A possible solution to the AC on/off - Club RSX Message Board
Go Back   Club RSX Message Board > GENERAL RSX > General RSX Discussion
Reply
Thread Tools
Old 02-07-2002, 05:18 PM   #1
n8236
Future C.F.O.
n8236 is an unknown quantity on c-rsx
I've read complains about the AC turning on and not turning at the correct times or when we want it. Here's a fix to that problem. You may have full control over your AC.
BUT this article is directed to Civics, so hopefully since our cars (RSXs) were built upon that flatform, maybe it might work on our cars.
http://madstatic.com/2k1civic/diy/acdisable/
Someone give it a shot and see if it helps.
n8236 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 02-07-2002, 08:23 PM   #2
calgary1
Senior Member
calgary1 is an unknown quantity on c-rsx
somebody try it, quick!!! I hope this doesn't screw up the whole climate control system.
2002 Artic Blue RSX Type S
calgary1 is offline   Reply With Quote
Old 02-07-2002, 09:38 PM   #3
TypeSzH
BUm
TypeSzH's Avatar
TypeSzH is an unknown quantity on c-rsx
I just tried it. When u turn it on wait for the recirculation to blink than the ac to blink. Worked like a charm. Don't know if it affects the Auto Climate control. Haven't tried to reverse it yet.
TypeSzH is offline   Reply With Quote
Old 02-07-2002, 09:49 PM   #4
TrustRSX
Master Member
TrustRSX's Avatar
TrustRSX is an unknown quantity on c-rsx
I tried this a month ago and it didin't work. The recirculation light did blink. Do you have to hold it longer after that?
How did you get it to work?
What you will need: Two Fingers
Time Needed: 10 seconds.
Annoyed with how you can't turn off the A/C when you turn to defog? Here's the override (realize that A/C expediates the defog process).
These steps are taken from a discussion thread on 2k1civic.com
Turn Car Off
Turn Temperature Knob To Full Blue (All the way to the left - Counter-Clock Wise)
Turn Vent Knob To Off (All the way to the left - Counter-Clock Wise)
Hold Down Air Recirculation Button As Well As A/C Button
Keep Both Buttons Depressed and Start Car
Keep Both Buttons Depressed for 7 Seconds
*AC LIGHT SHOULD BLINK*
You will now have control of your A/C regardless of what setting you are in, to revert back, simply repeat the procedue.
TrustRSX is offline   Reply With Quote
Old 02-07-2002, 10:08 PM   #5
n8236
Future C.F.O.
Oppz, my bad. Didn't know it was posted up b4. Hrm, guess I missed it.
Old 02-07-2002, 11:14 PM   #6
AnDylishus
The Dylishus One
AnDylishus is an unknown quantity on c-rsx
so whats the advantage in doing this?
AnDylishus is offline   Reply With Quote
Old 02-08-2002, 02:26 AM   #7
TypeSzH
BUm
TypeSzH's Avatar
Make sure u hold on to the two buttons before u turn on the car. Hold it till after the AC button blinks. The recirculation button blinks first than the AC. Make sure ur not holding on the Defrosting button for the rear window.
Old 02-08-2002, 02:30 AM   #8
TypeSzH
BUm
TypeSzH's Avatar
Advantage is you can turn the AC off to defrost your windshield. Ac is faster, but i like just using plain old heat. It was gettin to me thank god for CLUBRSX for all these fixes. First the Bass fix now this. KEEP IT COMING
Old 02-08-2002, 10:59 AM   #9
taoz
Senior Member
taoz's Avatar
taoz is an unknown quantity on c-rsx
man, that AC thingy bothers me for years. I had a Escort before it has same dumb design. I gotta try that... So after A/C light blinks then it stops work until you change it back right? How about air recirculation button, does it stop working too?
Thanks
taoz is offline   Reply With Quote
Old 02-08-2002, 11:24 AM   #10
mig
Guest
Posts: n/a
Always having the AC on seems like a bad design. I know that AC can remove moisture from the air, but seems like - unless the air is reheated after moisture removal - the air hitting the windshield will be saturated anyhow, by way of the fact that the air was cooled to the point of condensation. (unless, I suppose, the coils in the evaporator are much much colder than the air leaving the AC.. which I guess may be the case. Though, you do not want the condensed water to freeze on the coils. Ice is a very good insulator)
I know from empirical evidence that having AC on helps occaisonally. But heating up the windshield sometimes works well too.
Anyone here know if cooled air is passed back through the heater when defogging, or does the cold and hot air mix near the vent?
Old 02-08-2002, 01:53 PM   #11
MOTOR
Senior Member
MOTOR is an unknown quantity on c-rsx
Yeah, check page 21-8 of your service manual. This is the self diagnosis function. Codes blink thru the rec light after the first two blinks. Function ends when you turn the ignition off.
Groovy.
MOTOR is offline   Reply With Quote
Old 02-08-2002, 02:43 PM   #12
Jerome81
Senior Member
Jerome81 is an unknown quantity on c-rsx
So does the auto climate control still work? Will the AC still come on when you place both the vent and the fan in the auto position?
Jerome81 is offline   Reply With Quote
Old 02-08-2002, 03:46 PM   #13
Leo95SE
The Ominous One
Leo95SE's Avatar
Leo95SE is an unknown quantity on c-rsx
normally for me the windows get foggy AFTER ive been driving in the rain...
id hate to shut off the car on the highway just to get my AC off..
ABP Type S
Go Getters:
Hondata #4
Hondata IMG
DIY ram air intake
DIY Ground Wires
Stay Putters:
JDM Type R Struts
X-Brace
JDM rear sway
Front pads: Axxis Ultimates on slotted rotors
Rear Pads: Carbotech Bobcat
Battery Relocation
Falken GBR FK451: 225/50x16
The Look:
OEM Body kit
Type R wing
Red Tails
JDM HID Lights
Play Time:
Custom IPod Mount
Custom IPod Wiring
Leo95SE is offline   Reply With Quote
Old 02-08-2002, 04:02 PM   #14
MikeT-S
Senior Member
MikeT-S's Avatar
MikeT-S is an unknown quantity on c-rsx
Turn Car Off
Hey Thanks! I wondered how I could disable the ac when the defog was on. You think they would give you the option, instead of having to go through that.
MikeT-S is offline   Reply With Quote
Old 02-08-2002, 09:45 PM   #15
GJC
I like Honda/Acura!
GJC is an unknown quantity on c-rsx
Yeah, I don't understand why they designed it that way either. On my wife's '01 CR-V, it automatically turns on the A/C when you turn it to defrost, but you can override it by just hitting the A/C button to turn it back off.
Gary C
1990 Honda CRX Si turbo, Black
2002 Acura RSX Type-S, Desert Silver
GJC is offline   Reply With Quote
Old 02-09-2002, 02:13 AM   #16
TrustRSX
Master Member
TrustRSX's Avatar
TypeSZH,
I must be doing something wrong here. The same thing happened as with the first time I tried this.
The recirculation light will blink 6 times, but the a/c light stays off. How did you get it to blink?
Old 02-09-2002, 07:46 AM   #17
AnDylishus
The Dylishus One
Groovy.
so every time you shut your car off it resets back to the original settings? or in other words you have to do this every time to get the ac to full manual control?
Old 02-09-2002, 11:28 PM   #18
sc1977
Arctic Blue Type S
sc1977 is an unknown quantity on c-rsx
TypeSZH,
Ya, same here. I have no clue what I am doing wrong?
sc1977 is offline   Reply With Quote
Old 02-10-2002, 09:24 AM   #19
XSR
Senior Member
XSR is an unknown quantity on c-rsx
No, it will stay that way.
XSR is offline   Reply With Quote
Old 02-10-2002, 04:25 PM   #20
TypeSzH
BUm
TypeSzH's Avatar
Man i don't know. Let me repeat.
Turn all knobs all the way to the left.
Before the key is in the ignition(this is how i did it)
Hold down BOTH Recirculation and AC button. Make sure its the button to the most left and the middle one. NOT THE DEFROSTING BUTTON.
Turn the car on to two (ll) . The recirculation blinks ONCE and the AC blinks once.
That is wut happen i n my car. Maybe it blink more. But the ac blink once and i let it go.
Old 02-10-2002, 07:59 PM   #21
TrustRSX
Master Member
TrustRSX's Avatar
Motor,
Can you offer any insight on this? I know I specifically held down the recirc and a/c buttons prior to inserting the key.
Old 02-10-2002, 10:28 PM   #22
muxx
Administrator
muxx is an unknown quantity on c-rsx
Is this actualy working or do you just assume its disabling it? Because the blinking lights could just be the Climate Control diagnostic mode.
02' Satin Silver RSX Type-S
muxx is offline   Reply With Quote
Old 02-10-2002, 11:32 PM   #23
calgary1
Senior Member
It didn't work for me either... gonna try it again tomorrow.
Old 02-11-2002, 07:55 AM   #24
XSR
Senior Member
I've had this done on mine for over a month now. So to answer your question, yes, it does work.
Old 02-11-2002, 10:01 AM   #25
twisterbret
Guest
Posts: n/a
I was able to get my to take. The directions say to turn the knob all the way to the left so the vent is closed. In the RSX all the way to the left is Auto. Turn it one notch up. The vent won't be closed but that's the notch that allowed it to work.
Now that it's working..When I put the defroster on ..the AC turns on but I can use the AC button to shut it off.
Motor,
Reply
Bookmarks
on or off , solution
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
