX-S 03-04-2010 10:21 AM
90310-st7-z00 titanium 6 spd shift knob
DC5ITR329 03-04-2010 05:36 PM
I have forsale if anyone is interested.:D
jsinher3 03-05-2010 10:02 AM
hey would any one know were i can get a rsx type r pulley and has the part number?
Brock 03-05-2010 11:00 AM
Part number is 13810-PRC-003. Same as 2005-2006 Type-S. Get one from any
Acura dealer such as bernardiparts.com.
jsinher3 03-05-2010 11:02 AM
thanks
DC5_KR 03-05-2010 10:46 PM
I keep forgeting about this thread will post 2morrow.
Scourge 05-26-2010 06:43 AM
I'm also curious about the part number for the emblems. Front and back. Red and "normal" emblems.
jgm06s 05-26-2010 12:28 PM
where can i buy 05-06 jdm headlights?
24639RSX 06-03-2010 04:27 AM
lets keep it going, good info!
integraxtr 06-07-2010 05:56 PM
05-06 Front RED "H" emblem is // 75710-S6M-Z11
05-06 Rear RED "H" emblem is// 75701-S6M-Z01
