K20a2 help - Club RSX Message Board
Go Back   Club RSX Message Board > PERFORMANCE BASICS RSX > Bolt-On Basics: RSX Type-S
Old 03-16-2019, 09:15 PM   #1
jpstripeit
jpstripeit is a jewel in the rough of c-rsx jpstripeit is a jewel in the rough of c-rsx jpstripeit is a jewel in the rough of c-rsx jpstripeit is a jewel in the rough of c-rsx jpstripeit is a jewel in the rough of c-rsx jpstripeit is a jewel in the rough of c-rsx jpstripeit is a jewel in the rough of c-rsx jpstripeit is a jewel in the rough of c-rsx
K20a2 help
I'm building a car from scratch using a 04 RSX engine with Kpro. I'm trying to connect a ignition light that goes out once the alternator starts charging. I am using a Hybrid swap harness. I have a wire that has 12v from the bulb. Question is, where do I connect it to? I've tries the white lite blue wire and black with yellow with no results. Any help is appreciated.
jpstripeit is offline   Reply With Quote
Old 03-18-2019, 10:48 AM   #2
EP3A2
EP3A2's Avatar
EP3A2 is an unknown quantity on c-rsx
I would assume that most of the wiring/work would have to be done at the ecu because that's where you'll find the alternator signal wire.
The bulb needs constant power until you crank the engine over and run the alternator correct? The bulb would have to be linked some how to the alternator and a power source. Got a schematic?
I LoVe
EP3A2 is offline   Reply With Quote
Old 03-18-2019, 01:18 PM   #3
jpstripeit
You are correct but there is no wire at terminal B10 at the ecu.
k20a2
