Air mix control motor replacement - Club RSX Message Board
Go Back   Club RSX Message Board > GENERAL RSX > Problems & Solutions RSX
Reply
Thread Tools
Old 08-19-2014, 06:43 PM   #1
Djiban
Not a noob, not yet a vet
Djiban's Avatar
Djiban is an unknown quantity on c-rsx
Ok so basically I have a problem which some of you may have encountered. My climate control is not working properly, the air mix lever (driver side, underneath dash) only moves either when I set the temperature to max hot or cold, it doesn't move in between. I've done the climate control unit diagnostic test and it didn't blink at all.
As described in another post by someone: "on the passanger side of the car and look under the dash between the d/side and p/side. Look up into the dash from there and then turn the temp knob(make sure the power is on) and look for a little white lever to move".
I am assuming it has something to do with the air mix control motor. Now, how do I replace it? (couldn't find a DIY on that and I've searched). Any help is appreciated.
Thanks!
Djiban is offline   Reply With Quote
Sponsored Links
Advertisement
Old 08-22-2014, 07:15 PM   #2
Jay
likes to troubleshoot
Jay is an unknown quantity on c-rsx
The air mix control motor should set a CCU code if there's a problem with it. Sounds more like a binding problem with the linkage to me, but there's a test for the motor on pg 21-43 of the Helm.
base/auto Comptech air filter
Jay is offline   Reply With Quote
Old 08-23-2014, 02:06 PM   #3
B|acknd
Member
B|acknd is a jewel in the rough of c-rsx B|acknd is a jewel in the rough of c-rsx B|acknd is a jewel in the rough of c-rsx B|acknd is a jewel in the rough of c-rsx B|acknd is a jewel in the rough of c-rsx B|acknd is a jewel in the rough of c-rsx B|acknd is a jewel in the rough of c-rsx B|acknd is a jewel in the rough of c-rsx
I have the same problem. When I switch from one temp to another I can here a pop under the dash. Up underneath the driver side dash I can manually turn the cog to move the air blend door to get heat or cool air. Seems to me it's going to be a real pain in the ass to get it off. Hopefully someone can offer some advice to get it off.
B|acknd is offline   Reply With Quote
Old 04-12-2019, 07:13 AM   #4
JayPee-100
New Member
JayPee-100 is a jewel in the rough of c-rsx JayPee-100 is a jewel in the rough of c-rsx JayPee-100 is a jewel in the rough of c-rsx JayPee-100 is a jewel in the rough of c-rsx JayPee-100 is a jewel in the rough of c-rsx JayPee-100 is a jewel in the rough of c-rsx JayPee-100 is a jewel in the rough of c-rsx JayPee-100 is a jewel in the rough of c-rsx
Thanks!
You ever get this sorted out?
I'm having to replace my air mix motor since it's completely broken. Was looking for an easy way to get at it and replace it
JayPee-100 is offline   Reply With Quote
Reply
Bookmarks
air , control , mix , motor , replacement
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
