Inner Tie Rod Replacement Help - Club RSX Message Board
Old 02-23-2019, 05:19 PM   #1
StraightEdgeKiDD
StraightEdgeKiDD's Avatar
StraightEdgeKiDD is a jewel in the rough of c-rsx StraightEdgeKiDD is a jewel in the rough of c-rsx StraightEdgeKiDD is a jewel in the rough of c-rsx StraightEdgeKiDD is a jewel in the rough of c-rsx StraightEdgeKiDD is a jewel in the rough of c-rsx StraightEdgeKiDD is a jewel in the rough of c-rsx StraightEdgeKiDD is a jewel in the rough of c-rsx StraightEdgeKiDD is a jewel in the rough of c-rsx StraightEdgeKiDD is a jewel in the rough of c-rsx
About to attempt this just need to get the right tool and just want to make sure I'm doing it right so I don't waste my time so just looking for some insight.
(seems like there's a lot of mixed info when you try searching this up with people explaining how to the outer tie rods ends.)
saw someone on the forum mention you need to turn the nut clockwise.. seems weird that it would be reverse threaded.
if you look at the photo in my attachment, do I need to bend flat washer at all (blue arrow)? if not am I just spinning the nut (red arrow) counter clockwise?
will probably just end up figuring it out myself but any input is appreciated, thanks!
StraightEdgeKiDD is offline   Reply With Quote
Old 02-23-2019, 11:49 PM   #2
TheRickster
TheRickster's Avatar
TheRickster is a jewel in the rough of c-rsx TheRickster is a jewel in the rough of c-rsx TheRickster is a jewel in the rough of c-rsx TheRickster is a jewel in the rough of c-rsx TheRickster is a jewel in the rough of c-rsx TheRickster is a jewel in the rough of c-rsx TheRickster is a jewel in the rough of c-rsx TheRickster is a jewel in the rough of c-rsx TheRickster is a jewel in the rough of c-rsx TheRickster is a jewel in the rough of c-rsx
Dude I'm curious to. I'll be doing this when it warms up and I've wondered the exact same thing.
I do everything in a parking lot or friends garage, so i study the fuck out of DIYs the manual, and youtube so I can go in as prepared as can be.
02 RSX Type-S
09 Pontiac G6 v6
TheRickster is offline   Reply With Quote
Old 02-24-2019, 01:21 AM   #3
StraightEdgeKiDD
People like you are wild lol I could never
I research diys too but every time I try to do something on my car it always takes longer then expected, would not be down to leave my car at the park lol
13 CBP Civic LX (Daily)
03 NHBP RSX Type-S
Old 02-24-2019, 10:19 AM   #4
marko16 is a jewel in the rough of c-rsx marko16 is a jewel in the rough of c-rsx marko16 is a jewel in the rough of c-rsx marko16 is a jewel in the rough of c-rsx marko16 is a jewel in the rough of c-rsx marko16 is a jewel in the rough of c-rsx marko16 is a jewel in the rough of c-rsx marko16 is a jewel in the rough of c-rsx marko16 is a jewel in the rough of c-rsx
I'd try lefty loosy first. I haven't done an RSX but haven't come across reverse threads unless that bolt goes all the way through. Looks like that bent over bit has a tab on the back or bottom that needs to be bent to allow rotation.
Old 02-24-2019, 08:05 PM   #5
StraightEdgeKiDD
Well first attempt today was a failure. Also don't want to strip the nut so I'm a little hesitant on which way to turn it.
It just seems wierd because it's bent the opposite way of what I would think would lock the nut in place so I'm not sure how to bend it.
03 NHBP RSX Type-S
Old 02-24-2019, 09:05 PM   #6
By the picture they are bent wrong, but on the bottom could be the one bent in the right direction.
Old 02-24-2019, 09:21 PM   #7
StraightEdgeKiDD
I get what you mean that would make sense but on the top there's another bend but its bent the same way.
03 NHBP RSX Type-S
Old 02-26-2019, 02:15 AM   #8
StraightEdgeKiDD
ended up figuring it out and created a diy:
https://forums.clubrsx.com/showthread.php?t=1262189
03 NHBP RSX Type-S
Old 02-28-2019, 06:57 PM   #9
thanks for posting that as I couldn't figure why they needed bending
replacement , rod , tie
KTuned Tie rod and spherical tie rod end kit GuintZ Suspension, Chassis & Brakes 5 11-20-2017 10:40 AM
changing out inner tie rod shattered_memory The DIY Garage RSX 12 03-12-2017 04:22 AM
Please help! Removing Inner Tie Rod beaverco22 Problems & Solutions RSX 5 10-05-2014 04:08 PM
Inner tie rod solution juggindc5 Suspension, Chassis & Brakes 15 07-24-2009 01:07 PM
