Electronic Power Steering does work in the 05-06 RSX - Club RSX Message Board
Go Back   Club RSX Message Board > PERFORMANCE BASICS RSX > Supercharging RSX
Reply
Thread Tools
Old 03-04-2009, 08:13 PM   #1
Surferboy
Been there & gone back
Surferboy's Avatar
Surferboy is a jewel in the rough of c-rsx Surferboy is a jewel in the rough of c-rsx Surferboy is a jewel in the rough of c-rsx Surferboy is a jewel in the rough of c-rsx Surferboy is a jewel in the rough of c-rsx Surferboy is a jewel in the rough of c-rsx Surferboy is a jewel in the rough of c-rsx Surferboy is a jewel in the rough of c-rsx Surferboy is a jewel in the rough of c-rsx
I am not going to duplicate information on the install that has been already posted by Erik Loza originally. He did an awesome DIY
http://forums.clubrsx.com/showthread...ht=eps+install
The labor force
JustinC (wiring master)
Erik Loza (great host and grunt)
Jenny (Fantastic cook, host and wonderful person)
Well this past weekend we tackled the electronic power steering project on my 06 RSX Type-S and had great success.
Other RSX owners have been unsuccessful in getting the eps rack to work on the 05-06 rsx because these rsxs use a high frequency vss signal. Hybrid racing came out with a converter to change that high frequency signal to a low frequency signal which it does well. So once it is wired in we were able to uncheck the countershaft driven speedsensor option in kmanager and the guage cluster and rack worked.
When we first started this on Sat our goal was to determine whether or not the 06 guage cluster ran off a low or high frequency signal and it was found that it runs off a low frequency signal. I was shocked that hondata did not know this or just chose to not disclose this information for whatever reason which is perfectly fine. Either way a few tests and we had the frequency identified. Once we had the speedo in the dash working correctly we knew the rack would work as well which was the case.
There are few side affects of this install which are good and one is not so good. The good news is that cruise control now works for me which it never had before for any length of time and also the speedo does not periodically drop off anymore which is why cruise would kick off on us. The not so good news is that the hybrid device is calibrated for 15" wheels and not 17" wheels so the speedo is off. We are currently looking into a few options for this as well.
http://www.hybrid-racing.com/?cat=4&p=686
The one item we did not explore is if kpro does send a low frequency signal to the speedo why wouldnt the rack work without the hybrid device. The answer is I think it would but there is a catch. I do not think I would want to run this rack with the kpro signal because if you are a 05-06 rsx owner we all get the crazy drop in speedo readings from kpro. With this in mind I would hate to be driving down the road and all of a sudden have power being given to the rack because the vss signal fluctuates. Doesnt sound safe to me.
While putting in an EPS rack is not for everyone it was a great mod for me since we are working on putting a Lysholm Twinscrew blower in the car. With that said this speed converter seems like it would be a good item for those of you who like your cruise control. I have sent an email out to HYbrid to inquire about a resolution with not being able to calibrate the device. I have looked at the Dakota Digital product which seems to do the same thing and is cheaper but since I had invested in the hybrid I thought I would work with them before going with the dakota device. Either way I will have a resolution.
----------------------------------------Update 3/29/09----------------------------------------------------------------------------------------------------------------------------------------------------------------------
The Dakota Digital unit works WONDERFUL. I was able to easily calibrate for my wheel size and the best part it is only 79.95 bucks and some shipping compared to $200 for the Hybrid. It wires in the same as the Hybrid with one additional ground for the unit itself which I grounded on the frame.
12 volt - same as Hybrid
ground - same as Hybrid
Sensor Ground - Ground on the frame somewhere
Speed input signal - same as Hybrid
Calibrated AC output signal - same as Hybrid
Switch settings are as follows:
#1 - on
#2 - on
#3 - on
#4 - off
http://www.dakotadigital.com/index.c...rod/prd126.htm
JustinC is making another wiring diagram for the Dakota Digital wiring and I will post that as soon as I get it.
Attached is the wiring diagram needed for the Hybrid harness, BCU, and vss sensor.
Thank you
Click image for larger version
Surferboy is offline   Reply With Quote
Sponsored Links
Advertisement
Old 03-04-2009, 08:31 PM   #2
DC5 FTW
12.3 @ 114 mph
DC5 FTW's Avatar
DC5 FTW is on a distinguished road
so the A18 has to be cut, the power for the vss sensor, does it have to be tap by the connector only? what about in Kpro, uncheck the 05 speed sensor option?
edit: NVM, reading > me
2013 WRX-STI Hatch Stage 2..
2006 RSX-S: Fullrace GT35R .... SOLD
Motorcycle Crew # 777
2007 Yamaha R6: Shoei RF1100, Alpinestar Mx-1, Driven -1/+2, Arrow Header, Yoshimura slip-on, PCIII, Gregg FE. SOLD
DC5 FTW is offline   Reply With Quote
Old 03-05-2009, 02:35 AM   #3
renrab
above status quo
renrab's Avatar
renrab is cool, not as cool as some though renrab is cool, not as cool as some though renrab is cool, not as cool as some though renrab is cool, not as cool as some though renrab is cool, not as cool as some though renrab is cool, not as cool as some though renrab is cool, not as cool as some though renrab is cool, not as cool as some though renrab is cool, not as cool as some though renrab is cool, not as cool as some though renrab is cool, not as cool as some though renrab is cool, not as cool as some though
thanks for the info Thomas, this should be stickied imo
renrab is offline   Reply With Quote
Old 03-05-2009, 08:14 AM   #4
jmercado567
Master Member
jmercado567's Avatar
jmercado567 is an unknown quantity on c-rsx
Great work and awesome documentation... Nothing but the best!
Thanks!
Get power
Documented Twin Screw Record: 424HP 301TQ 16-17psi http://forums.clubrsx.com/showthread.php?t=626669
jmercado567 is offline   Reply With Quote
Old 03-05-2009, 08:40 AM   #5
BlackNite
SS Specialist to the 6th
BlackNite is an unknown quantity on c-rsx
Welcome to the land of no power steering lines/pump! Just glad I didn't have to go through what u guys did to get it to work
My Home Page
BlackNite is offline   Reply With Quote
Old 03-05-2009, 01:03 PM   #6
DC5 FTW
12.3 @ 114 mph
DC5 FTW's Avatar
bump
Old 03-05-2009, 01:04 PM   #7
ReppinDa(603)
Senior Member
ReppinDa(603)'s Avatar
ReppinDa(603) is an unknown quantity on c-rsx
omg his is so awsome, i can now buy an eps system
vouches: fidencio74, azninvasion, KobeRsx24
ReppinDa(603) is offline   Reply With Quote
Old 03-05-2009, 02:05 PM   #8
JustinC
Master Member
JustinC's Avatar
JustinC is an unknown quantity on c-rsx
bump
No, the power needs to be 12v switched..meaning it needs to turn on and off by the key
2005 Silverstone Metallic AP2 Honda S2000
Sold: 2003 NHBP RSX Type S
S/C Crew #45
RED WING CREW #2
Originally Posted by rensoyka View Post
that's why most guys who suck get their hands on a repair manual, 95% less suckage
JustinC is offline   Reply With Quote
Old 03-05-2009, 02:09 PM   #9
BlackNite
yea, i got mine wired underneath the steering column
My Home Page
Old 03-05-2009, 02:14 PM   #10
DC5 FTW
12.3 @ 114 mph
DC5 FTW's Avatar
well i meant like i didnt wanna run the power wire all the way to the vss connector by the tranny lol. i was asking like if i could run the power wire from IG1 to vss for power by the dash before kpro instead of all the way to the tranmission. I'm gonna go do it now neway, hopefully my eps motor is still good haha.
Old 03-05-2009, 06:34 PM   #11
DC5 FTW
12.3 @ 114 mph
DC5 FTW's Avatar
well thanks for all the help! especially texas's guy and the stig. my EPS took a shit. I got the speedo to work so obviously it has signal. no power steering still.
Old 03-05-2009, 07:28 PM   #12
Carlow
BELT driven ASS whippen
Carlow's Avatar
Carlow is cool, not as cool as some though Carlow is cool, not as cool as some though Carlow is cool, not as cool as some though Carlow is cool, not as cool as some though Carlow is cool, not as cool as some though Carlow is cool, not as cool as some though Carlow is cool, not as cool as some though Carlow is cool, not as cool as some though Carlow is cool, not as cool as some though Carlow is cool, not as cool as some though Carlow is cool, not as cool as some though Carlow is cool, not as cool as some though Carlow is cool, not as cool as some though Carlow is cool, not as cool as some though
thanks for the great info, I will be looking into this in the near future
S2 CAMMED JRSC 13PSI- 312WHP 213TRQ SOLD
http://forums.clubrsx.com/showthread...0#post21403870 SHOWOFF THREAD
Carlow is offline   Reply With Quote
Old 03-27-2009, 12:31 PM   #13
ReppinDa(603)
Senior Member
how much was the hybrid racing peaice???????
Old 03-27-2009, 12:49 PM   #14
Surferboy
Surferboy's Avatar
I got mine for 150 on sale but they went back to 200. The Dakota Digital does the same thing for 80. I just got mine but havent wired it in yet but will update thread soon enough. The Dakota you can calibrate for wheel size.
Old 03-27-2009, 01:31 PM   #15
JustinC
Master Member
JustinC's Avatar
Yeah, everyone sit tight on purchasing the hybrid device, let us get a document on the dakota digital piece, it will be a much better option
S/C Crew #45
RED WING CREW #2
Old 03-27-2009, 07:49 PM   #16
Agent Smith
It is inevitable
Agent Smith's Avatar
Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more
Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more
added to the faq's guides and solutions.
Originally Posted by waltMA70 View Post
The thing I like best about camaros is that they come new from the factory smelling like winston cigarettes.
S/C Crew Member #7 CRSX Zombie Eradication Team Member #10|Anime Crew 三番
http://i2.photobucket.com/albums/y41/Xinu38/Untitled-2_zpsceedtb4z.gif
Agent Smith is offline   Reply With Quote
Old 03-27-2009, 11:59 PM   #17
himsweet66six
Hawks
himsweet66six's Avatar
himsweet66six is an unknown quantity on c-rsx
good stuff. curious to know is there any other benefits from doing the swap besides not haveing the extra pulley and more belt wrap? why is this better if u convert to twin screw? also does the steering feel better? is eps better than hydrolic? sorry for the noob question. also where is a good place to purchase a eps system and what peices of it do u need? rack , ecu, anything else
Google. What Can I Say?
himsweet66six is offline   Reply With Quote
Old 03-28-2009, 02:02 AM   #18
jdmkid
Master Member
jdmkid might be well recognized one day on c-rsx jdmkid might be well recognized one day on c-rsx jdmkid might be well recognized one day on c-rsx jdmkid might be well recognized one day on c-rsx jdmkid might be well recognized one day on c-rsx jdmkid might be well recognized one day on c-rsx
nice, ive been waiting for someone to figure it out, now i need to find a eps rack. also cant you do the vss calibration in kpro or does they hybrid converter mess that up?
jdmkid is offline   Reply With Quote
Old 03-28-2009, 07:53 AM   #19
JustinC
Master Member
JustinC's Avatar
For all this information look for Erik's DIY and it has the parts list and a writeup on the install
S/C Crew #45
RED WING CREW #2
Old 03-28-2009, 07:54 AM   #20
JustinC
Master Member
JustinC's Avatar
You turn of the 05-06 countershaft option in Kpro which means you do lose the ability to calibrate the speedo with KPRO
S/C Crew #45
RED WING CREW #2
Old 03-28-2009, 03:30 PM   #21
ReppinDa(603)
Senior Member
will do, also i know this thread has nothing to do with an ap2 cluster in an 05 rsx, but does dakota digital make a speed converter to runs the ap2 clust, because i have my eps, and i have my s200 ap2 cluster, and i want both of these options
Old 03-29-2009, 02:35 AM   #22
jdmkid
Master Member
o makes sense
Old 03-29-2009, 02:50 AM   #23
Creepy Chris
Too much drama
Creepy Chris's Avatar
Creepy Chris needs to visit eHarmony.com or at least the hook up section on CraigsList Creepy Chris needs to visit eHarmony.com or at least the hook up section on CraigsList Creepy Chris needs to visit eHarmony.com or at least the hook up section on CraigsList Creepy Chris needs to visit eHarmony.com or at least the hook up section on CraigsList Creepy Chris needs to visit eHarmony.com or at least the hook up section on CraigsList Creepy Chris needs to visit eHarmony.com or at least the hook up section on CraigsList
Creepy Chris needs to visit eHarmony.com or at least the hook up section on CraigsList Creepy Chris needs to visit eHarmony.com or at least the hook up section on CraigsList Creepy Chris needs to visit eHarmony.com or at least the hook up section on CraigsList Creepy Chris needs to visit eHarmony.com or at least the hook up section on CraigsList Creepy Chris needs to visit eHarmony.com or at least the hook up section on CraigsList Creepy Chris needs to visit eHarmony.com or at least the hook up section on CraigsList Creepy Chris needs to visit eHarmony.com or at least the hook up section on CraigsList Creepy Chris needs to visit eHarmony.com or at least the hook up section on CraigsList Creepy Chris needs to visit eHarmony.com or at least the hook up section on CraigsList Creepy Chris needs to visit eHarmony.com or at least the hook up section on CraigsList Creepy Chris needs to visit eHarmony.com or at least the hook up section on CraigsList Creepy Chris needs to visit eHarmony.com or at least the hook up section on CraigsList Creepy Chris needs to visit eHarmony.com or at least the hook up section on CraigsList Creepy Chris needs to visit eHarmony.com or at least the hook up section on CraigsList Creepy Chris needs to visit eHarmony.com or at least the hook up section on CraigsList Creepy Chris needs to visit eHarmony.com or at least the hook up section on CraigsList Creepy Chris needs to visit eHarmony.com or at least the hook up section on CraigsList Creepy Chris needs to visit eHarmony.com or at least the hook up section on CraigsList
In for results of the Dakota piece.
Creepy Chris is offline   Reply With Quote
Old 03-29-2009, 03:22 PM   #24
Surferboy
Surferboy's Avatar
The Dakota Digital WORKS!
I just got done swapping out the Hybrid for the Dakota and all is well. I was able to calibrate my speed perfectly! I like it! 78 bucks versus 200 you just cant beat it. And you are able to calibrate your speed.
I will postup the wiring diagram and misc info need to run this thing later this week. I am giving the specs to Justin who will make a wiring diagram like he did for the Hybrid setup.
Life is good.
Old 03-30-2009, 03:21 PM   #25
ReppinDa(603)
Senior Member
Life is good.
will the Dakota Digital work to get my ap2 cluster to work in my 05 type s along with my eps?
Reply
Bookmarks
0506 , electronic , power , rsx , steering , work
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
