need help! electrical short after JRSC install - Club RSX Message Board
Go Back   Club RSX Message Board > PERFORMANCE BASICS RSX > Supercharging RSX
Reply
Thread Tools
Old 05-12-2016, 07:52 AM   #1
i-Zapp
03 RSX type SC
i-Zapp's Avatar
i-Zapp is a jewel in the rough of c-rsx i-Zapp is a jewel in the rough of c-rsx i-Zapp is a jewel in the rough of c-rsx i-Zapp is a jewel in the rough of c-rsx i-Zapp is a jewel in the rough of c-rsx i-Zapp is a jewel in the rough of c-rsx i-Zapp is a jewel in the rough of c-rsx i-Zapp is a jewel in the rough of c-rsx
just finished the install, and while trying to reconnect the ground wire to the battery- BIG sparks. Not like the normal discharge after reconnecting a battery. Checked ohm between hot side of battery and engine ground, and sure enough, dead short. wtf. figured that the big positive wire to the starter got pinched by the blower (it looked real close from underneath), but after pulling it there's no evidence of a bare wire or rubbed insulation.
has anyone experienced similar? any ideas? with ignition off, the only "live" wires are the one going to the starter, or are there others?
probably going to carefully reinstall again this evening, and check the ohms at each step. even if I'm successful, I'm concerned about what it was and whether it might recur again at a later time.
thanks!
2003 RSX type "SC" Supercharged
i-Zapp is offline   Reply With Quote
Sponsored Links
Advertisement
Old 05-12-2016, 09:29 AM   #2
nats007
Always on TDY...
nats007's Avatar
nats007 is on a distinguished road
Garage
It's the starter lead... Had the same issue. You have to reposition it
Here is what I had to do: http://forums.clubrsx.com/showpost.p...5&postcount=43
2002 NHBP RSX-S | K-Pro v3 | 2006 K24a2 | JRSC (K24a2 CP + 3" BP) | MercRacing Inlet
FIC 775cc | AEM W/M (1000cc/min) | 3" Custom SRI | OBX v1 RH | 2.5" Custom Catback
nats007's DC5 progression
nats007 is offline   Reply With Quote
Old 05-12-2016, 10:11 AM   #3
i-Zapp
03 RSX type SC
i-Zapp's Avatar
dude, you are like my guardian angel! you're always giving this guy help. next time in FL, I'm buying you a beer.
interstingly, on mine there's no evidence of a bare wire but will check more thoroughly tonite. when you repositioned the starter lead downward, did you grind the plastic guide on the starter that orients the eyelet of the starter wire or just bend the eyelet?
(btw, I too broke my frickin knock sensor lol. seems it needing replacing anyways)
Old 05-12-2016, 02:13 PM   #4
nats007
Always on TDY...
nats007's Avatar
Garage
no worries Sir!
Yes, you need the grind down the plastic guide ( I used a dremel). I didn't remove the starter, just disconnected it, grinded down the plastic, and reattached the eyelet positioned down, and electrical taped it up!
The knock sensor is super sensitive so be careful and ensure the wires are positioned away from getting pinched by the blower manifold
Reply
Bookmarks
electrical , install , jrsc , short
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
