Official Aggressive Wheel Thread V4 - Page 64 - Club RSX Message Board
Go Back   Club RSX Message Board > SUSPENSION > Wheels & Tires
Old 07-30-2018, 10:28 PM   #1576
Rhas97
Rhas97's Avatar
Rhas97 is a jewel in the rough of c-rsx Rhas97 is a jewel in the rough of c-rsx Rhas97 is a jewel in the rough of c-rsx Rhas97 is a jewel in the rough of c-rsx Rhas97 is a jewel in the rough of c-rsx Rhas97 is a jewel in the rough of c-rsx Rhas97 is a jewel in the rough of c-rsx Rhas97 is a jewel in the rough of c-rsx
Originally Posted by Moises's_Rsx View Post
I have my car at that same height and no problems at all with -1.5 front and -2.5 in the rear for camber. You have even more negative so it shouldnt be rubbing the tops at all. But try okaying sih camber more and i suggest try putting spacers you never know. But thats weird. How long have you had the couls?
Ive had the BCs installed for about 2 months, im going to try to add more camber in the front when I install my SPC bolts and see if it will make a difference. Wont be able to do it immediately but as soon as I can I will update. Thanks
Rhas97 is offline   Reply With Quote
Old 08-15-2018, 02:18 PM   #1577
Rhas97
Rhas97's Avatar
update on setup , got the rear -re-rolled and adjusted the suspension a bit more , no more rubbing, only over big bumps, lowered my dampening as well. Will be heading to Etown this fall for a nice session to finally get some track time with her.
Old 11-13-2018, 05:00 AM   #1578
StayDC5Fresh
StayDC5Fresh's Avatar
StayDC5Fresh is a jewel in the rough of c-rsx StayDC5Fresh is a jewel in the rough of c-rsx StayDC5Fresh is a jewel in the rough of c-rsx StayDC5Fresh is a jewel in the rough of c-rsx StayDC5Fresh is a jewel in the rough of c-rsx StayDC5Fresh is a jewel in the rough of c-rsx StayDC5Fresh is a jewel in the rough of c-rsx StayDC5Fresh is a jewel in the rough of c-rsx StayDC5Fresh is a jewel in the rough of c-rsx
Back with a different set of wheels from 2015. Thinking of going 18x9 +22 with 255/35/18, anyone ran those specs? share some pics please.
255/40/17 17x9 +35, running 5mm spacer to make +30
IG: dc5_phan
StayDC5Fresh is offline   Reply With Quote
Old 11-13-2018, 05:03 AM   #1579
StayDC5Fresh
IG: dc5_phan
Old 11-13-2018, 10:14 PM   #1580
Ericcarver1
Ericcarver1's Avatar
Ericcarver1 is an unknown quantity on c-rsx
Sir,
18 x 9 +22 with 255/35/18 will require "fender finesse" and even with that you will still touch the upper wheel well sides on big dips and bumps.
I was running 18 x 9.5 +22 with 235/40/18 Falken Azenis and had to gut the wheel wells. No fender liners, extreme fender rolling (like hitting things with a hammer that stuck out) and it still rubbed on really hard corners and dips sometimes. I switched to Toyo R888 in 225/40/18, added some camber, and did even more work to the wheel wells and it works! A tiny "touch" on huge dips once in a while but almost flawless otherwise. Note: I never did have to pull the fenders which was a priority for me.
I think the perfect setup in 18" for function and form is 18 x 8.5 +30 (or so) with 235/40/18. But I understand this does not look as aggressive as most would like.
The best handling setup I ever had was 16 x 8 Rota Slipstreams with 225/50/16 Falken Azenis. Honda did not engineer cars for big wide wheels... not that we can't make them work.
I hope this assists!
-eric
"Towering genius disdains a beaten path. It seeks regions hitherto unexplored" -Abraham Lincoln
Ericcarver1 is offline   Reply With Quote
Old 11-14-2018, 11:51 AM   #1581
97 GSX 97
I Hate Honda's
97 GSX 97's Avatar
97 GSX 97 is a jewel in the rough of c-rsx 97 GSX 97 is a jewel in the rough of c-rsx 97 GSX 97 is a jewel in the rough of c-rsx 97 GSX 97 is a jewel in the rough of c-rsx 97 GSX 97 is a jewel in the rough of c-rsx 97 GSX 97 is a jewel in the rough of c-rsx 97 GSX 97 is a jewel in the rough of c-rsx 97 GSX 97 is a jewel in the rough of c-rsx 97 GSX 97 is a jewel in the rough of c-rsx
With BC Extreme Low Coils and SPC Camber Bolts on a previous car I was able to get it to -3.9 degrees of camber out of the front. You just had to tinker with it.
2002 RSX Base NHBP SOLD
2006 RSX Type S A-Spec VBP SOLD
2014 Mercedes C300 Sport Plus
2002 RSX Type S Laser Blue Turbo
97 GSX 97 is offline   Reply With Quote
Old 11-22-2018, 10:22 PM   #1582
StayDC5Fresh
I'm thinking of running 18x9.5 +22. with 255/35/18. i'm not as low as i used to be. so some camber will be fine with me, just not excessive. we'll see how it goes.
Originally Posted by Ericcarver1 View Post
Sir,
-eric
IG: dc5_phan
aggressive , wheel
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
