I am getting a ton of emails concering what people need for the 05-06 k-pro.
what you need is a 02-04 PRB ECU or any other approved ECU (if you want to retain features like the reverse lock out you will want a 02-04 RSX Type S ECU as the donor) and also a primary O2 sensor from an 02-04.
the most common purchased option is $1140 if you ship it yourself to Hondata (the ECU only, no key or immobilizer).
your second option is to out right buy the k-pro for the 05-06 found here
the cost is $1689 and you still need to supply yourself a 02-04 O2 sensor.
make sure you select Hondata supplied option in the drop down for $549. The lead time would be approximately 4-5 business days for the new ECU to show up at your door (Yes all you have to do is wait for that brand spankin new K-pro to come to you)
so ..... we do not need out 05/06 ECU any more ....... all we do is buy a new ecu from hondata ...
like the ECU here ?
$1145 - K-Pro, ECU modifications and adapter harness (user supplied donor ECU).
$1745 - K-Pro, ECU modifications and adapter harness (with new Honda 2004 RSX-S kECU)
if that is so and i have an type-s 06
all i need is $1745 ECU, is that right ?
also will the $1745 cover all the stuff we need for the boost ?
or do we need to get thing like the oxygen senor and OBD2 ?
I got eveything for like $1450.00: $311.00 for used 02-04 ecu, $185.00 for o2 sensor, and about $950 for kpro, and $5.00 for crsx premium membership, (this was to save 5% on the price of kpro.)
You can save money buying a used ecu, and if you have a premium membership on crsx.
ok I know I'm :deadhorse but I just want to make sure I have everything straight. I find an ECU from an 02-04 rsx type s, I ship that to hondata. They ship it back with K-pro, I replace my stock ECU with the one Hondata has shipped to me, this much I'm clear on. But can someone go more in-depth on the sensor we need? i.e. what's involved in installing it, whether or not I need to ship that to hondata with the ECU, etc. Also, as I add on more mods, are there custom calibrations that I can upload to accommodate? Last, how familiar do I have to be with the internals of my engine, or can I get away with pre-existing calibrations?
you can buy it from Hondata but it doesn't work like that. You have to get the ECU changed to work for an 05-06. If you just buy the harness and plug it into an 02-04 K-Pro it won't work.
You have to buy an ecu from a 02-04 model year and then purchase Kpro through an authorized dealer like CRSX. The dealer will forward your info to Hondata, and all you have to do is ship the ecu to Hondata, they will modify it, install the kpro board, and give you an adapter that will enable you to connect to your 05-06 RSX.
You can usually get a used one for under $400.00. Check on ebay, and the classified section on CRSX. Also check to see if anyone is currently selling their already modified ecu with Kpro on it, you can save some money that way.
o wow only 150? are u sure? and can i send it to hondata myself? reason is i already bought an 02-04 kpro. how do i get that change for the price of 150? thnx
I currently have an 05 Reflash and want to upgrade to KPRO, and I know they offer a discount for existing customers...I just don't know if this applies to 05-06 because we need a new ECU. Can anybody weigh-in on this?:dontknow:
Related Threads
29.7M posts
179.4K members
Since 2001
