Rear caliper replacement - Club RSX Message Board
Old 05-10-2018, 12:39 AM   #1
Arien Victus
Arien Victus is a jewel in the rough of c-rsx Arien Victus is a jewel in the rough of c-rsx Arien Victus is a jewel in the rough of c-rsx Arien Victus is a jewel in the rough of c-rsx Arien Victus is a jewel in the rough of c-rsx Arien Victus is a jewel in the rough of c-rsx Arien Victus is a jewel in the rough of c-rsx Arien Victus is a jewel in the rough of c-rsx
I have an 03 rsx, and don't have a lot of experience with cars, I found how to do the basic parts but I'm stuck on the parking brake line, how can I get that off, does the piston loosen the tension spring or did I really mess something up? Base model. Automatic.
Arien Victus is offline   Reply With Quote
Old 05-10-2018, 08:02 AM   #2
You have the brake released right? Pretty sure all you have to do is remove the cable clip on the bottom, then push the lever down to release the end of the cable. Think I used a screwdriver to compress the lever and slide the end of the cable off.
Old 05-10-2018, 08:20 AM   #3
Arien Victus
The silver clip?
Old 05-10-2018, 09:42 PM   #4
marko16 is a jewel in the rough of c-rsx marko16 is a jewel in the rough of c-rsx marko16 is a jewel in the rough of c-rsx marko16 is a jewel in the rough of c-rsx marko16 is a jewel in the rough of c-rsx marko16 is a jewel in the rough of c-rsx marko16 is a jewel in the rough of c-rsx marko16 is a jewel in the rough of c-rsx marko16 is a jewel in the rough of c-rsx
Look a little deeper. There are two 10mm bolts that hold the bracket on that holds the cable. Just undo those and getting the cable out is easier.
caliper , rear , replacement
