Headrest Insert replacement parts - Club RSX Message Board
Old 02-20-2018, 11:15 AM   #1
bp787
Colts SuperBowl Crew
bp787's Avatar
bp787 is an unknown quantity on c-rsx
my headrest inserts are separating. The tabs no longer click together. A long time ago, I had this fixed under warranty.
Now, it appears near impossible to find either the graphite inserts or the 06 silver inserts.
Anyone know where I can buy these? or if I only need to buy the front or rear to fix this issue?
I currently have graphite inserts 81146-S6M-J11ZA 81146-S6M-J01ZA
https://www.oemacuraparts.com/oem-pa...BlZWQtbWFudWFs
2007 Infinity G35S Sedan 6MT - Sport Package - Garnett Red
2002 Arctic Blue Pearl Type-S
*** HPDE 1 passed.
*** Putnam Park best lap time: 1:35
[/URL]
bp787 is offline   Reply With Quote
Old 02-20-2018, 07:13 PM   #2
Perfectionist
Perfectionist is an unknown quantity on c-rsx
Bernardi parts doesn't indicate discontinued.
https://acura.bernardiparts.com/Acur...S6M-J11ZA.aspx
Lots of others come up with google. Email to check availability first.
They also show up on ebay but didn't check the details to see if they are OEM.
Perfectionist is offline   Reply With Quote
Old 02-22-2018, 11:11 AM   #3
bp787
bp787's Avatar
I had already called them. no dice.
none of the acura parts sellers have a full set. seems that there are a few that have 1 side. I'm assuming that's the side that breaks. I'll have to fully pull mine out to check.
Only found one on ebay. will check again.
*** HPDE 1 passed.
[/URL]
Old 02-22-2018, 01:32 PM   #4
02RSXS
02RSXS is an unknown quantity on c-rsx
Might try finding one on car-part.com
...may need to call for the actual insert vs. the entire seat...
2018 Acura TLX A-Spec Still Night Pearl
02RSXS is offline   Reply With Quote
Old 02-24-2018, 09:12 AM   #5
bp787
bp787's Avatar
thanks for the tip.
I did figure out that one of the plastic clips on the front part is broken, allowing the whole thing to come apart, and there are small plastic guides that seem to wear down over time and allow the tabs to wiggle free. crappy design.
*** HPDE 1 passed.
[/URL]
Old 02-26-2018, 08:21 AM   #6
02RSXS
I had my car for 13 years and never had an issue with these inserts, but if someone were using that to pull the seat back in place or a little careless in removing/reinstalling them I could see how the broken tab and worn guides could occur.
Old 02-27-2018, 06:59 AM   #7
bp787
bp787's Avatar
I've only removed my seats 2-3 times, and I'm an OG owner from 2002.
They were replaced under warranty in 2004 or 2005. There was a TSB on it that I can't find. known issue of the clips breaking. It happens.
*** HPDE 1 passed.
[/URL]
Old 03-02-2018, 02:00 PM   #8
02RSXS
I started out with a new '02 Type-S and later traded it in on a new '05 Type-S. Never had the problem in either one, but obviously it happened enough for them to issue a TSB.
Old 03-08-2018, 01:34 AM   #9
bp787
bp787's Avatar
I'm either going to 3d print a version, or glue them together...
*** HPDE 1 passed.
[/URL]
headrest , insert , parts , replacement
